Terminal does not seem to remember previous commands anymore.
Had the same. Since then I see only âwaiting for connectionâ, wenn triggering the update. I guess this error you show is maybe due to an incomplete download.
gPodder has some UI bugs, hope to get to them soon.
Incidentally, this title is a little misleading. When I first read it, I thought âuh? Koli? Never heard of this app; what does it do?â.
Hmm, that text has been inherited from the times of Jolla Phone where there was often a lack of storage space. Downloading and processing an OS update of hundreds of megabytes requires some free space. âInternal storageâ referred to the storage inside the device, in contrast to external storage in a memory card. It is the time to reconsider that text.
Update went on my case fine yesterday on XA2 Dual-Sim. The phone was a bit sluggish first but it has settled down. Unfortunately Situations app doesnât recognize the phone screen state (on/off) correctly anymore
Great job though!
Update worked fine yet Android apps do not have internet connectivity with cellular network (3g/4g does not make any difference). When wlan is on Android apps work fine. Sony XA2 dual sim. I tried flight mode - does not help and reverting back to Android and then installing Sailfish seems a bit burdensome (and Iâd need to find a Windows computer first
) Solved: activated empty sim slot, deactivated the actual sim. Repeat the other way around and reboot = = > Android apps have connectivity in cellular network.
@oroesler thanks for the hint. That sounds very promising, however I didnât find any further info on that here in this forum nor on https://together.jolla.com. system_a is not a useful search term.
Do you have any link available? Could you expand on that?
Anyone else have issues with the browser since the update? I have installed a pretty hefty /etc/hosts on my phone to block unwanted cruft when browsing, since I cannot manage to install Privacy Badger, and since the update the browser is ignoring these entries.
This seems to be related to the new firejail setup (which is a really great idea, btw!). Iâve looked into it a bit and it looks like it should work. Browser process runs like this (according to ps)
/usr/bin/firejail --quiet --profile=/etc/sailjail/permissions/Base.permission --profile=/etc/sailjail/permissions/Mozilla.permission --profile=/etc/sailjail/permissions/Audio.permission --profile=/etc/sailjail/permissions/Location.permission --profile=/etc/sailjail/permissions/Internet.permission --profile=/etc/sailjail/permissions/Downloads.permission --profile=/etc/sailjail/permissions/Documents.permission --profile=/etc/sailjail/permissions/Pictures.permission --profile=/etc/sailjail/permissions/Videos.permission --profile=/etc/sailjail/permissions/Music.permission --profile=/etc/sailjail/permissions/Sharing.permission --profile=/etc/sailjail/permissions/sailfish-browser.profile --whitelist=/usr/share/sailfish-browser --whitelist=/usr/share/applications/sailfish-browser.desktop --whitelist=/home/nemo/.local/share/sailfish-browser --mkdir=${HOME}/.cache/org.sailfishos/browser --whitelist=${HOME}/.cache/org.sailfishos/browser --mkdir=${HOME}/.local/share/org.sailfishos/browser --whitelist=${HOME}/.local/share/org.sailfishos/browser --mkdir=${HOME}/.config/org.sailfishos/browser --whitelist=${HOME}/.config/org.sailfishos/browser --dbus-user=filter --dbus-user.own=org.sailfishos.browser --private-bin=sailfish-browser -- /usr/bin/sailfish-browser
The Internet.permission profile contains this entry:
private-etc ssl,hosts,pki,crypto-policies
Which, AFAICT, should copy the hosts file into the private jail. However, all the blocked entries (that are hardcoded to go to 0.0.0.0 in /etc/hosts) will now open in the browser. If I open the browser from the terminal without jailing it, this doesnât happen.
Update went smoothly on my XA2 plus Dual Sim.
I donât like at all the new notification UX: either on main screen and in the event view. I found managing notifications in event views more friendly before. Besides icons are ugly and again a step toward android.
Thank you for this update. It works well so far. I only had one problem: the update failed the first time I attempted to perform it, but worked flawlessly the second time. I particularly enjoy the firejail sandboxing integration. Notification actions are a very useful feature as well.
Xperia 10 updated and everything went smoothly. But Android support does not work anymore. If I open Settings => Android -Support => cannot Start/stop press buttons because they are disable. (phone is rebooted couple of times)
When trying to start Android app it will try to load it for a while and then it fails.
