Along with the significant amount of issues and confusion discussed across diverse topics concerning NextCloud integration ( listed by the end ) some notes on the current state of usability and issues encountered for further development and improvements.
At the current state, NextCloud integration - as a preferred service for data retention - still requires a significant bit of work regarding :
- straight-forward setup
- de-cluttered menus
- reliability of synced contents
- workflow-oriented, coherent UI integration into SailfishOS
Great if an advanced integration could serve as a reference approach for other services in future âŚ
But itâll probably become quite unconvincing, if nothing would ever happen to further development goals of NextCloud integration to begin with.
Further development should employ actually set up environments for testing.
Setup of review :
SFOS 5.2.0.22 ( Jolla Phone 2026 )
Nextcloud Hub 26 Spring 34.0.0/.5
php 8.2.35
HostOS: Linux 6.18.53 x86_64
Experience based on setting up 3 Jolla 2026 phones.
Two in English one in German localization.
Reviewing notes :
Provisioning :
suspected SSL/ceritficate-issues ( as mentioned in some threads ) are not really a main culprit for malfunctioning NextCloud-integration ( especially if they work elsewhere in other instances on the phone ).
âhard-codedâ path definitions do not exist. Some forum-contributors suggest sticking to âSailfishOS/Backupâ will provide successful backup-uploads. This is not guaranteed.
You can use any path you like - the NextCloud Account-creation-wizard will even create it for you, if not existing. But - inconsistently with other path definitions - this only applies for backup paths. Not images, calendars, contacts and so forth.
Most important is a correctly provided WebDAV-path :
â/remote.php/dav/files/{user}â ( no â/â following ) and a file-path like â/remote.php/dav/files/{user}/backups/{you-name-it}/{and-so-forth}â -
a lot of hassle can be avoided if sticking to correct conventions :
WebDAV-path : /remote.php/dav/files/{user}
Addressbooks : /remote.php/dav/addressbooks/users/{user}[/{addressbook-name}]
Calendars : /remote.php/dav/calendars/{user}[/{calendar-name}]
Image-path : /remote.php/dav/files/{user}/pictures[/{you-name-it}/{and-so-forth}]
Backup-path : /remote.php/dav/files/{user}/backups[/{you-name-it}/{and-so-forth}]
SFOSes NextCloud-account-integration actually and currently supports these. -
URL encodings such as â%20â are ignored and produce odd folder namings within the backup-path. Probably not WebDAV-compatible.
while testing around, it became obvious, that Nextcloud-pulley-menu items âsyncâ and âdelete accountâ are too close together.
Mishaps are predestined. âdelete accountâ should be at the very far top end of the list. -
Considering the fact, that SFOS backups ( as well as calendars and address-books ) are not saved in any encrypted way, End-to-End Encryption (E2EE) should become implemented as well. ( securing not self-hosted user cases )
Contacts ( via âPeopleâ-app ):
Modifications of contacts in âPeopleâ-app do not sync automatically to cloud - even if âSync device changes automaticallyâ is set ( Settings/Accounts/NextCloud-account ) and
contact details are showing a NextCloud-addressbook-relation. -
relaunching the âPeopleâ-app has no effects on NextCloud-syncing. It doesnât do anything. Good thing to know, that unsynced changes currently survive a system reboot.
contact-syncs are currently only working via Settings > Accounts > Nextcloud-Account > pulley-sync. On the contrary, calendar events sync directly via pulley-sync in the âCalendarâ-app or worst when relaunching the app. Inconsistently implemented compared to contact-syncs.
syncing while leaving the âPeopleâ-app open will not update any changes into the âPeopleâ-app. âPeopleâ-app needs to be relaunched for updated contents. Also inconsistent.
Selecting and sharing contacts to Nextcloud via (Android) Nextcloud-app does not work ( âunable to find file to uploadâ error ) - thus it should not be offered.
The âPeopleâ-app pulley-menu is missing an âUpdate Address-booksâ-option. Address-book collections on NextCloud may change : renamings / deletions / additions. These should by synced properly on app launch and also via pulley-option ( to avoid relaunches ).
it is impossible to push-sync contacts ( e.g. locally saved âPeopleâ-app-contacts) into a cloud-based address-book. Currently you have to re-create local contacts completely new, with a NextCloud-address-book-assignment ( or export & re-import them externally via NextCloud-user-sessions ).
You also cannot change or modify NextCloud-address-book-assignments of contacts via âPeopleâ-app. It must be done externally via separate NextCloud-user-sessions.
