On Xperia X and Xperia 10 (probably XA2, also) only “Data”-selected sim will have 3g/4g, then the other sim will have 2G only. If there’s no 2G network for that sim, it won’t work at all.
We’ll see if it’s a SFOS limit on Xperia 10 II, since I checked on Android and it clearly supports 3g+4g sims working simultaneously.
Definitely, a precise bug report is a correct way. Power drain issues are hard to investigate because there are so many factors affecting them. It would be helpful if one can limit/eliminate some of those factors and compare with different devices or previous OS release on the same device. It is good to tell which Internet connections are used, how often various accounts are synced (and what are they), if ‘top’ shows some suspiciously active processes running for minutes, etc.
@Remote: You wrote “only “Data”-selected sim”. Do you mean that you have chosen this SIM for mobile data in Sailfish menu “Settings > Mobile network > Use SIM card” (while the other SIM is assigned for call and messages in “Settings > SIM cards”), or, do you mean that you have such a contract with your operator/carrier that your SIM does not support phone calls at all - so, it is just “data only”?
@peterleinchen@jovirkku
I can confirm this change in behaviour on the Xperia X. I wasn’t sure at first, but I checked the battery usage graphs in SysMon, and the battery is visibly going down much faster with WiFi enabled on 4.1.0 than it was on 4.0.1. In both cases, no applications or only the camera are/were running, and the only user-intended active online connection is two email accounts with their synchronisation set to ‘always up-to-date’. Android app support is active, but there are no Android applications running in the background. Hopefully we can find some more similarities and differences between our setups this way to estimate where the problem is actually located.
With WiFi disabled, power consumption appears to be the same as before.
Out of the devices I checked (Jolla C, Jolla Tablet and Xperia X), only the Xperia X has a much larger power consumption on WiFi in comparison to 4.0.1. The Xperia 10 II also seems to have a large power consumption on WiFi, but of course I can’t compare that one with a previous OS version.
Now testing with cell data enabled and WiFi off…
(looks normal until now which would really cut it down to connected WiFi)
may test later then with enabled but not connected WiFi.
One mail account set to manual sync.
No Android support running.
Bluetooth on.
Nil applications.
Fresh reboot.
Only one of the SIMs can provide the data transfer service (mobile data) at a time. It is the selected SIM, of course. The other SIM can only provide call and messaging service during that time. But this is not limited to 2G - phone calls over 3G should work equally well with that other SIM.
Note that Sailfish does not support VoIP/VoLTE - therefore phone calls via the 4G network are not possible (neither SIM).
So, if in your case the “other SIM” can work in the 2G network only then there is a problem. But where?
I got a message on my device yesterday saying I had entered a “4G Only area. Your device does not have 4G voice calling capability enabled. This means you may not be able to make voice/emergency calls in the area”
So the update notes say there should be a .24 available, but I can’t see it on my X10 II (although I am enrolled in EA). I would really like to test that, so that I can verify, if that fixes my bugs!
