Thanks @cquence. Maybe it will end up being what Iām really looking for. I just installed Sailfish on my XA2 ultra two days ago, and for now I donāt want to pollute it with anything Android related.
I like your attitude @ebohoyod
Once I tried to do the same but not any more - it was just too much work. Now I have a Sailfish phone for daily use and an Android phone (pardon my Klatchian) that I use to run those Android applications that have none or not good enough native support.
I understand it perfectly. To be honest, I must say that my phone usage is very, very specific, in line with my idiosyncrasy, which I must also admit is very rare these days. So when I checked out all that Sailfish had to offer, I understood that it was made for me. Just to give an example:
Actually, installing Signal for me would be a frivolity these days. I use Telegram and, in fact, yesterday I installed the Android version, but I immediately uninstalled it, because its Sailfish client (Fernschreiber) meets my real needs with Telegram.
But yes, you are right. For most users, Android apps are still indispensable for the time being.
By the way, I also want to try Yottagram as a native Telegram client for Sailfish. But while I was now looking at the whisperfish case, I realize that I donāt know where to start with Openrepos. is there any basic tutorial for a newcomer like me? I donāt understand how I should install openrepos first, and from there on I canāt figure out anything either.
Itās a bit unfortunate to post this in the 4.0 thread, but Whisperfish is currently unable to register a new account on SailfishOS 4.0, due to [4.0.1.45] Regression in rendering of reCAPTCHA in sailfish-components-webview
So if you still havenāt updated to 4.0, please do register first on your 3.4 and then do the upgrade :ā-)
You can download the āStoremanā application from OpenRepos, installing it would be either in the terminal, or enabling āUntrusted softwareā will allow you to install the file within the Transfers section of the Settings, or in the file browsers. Since youāre likely using your phone, avoid anything relating to i486. The current version is meant for 3.4.0.24, but aside from a few bugs, will still run in 4.0.1.45/48.
Once itās installed, you need only select an app you wish to install, use the pulley to āadd repositoryā of the user who made the application, and then youāll be free to install the app. Adding a repository also makes many apps by that user available to download, and Storeman will monitor those repos when any updates come through. OpenRepos is generally used for software that Jolla canāt or wonāt support in the native store since it may not follow Jollaās store guidelines. Itās also a good venue for trying beta versions of programs that eventually end up on the store. As you mentioned Fernschreiber, beta versions end up on OpenRepos before they head to the store.
Certain applications cause problems when updating Sailfish, and some programs can break the OS altogether if they arenāt meant for that version. For that reason, OpenRepos and the Storeman app canāt be held responsible for anything that may break your system, or result in loss of data. Simply take precautions, check the descriptions and changelogs to make sure those programs have been updated or are working under your version of Sailfish.
Many thanks. After this explanation, it seems to me that I donāt need much more research
How do I check the Android version? Updated to 4.0.1.48, but Aida64 shows me Android 8.1 (Oreo) APK 27.
This is the old version
Donāt think there is anything broken in the applications themselves, but rather something to do with AlienDalvik. I had problems with Android apps altogether not being able to fetch new data from Internet after the phone transitioned out of the reach of WLAN into mobiledata (no problems with native apps). This regression started for me at some update 3.x (canāt remember witch, 3.1 or 3.2 probably).
I havenāt tested if it has been fixed already because since the problem appeared, I was too lazy not to reflash to see if it would fix this, I just used plain mobiledata until 4.0 update on my phone (yay for uncapped data subscriptions) and since 4.0 update I havenāt tested moving out of the reach of WLAN yet.
A very didactic, clear and concise video. I had not seen it yet (these days Iām watching some videos from your channel from my Freetube on my plasma desktop). I guess I havenāt come across it before because it was not among the most recent videos. I really appreciate your contribution.
During the video you say something about the convenience of installing Patchmanager. what is it really for?
Patchmanager is for patching the system for some UI changes (like bigger spacebar in the keyboard for example) and others.
I have the same problem with Bluetooth and XPERIA X (two devices(single and dual sim). It connects perfectly after restarting both devices. As soon as I disconnect once it is not possible to reconnect a Sennheiser MB Pro 2 headphone again. It started started after updating to 4.0.1.48. Never had that problem before.
@leszek Gotcha. An application with a ācosmeticā spirit. Thatās good to be aware of. I myself may, at a given moment, decide that a certain aesthetic modification on some application may be more functional. You never know.
Hey, Iāve waited for the official release to update my main phone⦠only to see that the reported issues were not fixed in 4.0.1.18
: Browser bookmarks are lost and Access Events when device is locked breaks the Quick Events access with an unlocked device.
What is the EA release for, if not to iron those kind of bugs?
The Quick Event access I can understand, itās a new feature letās just not enable it, but the bookmarks? By doing this, you are reminding 100% of your userbase that Sailfish is not yet for average users, as we need to come here and read the comments to know how to fix it
. Why isnāt it even mentioned in the known issues? Or am I one of the very few ones to have the issue (on two phones)?
Thereās a method to restore any lost bookmarks here:
I guess he knows that
but that is not his point.
Everyone, please, this post is about the OS release 4.0.1.48. Your comments should only be about observations on this release. If you want to write about 3rd party apps (be they Sailfish or Android), for instance, use the category Applications.
Letās keep the focus here on 4.0.1.48. Thank you!
(Yes, I know, the borderline is not always clear).
I super happily realized, that I can use my YubiKey with u2f in the Sailfish Browser by plugging it into the USB-C of my Xperia XA2. That is awsome!
(I used a YubiKey 5 in the USB-A variant with an adapter).
To keep to your observation, I would like to ask you a question:
I know itās not a priority issue, but why is it still impossible to implement external microphones, even with this update? Is it not even possible to record the audio of a video-blogging via USB-C instead of using jack?
That said, I really appreciate the work Jolla is doing with this OS. After a few days, I donāt regret abandoning Android
