Edit calendar entries (Nextcloud)
I have my calendar on my Nextcloud and it synchonized fine with the calendar app on my Jolla C2. But I cannot edit the entries on the Calendar App from Sailfish OS, just delete and share them. Any ideas?
Did you chose Synchronisation “Two Ways” in the account settings?
Yes, thanks. I’ve found the problem and solved it: I created the calendar entry in my google calendar via Thunderbird Calendar, with my e-mail-address as the organiser. There I copied it to my Nextcloud Calendar. From there I synced it with my Jolla C2 calendar app. When I deleted the organiser e-mail in the Nextcloud calendar entry in Thunderbird Calendar, it turned out to be editable at last.
