I have tried multiple Sony 10 Phones. Both Sony 10 Xperia II & III with Sailfish OS 4.4.72.
I had tried multiple combination for MMS Settings and Data Settings.
I have even tried copying other Sony and US T-Mobile users setups that are successful in having MMS sending and receiving, Like this setting:
Connect name: T-mobile
Access point name: epc.tmobile.com
Protocol: Dual
Authentication: None
Proxy: 10.188.239.14
MMS message center address: http://10.188.239.145/mms/wapenc
Also on the same page, a 2nd user with successful MMS transmission:
MMS settings:
Epc.tmobile.com
Protocol: IPv6
Authentication: none
Clear out all proxy info. Leave blank
Same MMS message center you already used.
And on my Sony 10 Xperia II, follwed these suggested setup from here:
To get MMS working use the following:
**T-Mobile**
** MMS APN**
** Protocol: Dual (Important)**
** Proxy Address: 10.188.239.145**
** MMSC: http://10.188.239.145/mms/wapenc**
** Messages App → Settings → SMS Message Center Address: “+1206313004”,145**
** US Mobile**
** MMS APN**
** MMSC: http://10.188.239.159/mms/wapenc**
And for Red Pocket, too, I had tried these settings from the same page:
However, non of these setup works, even when I had to re-image Sony 10 Xperia II
Here are MMS logs from ‘mms-engine’:
Blockquote
022-10-16 10:21:56 [mms-engine] Version 1.0.78 starting
2022-10-16 10:21:56 [mms-engine] Attaching to system bus
2022-10-16 10:21:56 [dbusaccess] Parsing “1;group(privileged)=allow”
2022-10-16 10:21:56 [ofonoext] Bus connected
2022-10-16 10:21:56 [mms-engine] Bus acquired, starting…
2022-10-16 10:21:56 [ofonoext] Name ‘org.ofono’ is owned by :1.11
2022-10-16 10:21:56 [mms-engine] Acquired service name ‘org.nemomobile.MmsEngine’
2022-10-16 10:21:56 [ofonoext] Interface version 8
2022-10-16 10:21:56 [mms-ofono] Modem ‘/ril_0’
2022-10-16 10:21:56 [mms-connman-nemo] Default SIM at /ril_0
2022-10-16 10:21:57 [mms-ofono] Name ‘org.ofono’ is owned by :1.11
2022-10-16 10:21:57 [mms-ofono] 1 modem(s) found
2022-10-16 10:21:57 [mms-ofono] SIM ril_0 is present
2022-10-16 10:22:33 [dbusaccess] Parsing /proc/6441/status
2022-10-16 10:22:33 [mms-attachment] /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/encode/Archipelago_of_Turku.jpg: image/jpeg; name=Archipelago_of_Turku.jpg
2022-10-16 10:22:33 [mms-attachment] /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/encode/smil: application/smil; charset=utf-8; name=smil
2022-10-16 10:22:33 [mms-dispatcher] Encode[390] READY
2022-10-16 10:22:33 [mms-settings-dconf] Attaching to /imsi/310260544370145/mms/
2022-10-16 10:22:33 [mms-settings-dconf] max-message-size = 307200
2022-10-16 10:22:33 [mms-task-encode] Created /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.req (1032369 bytes)
2022-10-16 10:22:33 [mms-task-encode] Message is too big, need to resize
2022-10-16 10:22:33 [mms-task-encode] Resizing /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/encode/Archipelago_of_Turku.jpg
2022-10-16 10:22:33 [mms-attachment] Decoder-assisted resize (3072x2304 → 1536x1152)
2022-10-16 10:22:33 [mms-task] Encode[390] READY → WORKING
2022-10-16 10:22:33 [mms-attachment] Resized /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/encode/convert/Archipelago_of_Turku.jpg
2022-10-16 10:22:33 [mms-task-encode] Created /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.req (410703 bytes)
2022-10-16 10:22:33 [mms-attachment] Resizing (3072x2304 → 1024x768)
2022-10-16 10:22:33 [mms-task-encode] Created /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.req (201977 bytes)
2022-10-16 10:22:33 [mms-task] Encode[390] WORKING → DONE
2022-10-16 10:22:33 [mms-dispatcher] Encode[390] DONE
2022-10-16 10:22:33 [mms-dispatcher] Send[390] READY
2022-10-16 10:22:33 [mms-task] Send[390] READY → NEED_CONNECTION
2022-10-16 10:22:33 [mms-connection-nemo] MMS modem path /ril_0
2022-10-16 10:22:33 [mms-ofono] ril_0: not attached
2022-10-16 10:22:33 [mms-connection-nemo] MMS context /ril_0/context2
2022-10-16 10:22:33 [mms-connection-nemo] MessageProxy: 10.188.239.14:8080
2022-10-16 10:22:33 [mms-connection-nemo] MessageCenter: http://10.188.239.145/mms/wapenc