These are significant workflow-impediments. -
Long-pressing a contact as well as a menu option âselect contactsâ should offer the possibility to assign a single or multiple contacts to a specific address-book. Not limited to NextCloud-address-books only.
Calendars ( via Sailfish calendar app 1.1.23 ) :
the âCalendarâ-app does not update modified / extended / reduced NextCloud address-book-collections under âManage calendarsâ. The app should be able of handling this robustly, according to the menuâs title.
currently the list of available NextCloud calendars only updates under Settings > Accounts > NextCloud > Sync or the âUpdate Calendarsâ-button by the end of the page.
Thatâs at least 5-6 swipes away from where usually needed. -
âCalendar managementâ should include the possibility to create / modify NextCloud-calenders. It should be capable of handling & catching typically specific NextCloud-parameters - such as limitations - by reading them out and informing the user appropriately instead of sneaking away quietly :
â Nextcloud Tasks/Calendar: Hidden limit of 30 calendars causes "unable to create the list" error | Cloudron Forum
Further Info : â Calendar / CalDAV â Nextcloud 35 Administration Manual -
after âupdatingâ NextCloud calendars (Settings > Accounts > NextCloud > Sync or âUpdate Calendarsâ) , calendars already deleted on NextCloud ( incl. NextCloud trash bin ) still show up as options under âNew Eventâ > âSelect calendarâ in the âCalendarâ-app :
It is possible to add events to calendars which already disappeared from the âManage Calendarâ listing but not from âSelect calendarâ in the âCalendarâ-app.
Such entries âsyncâ into nirvana without any further notifications. It stays in a local cache. Reboot ( most obvious option ) wonât help.
After revisiting the calendar 12hrs later, those âghost entriesâ disappeared though without any further notifications concerning affected calendar entries.
You canât share and sync calendars reliably with this kind of behavior. -
it is good to know, that RGB-hex-colors of NextCloud calendars are get synced into the SFOS calendar app.
NextCloud-set calendar reminders are not getting recognized at all. They have to be reset again after syncing to the native âCalendarâ-app. Thatâs tedious.
defining multiple day events is really tedious as well. Selecting multiple days by a swipe should be the way to go. There must exist libraries / repos providing calendar-date/time-picking functionality already way better and more ergonomic than currently implemented.
multiple-day events should be graphically displayed as day-binding lines also in month-view, than just as dots, to get a faster picture - especially when calendar-dot-colors are too alike.
Event-redactions ( such as changing calendar assignments ) via Nextcloud calendar UI can require two subsequent SFOS calendar-app pulley-syncs to take effect. First sync makes the event disappear - second shows it with its new assignment
Maybe this could be implemented
Backups ( via Settings / System /Backup ) :
- âBackupâ runs most reliably compared to other syncing services. It is capable of creating any folder path you like ( declared within the âBackup-pathâ-field under âAdvanced settingsâ of the NextCloud-account ) if not yet created / existent on cloud.
You can even âmisâ-use it to create other webDAV folders for other purposes ( and delete containing backup-files afterwards ).
File-syncing
UI-flow and clarity is really pre-alpha and confusing. Rather a prove of concept than a utility or a feature.
uploads not working over sharing are quitting silently without further notice. If proposed the proposed âDocumentsâ-folder is not existent, sharing to Nextcloud quits silently.
Folder destinations are neither selectable nor does sharing to webDAV automatically create non-existent, but possible folder locations to succeed ( as the Backup-tool does).
If you want to be sure, youâd first have to open a supplementary NextCloud-user-session to figure out about your current file-structure on NextCloud. Thatâs no workflow-support at all. -
A standard path for uploading - kind of a âdumpâ-directory via sharing cannot be set under âadvanced settingsâ of the NextCloud-accoount.
Selecting & syncing items from the âGalleryâ-app is rudimentary and rather a pain than a choice. For a few pictures itâs working. Storage-consuming video-files cannot be selected.
The âNextcloudâ-gallery within the âGalleryâ-app is not showing or syncing any contents. Havenât figured it out yet, how to make it work.
Summing up these issues, drawbacks and potentials, getting to work NextCloud and SailfishOS working hand-in-gloves should become a weighing top priority - eventually one of the core feature differentiating SailfishOS from others.
âââââ
Summary of topics & threads referring to :
WebDAV integration :
account setup :
calendar :
contacts :
backups :
syncs :
