I was away from Salfish with my XperiaX. I installed Android on it. After 4 month I installed Sailfish again, and I am happy now. Everything works like it should. Android was good, but I like Sailfish is better on this phone. Good to be back. Thank you.
[UPDATE] Fixed by removing (or unmount it via Settings) SD card (looks like something wrong with binding of it to android).
Devs please have a look: https://forum.sailfishos.org/t/4-0-1-48-most-of-android-apps-stopped-working-after-update/5156/13
After upgrade on 4.0.1.49 almost all android apps not able to start or dies after any clicks.
Xperia XA2+ (no gapps, no openrepos apps, clean vanilla)
Seeing in logs of logcat:
03-01 10:23:58.506 E/Parcel ( 88): Attempt to read from protected data in Parcel 0xcf4f3d90
03-01 10:23:58.508 E/Parcel ( 88): Attempt to read from protected data in Parcel 0xdd65c628
03-01 10:23:58.509 E/Parcel ( 88): Attempt to read from protected data in Parcel 0xcf4f3d90
03-01 10:23:58.509 E/WificondChannelHelper( 88): Got zero length for all channel lists
03-01 10:23:58.510 E/WificondScannerImpl( 88): Failed to start scan because there is no available channel to scan
03-01 10:24:04.512 E/Parcel ( 88): Attempt to read from protected data in Parcel 0xcf4f3d90
03-01 10:24:04.520 I/chatty ( 88): uid=1000(system) WifiScanningSer identical 1 line
03-01 10:24:04.520 E/Parcel ( 88): Attempt to read from protected data in Parcel 0xcf4f3d90
03-01 10:24:04.520 E/WificondChannelHelper( 88): Got zero length for all channel lists
03-01 10:24:04.521 E/WificondScannerImpl( 88): Failed to start scan because there is no available channel to scan
03-01 10:24:04.572 I/SurfaceFlinger( 88): ALIEN: discarding frame without app/window (system process).
03-01 10:24:04.582 I/chatty ( 88): uid=1000(system) SFThread identical 1 line
03-01 10:24:04.598 I/SurfaceFlinger( 88): ALIEN: discarding frame without app/window (system process).
03-01 10:25:18.046 I/SurfaceFlinger( 88): ALIEN: discarding frame without app/window (system process).
03-01 10:25:26.956 E/storaged( 39): getDiskStats failed with result NOT_SUPPORTED and size 0
Wow wow!! Iâve just noticed that after more than 5 years, the sneak peek feature is back to its full potential!!
Peeking finally works again like in SFOS 1.0: the foreground app continues to run normally, i.e. the video youâre watching will continue to play in transparency while you check your notifications or the time
I donât see any mention of âpeekâ in the changelog so it was maybe done in 3.4 already, but thanks to whoever brought that back. Original report for posterity
Edit: confirmed with my Jolla 1 that it was already there is 3.4.
Hmm, no it is not missing. There is the button âClear learned wordsâ under the subheading of âText predictionâ.
Do you have âPredictive text inputâ installed (Jolla Store > My apps)?
Thanks @jovirkku! You are spot on. This package is not installed. Sorry for the noise.
Thanks. Please note that installing the predictive text input is somewhat peculiar: after installing it from Jolla Store you will need to restart the phone before that app is fully in effect.
I lost my ringtones and in setting -> System -> Sounds and Feeback -> Ringtone, the only option available is âno soundâ, which is annoying on a mobile phone.
Did anybody experience the same and or has an ideas how to fix this issue?
Xperia X dual SIM.
Twice after installing SFOS 4.0.1, I didnât see my contacts in the People app. It was a common situation, I am not aware of any special operations on the device before it happened. Restarting the device helped.
EDIT: I only use contacts on my device, I donât have any synced contacts from other accounts.
Hi
I am still using jolla tablet. And after updating to Sailfish 4.0.1.48
I found the wifi cannot connect automatically. Always needs to first forget and then connect again.
Sometimes even reconnect cannot find the any wifi.
Does anyone know the problem?
Yes.
Same experience on a X with 4.0.1.48.
( but as I am used to such behaviour like having to turn flight mode on/off after rebooting to get cellular services connected, I did not bother
I have the same problem. Can anyone help me please?
I only have this phone
Seems to work now:
I forced a reboot like it was described here: https://together.jolla.com/question/189442/sailfish-x-update-hangs/
and it booted to recovery first. Then I held the power button again and the phone booted into 4.0.1.48
I am happy!
Sorry I couldnt answer earlier. Yes, I re-booted, too, and it worked afterwards.
Iâm waiting for a connection for months.
I know, Iâm late to the party, but I finally upgraded to 4.1.0.48, too.
I had the same âconnectionâ issue as described at Update to Koli not working
No matter how many times I rebooted or did a pkcon refresh, the update from 3.4.0.24 could not be installed via the GUI.
Manually doing
ssu release 4.1.0.48
version --dup
just yielded
NO UPDATES FOUND. Try again later.
I therefore manually upgraded to 4.0.1.45:
ssu release 4.0.1.45
version --dup
reboot
and then the update to 4.1.0.48 also worked using the GUI.
[release notes] Koli 4.0.1 shows another approach which apparently also works.
Backup settings, do a factory reset, reboot, update and restore backup. That worked for me
bugged me as well , i got pass it by running
sudo zypper dup
afterthat one wierd thing:
installed aliendalvik is aliendalvik-1.1.0-1.13.1.jolla.armv7hl
when trying to reinstall via zypper install -f aliendalvik it tries to revert to aliendalvik-1.0.0-1.12.1.jolla.armv7hl as if the repository is broken
See [4.0.1] Voicemail notifications don't call voicemail when clicked - #8 by dcaliste I found a bug in the way the notification calls the dialer for the voicemail and also a bug when fetching the voicemail number. Hopefully this will solve this regression.
Maybe a little late here and I already published it on other threads, but here it is: Extend SailfishOS rootfs with a hidden, unused partition.-Oskar Roesler's Blog
Thatâs interesting,
How big is the space added, e.g. on an XA2?
