REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.64
HARDWARE: Xperia 10 III
Android Version before flashing Sailfish: 62.0.A.9.11
VOLTE: Disabled
UI LANGUAGE: German
IPv4 and IPv6 mobile data connection works as expected on Xperia X (F5121), SFOS 4.4.0.64, with the same SIM card and same APN settings.
No IPv4 mobile data connection with MNO Telekom Deutschland possible.
SIM card from MNO Telekom Deutschland (e.g. MVNO Congstar)
A.) Set up mobile data access point for dualstack (e.g. Congstar APN: internet.telekom, Protocol: Dual, Auth: PAP, User: congstar, Password: cs)
or
B.) Set up mobile data access point for IP(v4) (e.g. Congstar APN: internet.telekom, Protocol: IP, Auth: PAP, User: congstar, Password: cs)
Turn off WLAN
Turn on mobile data
Ping a IPv4 address (e.g. ping 9.9.9.9)
Read output: âping: sendto: Network is unreachableâ
A.) Dualstack mobile data connection (IPv4 and IPv6) established
B.) IPv4 mobile data connection established
A.) Only IPv6 mobile data connection established
B.) No mobile data connection
(Please ALWAYS attach relevant data such as logs, screenshots, etcâŚ)
A.) Protocol setting: DUAL:
Jun 11 10:53:59 Xperia10III connmand[5393]: ipconfig state 2 ipconfig method 1
Jun 11 10:53:59 Xperia10III ofonod[3324]: Activating context: 1
Jun 11 10:53:59 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 11 10:53:59 Xperia10III kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Jun 11 10:53:59 Xperia10III kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Jun 11 10:53:59 Xperia10III kernel: HTB: quantum of class 10020 is big. Consider r2q change.
Jun 11 10:53:59 Xperia10III ofonod[3324]: setting up data call
Jun 11 10:53:59 Xperia10III connmand[5393]: ofono: 0x93c22e0 DUAL no IPv4 address set
Jun 11 10:54:00 Xperia10III connmand[5393]: ofono: 0x93c22e0 DUAL no IPv4 address set
Jun 11 10:54:01 Xperia10III connmand[5393]: ofono: 0x93c22e0 DUAL no IPv4 address set
Jun 11 10:54:01 Xperia10III connmand[5393]: cellular setup was not completed in time
Jun 11 10:54:01 Xperia10III connmand[5393]: ipconfig state 3 ipconfig method 1
Jun 11 10:54:01 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 11 10:54:02 Xperia10III systemd[5698]: selinux: Unknown permission start for class system
[root@Xperia10III defaultuser]# connmanctl services cellular_xxx-congstar-xxx_context1
/net/connman/service/cellular_xxx-congstar-xxx_context1
Type = cellular
Security = [ ]
State = online
Strength = 67
Favorite = True
Immutable = False
AutoConnect = True
Name = congstar
Roaming = False
Ethernet = [ Method=auto, Interface=rmnet_data2, Address=00:00:00:00:00:00, MTU=1500 ]
IPv4 = [ ]
IPv4.Configuration = [ Method=off ]
IPv6 = [ Method=fixed, Address=2a01:0598:92b4:cfa2:813e:7a68:0323:b9fa, PrefixLength=64, Gateway=fe80:0000:0000:0000:7858:2b86:e0a6:5079, Privacy=disabled ]
IPv6.Configuration = [ Method=fixed, Address=2a01:0598:92b4:cfa2:813e:7a68:0323:b9fa, PrefixLength=64, Gateway=fe80:0000:0000:0000:7858:2b86:e0a6:5079, Privacy=disabled ]
Nameservers = [ 2a01:0598:07ff:0000:0010:0074:0210:0221, 2a01:0598:07ff:0000:0010:0074:0210:0222 ]
Nameservers.Configuration = [ ]
Timeservers = [ ]
Timeservers.Configuration = [ ]
Domains = [ ]