When I look journalctl it shows following entries:
helmi 05 11:49:27 Sailfish kernel: binder: 4617:4617 transaction failed 29189/-22, size 0-0 line 3024
helmi 05 11:49:28 Sailfish kernel: binder: 4617:4617 transaction failed 29189/-22, size 0-0 line 3024
Tried to uninstall/reinstall Android support but id did not change anything.
Edit: journalctl -xe output:
- Unit aliendalvik.service has failed.
â
â The result is RESULT.
helmi 05 11:56:12 Sailfish systemd[1]: selinux: Unknown class service
helmi 05 11:56:13 Sailfish apkd[4617]: Alien Dalvik is activating (auto-restart)
helmi 05 11:56:13 Sailfish kernel: binder: release 19897:20006 transaction 284151 in, still active
helmi 05 11:56:13 Sailfish droid-hal-init: Received control message âinterface_startâ for âandroid.hardware.radio.config@1.0::IRadioConfig/default_alienâ from pid: 2889 (/sy
stem/bin/hwservicemanager)
helmi 05 11:56:13 Sailfish droid-hal-init: Could not find service hosting interface android.hardware.radio.config@1.0::IRadioConfig/default_alien
helmi 05 11:56:13 Sailfish kernel: binder: send failed reply for transaction 284151 to 20026:20110
helmi 05 11:56:13 Sailfish logd: logdr: UID=1000 GID=1000 PID=935 n tail=127 logMask=19 pid=0 start=0ns timeout=0ns
helmi 05 11:56:13 Sailfish kernel: ptrace attach of âsystem_serverâ[21196] was attempted by âcrash_dump32 155 981 1â[21177]
helmi 05 11:56:14 Sailfish init: Untracked pid 986 exited with status 0
helmi 05 11:56:14 Sailfish init: Untracked pid 1005 exited with status 0
after that a lot of these:
helmi 05 11:56:15 Sailfish libprocessgroup: Error encountered killing process cgroup uid 1000 pid 41: No such file or directory
helmi 05 11:56:15 Sailfish init: Sending signal 9 to service âril-daemonâ (pid 40) process groupâŚ
helmi 05 11:56:15 Sailfish libprocessgroup: Failed to open process cgroup uid 1001 pid 40: No such file or directory
helmi 05 11:56:15 Sailfish libprocessgroup: Error encountered killing process cgroup uid 1001 pid 40: No such file or directory
finally:
helmi 05 11:56:16 Sailfish systemd[1]: aliendalvik.service: Service hold-off time over, scheduling restart.
helmi 05 11:56:16 Sailfish systemd[1]: aliendalvik.service: Start request repeated too quickly.
helmi 05 11:56:16 Sailfish systemd[1]: aliendalvik.service: Failed with result âexit-codeâ.
helmi 05 11:56:16 Sailfish apkd[4617]: Alien Dalvik is failed (failed)
Is that fix available as patch for users to try?
Itâs only just been merged in, but if it all goes through the checks okay Iâll see what I can do (Iâll post any further info here).
updated smoothly on x II. uninstalled flatpak support before.
okboard has an issue again, like in previous version.
android works for me, deezer starts
nice update !!
like it. browser is really smooth and quick. very happy so far
the remorse time was rewoked ! thanks !
Update went fine here on an XA2. Finally we got a working multiple address books support, thatâs really great \o/.
Had to uninstall sailfish connect before the update, as requested. Does anyone know why or what is blocking sailfish connect from working with SF4 ?
Did you try to install it back afterwards? I mean you could get information on what features are not working or is the app working at all. I had the same case with ChargeMonitor app which I tried to install back and noticed it didnât show any battery related values anymore, basically just a blank UI. Maybe it could be related to Sailfish Connect too?
thereâs a missing dependency when you try to install it after so I guess that must be the reason - libcontextkit-statefs-qt5.so
I succesfully updated my XA2 Ultra just now, but WhatsApp doesnât start, not even after removing and reinstalling. AlienDalvik is up to date, reboot doesnât help either. Anyone else with this quirk?
Edit: I started a separate thread for this issue: [4.0.1.45] WhatsApp doesnât start since it doesnât seem to be a common issue at all.
The whole android support does not start. reinstall from jolla store did not help. Settings -> android support shows the start button active and stop as disabled. Pressing start does nothing. WA tries to start but closes soon after.
This is on xperia X
