BUILD ID = OS VERSION (Settings > About product): 4.1.0.23
HARDWARE (XA2, Xperia 10…): XA2
UI LANGUAGE: DE
REGRESSION: (compared to previous public release: Yes, No, ?): no
Sd card is no more mounted into /media/sdcard/cardname but in /media/sdcard/cardhashname.
This is fatal if people have stuff which rely on the cardname.
Mounted card
Mount a card (with a known name)
ls `/media/sdcard/known_name
directory is shown
file not found.
Would it be possible to define the path of the card once and never ever again? This mount path moved minimum 5 times on SFOS living. With all due respect: that sucks! You never know if e.g. your backup concept works, all tricks to outsource data from /home/username (by moving to sd card and link) may also break the system. This is more necessary for enterprise environments with e. g. automatical backup concepts.
Thanks for reporting. I will file a bug on this. Indeed, /media/sdcard shows the long and difficult UID code now, instead of the label/nickname given when formating the card.
@DrYak Doesn’t work for me I’m afraid. It still shows the long name. In the other thread - Name of SD Card I showed the various names for the card and I see that in there I don’t have a partition name. I have LABEL and PARTLABEL. Is that the reason that it shows up under ls /media/sdcard/ as the long name still?
Damn, indeed, behaviour has changed in recent versions of udisk2. (It’s still passed as a suggestion for the GUI, but not for the mount-point.
The last-ditch work-around I’ve fallen back to (and this one I’ve just tested, it’s still working with the latest 4.4.0.64 on 10iii):
File /etc/systemd/system/run-media-nemo-Ulysse31.mount ( ← that’s basically the mount path as in Where= below, but with dashes - instead of slashes /):
This will work for your “usual” card(s) or USB-C stick(s) for which you make a custom .mount systemd unit, but of course any unknown new SD card or USB-C stick will be mounted by UUID again.
LABEL is the partition name as used by blkid (the thing that you assign when formatting a filesystem, e.g. with mkfs.ext4 -L FunnyName or the Windows FAT32 formatter).
PARTLABEL is the name that some partionning systems can give to entries in the partition table. e.g. GPT-partitionned stick can have a PARTLABEL. MS-DOS partitionned one don’t have this.
PARTNAME is the partition name, but udisk2 uses a different way to LABEL by blkid.
UDISKS_NAME nowadays is only used by udisk when suggesting name for GUI’s filemanager, it’s not used for mount-points anymore.
The main issue is not to find temporary solution but that there is no consistent, stable sdcard mounting scheme/script, i.e /mnt/sdcard1 or /media/sdcard1 mounting point regardless of that mounted by system. Just like it is provided for alien dalvik.
Just had to install a new Phone as I broke my Xperia 10 and now the user is renamed which broke restoring backups and the SD card isn’t mounted so that I and at least one app can find it.
Ok, I found it as I know my way around Linux but first time in the “File Browser” I searched a little until I swiped left and discovered it in “Places” “Storage devices”.
Too bad that ownKeepass can’t find the SD card. I guess, have to write a udev rule to fix this.
@jolla this wasn’t the experience I expected after smooth sailing on the 2 previous Phones!