Domains.Configuration = [ ]
Proxy = [ ]
Proxy.Configuration = [ ]
Provider = [ ]
Available = True
Saved = True
Access =
DefaultAccess = sailfish:1;ClearProperty(*)|Connect()|Disconnect()|Remove()|ResetCounters()=deny;group(privileged)=allow
B.) Protocol setting: IP(v4):
Jun 11 11:07:22 Xperia10III ofonod[3324]: Activating context: 1
Jun 11 11:07:22 Xperia10III ofonod[3324]: Unexpected data call status 51
Jun 11 11:07:22 Xperia10III connmand[5393]: [ofono] ERROR! GDBus.Error:org.ofono.Error.Failed: Operation failed
Type = cellular
Security = [ ]
State = idle
Error = connect-failed
Strength = 62
Favorite = True
Immutable = False
AutoConnect = True
Name = congstar
Roaming = False
IPv4 = [ ]
IPv4.Configuration = [ Method=dhcp ]
IPv6 = [ ]
IPv6.Configuration = [ Method=fixed, Privacy=disabled ]
Nameservers = [ ]
Timeservers = [ ]
Domains = [ ]
Proxy = [ ]
Provider = [ ]
Available = True
Saved = True
Access =
For comparison:
Xperia X, SFOS 4.4.0.64 with same SIM card and same settings (Case A)
[root@Sailfish nemo]# connmanctl services cellular_xxx-congstar-xxx_context1
Type = cellular
Security = [ ]
State = online
Strength = 67
Favorite = True
Immutable = False
AutoConnect = True
Name = congstar
Roaming = False
Ethernet = [ Method=auto, Interface=rmnet_data0, Address=00:00:00:00:00:00, MTU=1500 ]
IPv4 = [ Method=fixed, Address=10.19.204.200, Netmask=255.255.255.240, Gateway=10.19.204.201 ]
IPv4.Configuration = [ Method=fixed, Address=10.19.204.200, Netmask=255.255.255.240, Gateway=10.19.204.201 ]
IPv6 = [ ]
IPv6.Configuration = [ Method=fixed, Address=2a01:0598:9185:be0f:87e2:1b91:ce15:4730, PrefixLength=64, Gateway=fe80:0000:0000:0000:4825:a521:5116:c2f2, Privacy=disabled ]
Nameservers = [ 10.74.210.210, 10.74.210.211 ]
Timeservers = [ 0.sailfishos.pool.ntp.org, 1.sailfishos.pool.ntp.org, 2.sailfishos.pool.ntp.org, 3.sailfishos.pool.ntp.org ]
Domains = [ ]
Proxy = [ Method=direct ]
Provider = [ ]
Available = True
Saved = True
Access =
For further comparison:
Xperia 10 III, SFOS 4.4.0.64 with another SIM card from MNO O2 Deutschland (MVNO MEDIONmobile) (Case A)
[root@Xperia10III defaultuser]# connmanctl services cellular_x-medionmobile-x_context1
/net/connman/service/cellular_x-medionmobile-x_context1
Type = cellular
Security = [ ]
State = online
Strength = 37
Favorite = True
Immutable = False
AutoConnect = True
Name = MEDIONmobile
Roaming = False
IPv4 = [ Method=fixed, Address=10.134.11.52, Netmask=255.255.255.248, Gateway=10.134.11.53 ]
IPv4.Configuration = [ Method=fixed, Address=10.134.11.52, Netmask=255.255.255.248, Gateway=10.134.11.53 ]
IPv6 = [ Method=fixed, Address=2a02:3035:0c0a:421b:f5aa:442e:ade0:4e48, PrefixLength=64, Gateway=fe80:0000:0000:0000:70a7:709f:b4da:89b5, Privacy=disabled ]
IPv6.Configuration = [ Method=fixed, Address=2a02:3035:0c0a:421b:f5aa:442e:ade0:4e48, PrefixLength=64, Gateway=fe80:0000:0000:0000:70a7:709f:b4da:89b5, Privacy=disabled ]
Nameservers = [ 62.109.121.17, 62.109.121.18, 2a02:3018:0000:40ff:0000:0000:0000:aaaa, 2a02:3018:0000:40ff:0000:0000:0000:bbbb, 2a02:3018:0:40ff::aaaa, 2a02:3018:0:40ff::bbbb, 2a02:3018:0:40ff::aaaa, 2a02:3018:0:40ff::bbbb ]
Timeservers = [ ]
Domains = [ ]
Provider = [ ]
Available = True
Saved = True
Access =
