Firefox on SFOS on Xperia 10 V? Native? I’m surprised. Where?
It’s the sailfish browser. It uses an engine from mozilla
And here you can upgrade it Install
- after every boot of Xperia 10 V bluebinder drain battery - process eating about 10-12% of cpu and phone is warm… (maybe related to [4.x, XA2+] Bluebinder service drain battery/CPU )
anyway after enabling bluetooth it is fine and phone temp is returning back to normal
but also noticed that after disabling of bluetooth it is problem to turn bt back on. mostly enabling wifi (or maybe wait couple of seconds) ‘helps’ somehow to successfully turn bluetooth back on. (on jp-1, xperia 10plus or 10ii it works instantly right after disabling can re-enable…)
bluetooth is always disabled after boot (should remember last state…)
no audio routing to the jack connector is annoying
will be nice to have screen wakeup for covers with magnetic part
fingerprint reader would be fine too
of course camera and batery status…
no issues with BT speakers and/or headphones - all fine
no issues with mobile data - 4G,5G, VoLTE works even with sms/mms (Vodafone cz - changed to IPv4 only)
no issues with WiFi except Annoying confirmation about which WIFI network to use
For me it saves the state of Bluetooth through reboots. Thanks for the observation. I will leave it enabled from now on
Or so i thought. Now Bluetooth is off after a reboot and i have difficulties turning it back on
Sometimes it fails to load for some reason and then it is “off” after reboot. It is hard to get it working again. Another reboot usually helps
If it loads correctly and if stayed “on” before reboot then after it will be “on” too.
I can confirm this Bluetooth behavior with my 10 V. Better to leave Bluetooth on.
What is your experience with screen brightness?
My 10 V can only be used inside, screen brightness is not sufficient for outdoor use with Sailfish OS. This is in contrast to
- 10 V screen usable outdoor with Android
- 10 iii screen usable outdoor with Sailfish and Android
According to specifications, 10 V screen is much brighter than 10 iii. With non Sailfish OS I can confirm this. But with Sailfish 4.6.15 beta even in max brightness settings screen is unusable dim on 10V for outdoir use.
Since my 10 V does not suffer dim screen under Android, I guess my hardware is OK, but Sailfish beta and the non-optimized OS is the reason.
But why then is nobody else reporting this dim screen issue.
What are your experiences?
Can anyone please test 10 V screen brightness in bright light against 10 iii screen brightness? Or a similar comparison?
The Xperia 10V screen gets more brighter if you turn of auto brightnes and turn the brightnes to max.
(No Comparison)
Interesting, in my device auto or non-auto makes no difference;
unfortunately,
… maybe my device has slightly different hardware??? I am just speculating, but slightly different hardware might also explain why some people experience the audio loss (after GPS) with the 10 iii and others do nor.
Dunno about configuration management in smartphone industry, but I worked in medical device sector many years, in this highly regulated environment, such silently available different hardware modifications within a single product line but not properly specified are NOT possible. So I am skeptical about that, but faulty hardware appears unlikely since an Android everything is fine.
Strange, very strange my 10 V unit.
The reason I choose the X10 V for Sailfish was the bright screen in the specs
There are only two variants that I know of. 6GB or 8GB RAM, otherwise the same. I’m not sure about your specific case but as you know different things may affect things that are not obvious right of the way.
This is still deep beta release, some people reported this some said i didn’t affected thier device. I’m sure Jolla knows about it already
I suppose it’s due to bluetooth In SFOS 4.6.0.15 In Xperia 10 V, that no info file is found In /var/lib/bluetooth/ when Amazfit Stratos 3 is paired with Amazfish App of Xperia 10 V.
Thus, I can not add Appearance=0x0192
In info file like In Refs. [1-2].
I found the server side pairing code (UUID, 32 characters long) from the log file of Zepp (in Android) by Windows 11 with command ‘adb logcat > full_log.txt’.
Pairing between Amazfish and Stratos 3 happens very slowly as early reported. I have now repeated that pairing several times with that server side pairing code.
Looking forward to SFOS 5 commercial update.
Curious, Stratos appears in the list of watches of Amazfish?
Yes, there is also support In App *) for Amazfit Stratos 3. But there are also limitations In Bluez In this SFOS 4.6.0.15 beta so far.
*) Amazfish 2.5.0 (2024-11-24) Chum.
Are there any news, any progress with 10V commercial image that somebody knows of?
This is the latest news as far as i know.
Was hoping for something I don’t know already.
So, I’ll go back to waiting
You probably saw this already?
That is very disappointing. I was under the impression that the updated blobs were the solution to all the problems, and all Jolla had to do was flip a few booleans, push an OTA update, and everything would be working.
Between the lack of a camera and especially being forced to use the speakerphone for all calls, it’s sometimes quite difficult to use my 10 IV.
Has anyone had success resizing the root directory?
I’m following the guide linked here and when I input
fastboot boot hybris-recovery.img
on step 3.3.1, I get
FAILED (remote: ‘not supported’)
