BUILD ID: 3.3.0.16
HARDWARE (Jolla1, Tablet, XA2,…): Xperia 10 Plus
UI LANGUAGE: Swedish
Nextcloud integration works poorly:
I can sync pictures manually one by one
Autosync of pictures will not happen
System backup to Nextcloud fails with no intelligable error message. Not even in the /tmp/backup… file. And there is not even an attempt to access the Nexcloud server.
Calendars are visible, but contains no entries
Enter Nexcloud account
Try to do a backup to Nexcloud or
Take a picture and check if the picture is uploaded to Nextcloud
I probably will not be able to do it, though. Sounds above my complexity level. I will take a look, though. The Ghostcloud solution I might be able to get through, though.
Question remains: Should this not be a built in feature in Nextcloud Sync in Sailfish OS?
I just got myself a certificate from let’s encrypt and with that the System backup feature seems to work. Weird as the other features work with the selfsigned cert… The rest of my points are still valid even with the “real” certificate. And I really expect Sailfish Nextcloud integration to be able to auto sync my pictures…
I’ve always had Let’s Encrypt on my NextCloud instance, but backup works really randomly – most of the time it doesn’t work (with no error messages), but every now and then it’ll work for a few days without me doing anything.
same situation as @ender - Lets Encrypt and “random uploads”.
If i have a look in the backup folder the timestamp file ages are:
3, 8, 11,12, 15, 16 days. I did not start/stop it manually.
Setup is Daily, 03:00 wifi only - and i always have wifi at 03:00 in the morning.
