Many thanks to you our active contributors for your feedback and proposals.
Version history of the OS release
- 2024-05-20: OS version 4.6.0.11 was released to Early Access subscribers as an over-the-air update.
- 2024-06-06: OS version 4.6.0.12 was released to Early Access subscribers as an over-the-air update.
Stop release
4.6.0.15 is a stop-release.
Device models supported by Sailfish X
The supported Sailfish X devices are listed in this table .
This is the last release for the following products: Jolla Tablet, Jolla C, Xperia X and, Gemini PDA.
The instructions for installing Sailfish OS to Sony Xperia X, Xperia XA2, Xperia 10, Xperia 10 II (mark 2), and Xperia 10 III (mark 3) devices are here - covering Windows, Linux, and macOS computers.
The instructions for Xperia 10 IV and Xperia 10 V will appear in the same place.
This document explains what the Sailfish X licence is.
Release highlights
The list below contains bug fixes added to Sailfish OS, compared to the previous public release 4.6.0.11. All Sailfish OS release notes can be found here .
AppSupport
- Video calls via Android apps are shown in full screen again
Phone
- Voice call waiting fixed
Sailfish Utilities
- Tool for resetting audio (Pulseaudio) added for recovering from difficult audio problems. This item is lacking translations - it is in English only. The next OS update will fix it.
SDK
- Fixes
- An update to the Early Access Build Targets and Emulator. Note: The SDK target is 4.6.0.11 (not 4.6.0.12).
Xperia 10 IV & 10 V
- Several improvements
Sailfish OS Forum: issues reported by the community fixed in this update
Technical changes
The detailed changelogs are here.
Updating your device
By installing this update you accept the updated The Sailfish OS End User License Agreement.
The usual update process
Your device must be connected to the Internet and signed into your Jolla account.
Start the update from āSettings > Sailfish OS updatesā. Avoid running updates on the command line, please.
We warmly recommend making some 3-4 GB of free space for the internal storage of your device ( /home ) before starting the update. Processing an OS update of almost 1 GB requires a good amount of work area. Move your pictures and videos to the SD card (or your PC or cloud service).
This is the usual drill before attempting to update your devices:
Back up your data before an attempt to update your device and save the backup to an SD card or some other off-device location (PC, your cloud service). Note that videos and images are not included in cloud-based backups. Do not reboot the device while the update is in progress. Do keep the phone connected to a battery charger during the whole process. The device screen may get blank during the update process; you may wake the display with a short press of the power key to monitor the progress.
For detailed instructions on updating software, read our help article in Sailfish OS Documentation.
NOTE 1:
Sailfish OS does not support downgrading. Never try to downgrade the OS as this would break your device.
NOTE 2:
After downloading an update and selecting āInstallā in the pulley menu, the device runs a restart first. You will need to type the security code before the actual installation can start. A horizontal progress bar appears on a black background, under the Sailfish OS logo. When the other end of the bar has been reached the phone will restart automatically. If it doesnāt, please wait for 15 minutes. If it is still stuck at the 100% point of the progress bar it is time to perform forced power off . Next, turn the phone on with the power key and check the OS version at āSettings > About productā.
NOTE 3:
The Jolla Shop has the images of the latest OS release only. Keep the previously downloaded ones stored on your computer if you should want to reflash one of them later on.
Notification concerning apps from Open Repos
- Compatibility with the release 4.6.0 has not been verified yet. Early Access users, please report
Some apps from Open Repos have been reported to cause problems when installing OS updates. Read the recent comments on those apps.
- Call recorder has caused serious problems. We recommend uninstalling that app before the OS update. Read this comment, please.
Known issues
We have relocated the known issues to a table in Sailfish OS documents .
How did the upgrade go?
- I had no issues during the upgrade process
- I had small issues but was able to handle them
- I got into serious trouble when upgrading my device (please help!)
- I did not dare or want to update
0 voters
Help articles
The Sailfish OS help articles, previously kept in Zendesk, have been moved to Sailfish OS Documents repository.
Slack media is displayed full screen again.
