Why is this issue no longer listed under known issues for XA2? (it was previously tracked and incorrectly states as fixed in a TJC release notes):
Title of a page now seems forced white when an attachedPage exists?
Iām afraid the fix didnāt make it in in time for this release, but should be there for the next.
Hello,
I need help. Update went smoothly. But after update I am not able to open the core apps any more (Browser, Galery, Phone, Contacts, Mail). At first startup, they asked for permission. I accepted - the app closed. Now non of the apps does open. However, I tried to open the browser by terminal and it works immediately.
What I already tried: Reboot, Open Accounts, and start sync., Reboot
Edit: Opening Contacts app by terminal does not show any contacts
I have a dual sim XA2. On 3.4, the mobile icons (1 and 2) on top right of the home screen had different colors, and the mobile internet connection icon had the same color as the default sim for internet. So by looking at the icon color you knew if SIM1 or SIM2 was active for mobile internet.
Now on 4.0.1, all these icons are white, so you canāt decide by the icon color which sim is used for mobile internet.
Is there any setting to bring back the old behavior?
āWaiting for connectionā¦ā The first trials didnāt work, now update process waits for a connectionā¦I am looking forward to all the new features!
My experience so far:
Is Patchmanager broken? I canāt apply any patches nor can I access the Web catalog. Is this a permissions thing?
I also found that my SDCard is no longer auto-mounting (having previously followed the guide on TJC). I havenāt got the time to see if I can redo the procedure to see if itāll work today, but if anyone else does, can they report back if it works or not. So if you have a long password, Iād suggest you temporarily copy it to notes or in a file NOT on you sdcard to facilitate easier unlocking eg. after an emergency reboot.
SailfishConnect, which needs to be uninstalled before an update, has a missing dependency - libcontextkit-statefs-qt5.so
The problem with not showing contacts, happens to me too. A strang thing was, that the history was also empty.
But after a reboot the contacts and history is back.
Cannot seem to connect with my XMPP account anymore. Telepathy Gabble/Wocky tries to use TLSv1 (and enforce that now it seems) which fails with most modern servers that require TLSv1.2+.
See also: Missing support for TLS1.3
and āArchiveā option instead of āDeleteā in the email client would also be wonderful!
Since failed update, the update hangs with āwaiting for connectionā in the settings page. Is the server overloaded, or is it a problem of the failed update?
A reboot didnāt help in my case. All Core apps have now permissions to use other apps/data - but still, the apps wonāt open and if opened via terminal, the have not data (e.g. contacts). Using my backup data didnāt help. Also deleting/reactivating the google account didnāt help. This sucks.
Tapping on adress in contact details, ther is no option to āshow on mapā.
Only the statusbar shows āthis action is currently unavailableā.
Is there a way to send the adress to a map-app?
Enable Do Not Disturb mode to turn off notification sounds and vibrator feedback
Address books support developed for contacts
Yess!
- Keyboard colours now follow the application theming (apps can override the ambience style)
Do we have control over this ? I really like the unified look given by ambiences.
I also have hard time dealing with some colors and the way ambiences works now have greatly improved my life by allowing me to remove them from the main interface.
Overall very positive upgrade experience (XA2 Dual Sim).
The update went through flawlessly. Had a few hiccups with contacts that were not showing up and calendar events. Easily resolved by making sure that I give permissions to the Contacts app and also go to all the Accounts and do a re-sync to bring all the calendar events and cloud contacts. Rebooted a couple of times in between and contacts appear normally. Also the call log got populated with the names instead of just showing numbers once the contacts loaded and I rebooted. Very happy, seems like a solid release and much better experience compared to the 3.4 update.
Another nice touch was the warning to uninstall some apps from OpenRepos (Contrac and System Monitor in my case) before starting the update - itās good to see Jolla listening to the community requests
Interesting UI changes, not sure if I like all of them but I am happy to see changes/experimenting/evolution.
Keep up the great work! Looking forward to new hardware support
PS: Seems that the battery life returned back to the previous levels, I am at 49% after 24hrs since last charge with the same use pattern as with 3.x versions. 3.4 introduced some horrible battery drain which I never tracked down, resulting in the phone barely lasting for a day with a full chargeā¦
Issue with my XA2, single sim. After this screen:
After reboot I am stuck either on the Sony screen, or passing it, but then it stays black. Backlight turns on when pressing power, but thatās all. No SSH access.
Update failed on XA2. (Alien dalvik removed / storeman removed / all patches disabled)
Stuck while checking the device lock code.
Where and when to except v4 image to flash please ?
EDIT: never used Defender app
Are there plans to bring back bash at some point? Busyboxās ash is an inadequate replacement for bash in my opinion, as simple things like shopt are not present, nor arrays. Iām sure thereās a ton more, but those are the first two issues I ran into when running a bash script on Koli.
Thank you.