2022-10-16 10:22:33 [mms-connection-nemo] Activate /ril_0/context2
2022-10-16 10:22:33 [mms-ofono] Activating /ril_0/context2
2022-10-16 10:22:34 [mms-ofono] Settings.Interface: rmnet_data3
2022-10-16 10:22:34 [mms-ofono] Settings.Method: static
2022-10-16 10:22:34 [mms-ofono] Settings.Address: 29.58.23.40
2022-10-16 10:22:34 [mms-ofono] Settings.Netmask: 255.255.255.240
2022-10-16 10:22:34 [mms-ofono] Settings.Gateway: 29.58.23.41
2022-10-16 10:22:34 [mms-ofono] Settings.DomainNameServers: 10.177.0.34 10.177.0.210
2022-10-16 10:22:34 [mms-ofono] Interface: rmnet_data3
2022-10-16 10:22:34 [mms-connection-nemo] Interface: rmnet_data3
2022-10-16 10:22:34 [mms-ofono] IPv6.Settings.Interface: rmnet_data3
2022-10-16 10:22:34 [mms-ofono] Context /ril_0/context2 is active
2022-10-16 10:22:34 [mms-connection-nemo] Connection 310260544370145 opened
2022-10-16 10:22:34 [mms-dispatcher] 310260544370145 OPEN
2022-10-16 10:22:34 [mms-dispatcher] Send[390] NEED_CONNECTION
2022-10-16 10:22:34 [mms-task-http] MMS interface address 29.58.23.40
2022-10-16 10:22:34 [mms-task-http] MMS proxy 10.188.239.14:8080
2022-10-16 10:22:34 [mms-task-http] /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.req (201977 bytes) → http://10.188.239.145/mms/wapenc → /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.conf
2022-10-16 10:22:34 [mms-transfer-list] Transfer /msg/390/Send started
2022-10-16 10:22:34 [mms-task] Send[390] NEED_CONNECTION → TRANSMITTING
2022-10-16 10:22:34 [mms-ofono] Settings.Netmask: 255.255.255.255
2022-10-16 10:22:34 [mms-ofono] IPv6.Settings.Address: 2607:fb90:7829:b7e0:3ca0:cb90:f4f5:2187
2022-10-16 10:22:34 [mms-ofono] IPv6.Settings.Gateway: fe80:0000:0000:0000:c405:22d5:343c:f52c
2022-10-16 10:22:34 [mms-ofono] IPv6.Settings.PrefixLength: 64
2022-10-16 10:22:34 [mms-ofono] IPv6.Settings.DomainNameServers: fd00:976a:0000:0000:0000:0000:0000:0009 fd00:976a:0000:0000:0000:0000:0000:0010
2022-10-16 10:22:41 [mms-task-http] HTTP status 7 (Connection terminated unexpectedly)
2022-10-16 10:22:41 [mms-task] Send[390] TRANSMITTING → SLEEP
2022-10-16 10:22:41 [mms-transfer-list] Transfer /msg/390/Send finished
2022-10-16 10:22:51 [mms-connection-nemo] Deactivate /ril_0/context2
2022-10-16 10:22:51 [mms-ofono] Deactivating /ril_0/context2
2022-10-16 10:22:51 [mms-ofono] IPv6.Settings.PrefixLength: 0
2022-10-16 10:22:51 [mms-ofono] Interface:
2022-10-16 10:22:51 [mms-ofono] Context /ril_0/context2 is not active
2022-10-16 10:22:51 [mms-dispatcher] 310260544370145 CLOSED
2022-10-16 10:22:51 [mms-connection-nemo] Released /ril_0
2022-10-16 10:22:56 [mms-task] Send[390] SLEEP → READY
2022-10-16 10:22:56 [mms-dispatcher] Send[390] READY
2022-10-16 10:22:56 [mms-task] Send[390] READY → NEED_CONNECTION
2022-10-16 10:22:56 [mms-connection-nemo] MMS modem path /ril_0
2022-10-16 10:22:56 [mms-connection-nemo] MMS context /ril_0/context2
2022-10-16 10:22:56 [mms-connection-nemo] MessageProxy: 10.188.239.14:8080
2022-10-16 10:22:56 [mms-connection-nemo] MessageCenter: http://10.188.239.145/mms/wapenc
2022-10-16 10:22:56 [mms-connection-nemo] Activate /ril_0/context2
2022-10-16 10:22:56 [mms-ofono] Activating /ril_0/context2
2022-10-16 10:22:57 [mms-ofono] Settings.Interface: rmnet_data1
2022-10-16 10:22:57 [mms-ofono] Settings.Method: static
2022-10-16 10:22:57 [mms-ofono] Settings.Address: 21.171.203.145
2022-10-16 10:22:57 [mms-ofono] Settings.Netmask: 255.255.255.252
2022-10-16 10:22:57 [mms-ofono] Settings.Gateway: 21.171.203.146
2022-10-16 10:22:57 [mms-ofono] Settings.DomainNameServers: 10.177.0.34 10.177.0.210
2022-10-16 10:22:57 [mms-ofono] Interface: rmnet_data1
2022-10-16 10:22:57 [mms-connection-nemo] Interface: rmnet_data1
2022-10-16 10:22:57 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2022-10-16 10:22:57 [mms-ofono] Context /ril_0/context2 is active
2022-10-16 10:22:57 [mms-connection-nemo] Connection 310260544370145 opened
2022-10-16 10:22:57 [mms-dispatcher] 310260544370145 OPEN
2022-10-16 10:22:57 [mms-dispatcher] Send[390] NEED_CONNECTION
2022-10-16 10:22:57 [mms-task-http] MMS interface address 21.171.203.145
2022-10-16 10:22:57 [mms-task-http] MMS proxy 10.188.239.14:8080
2022-10-16 10:22:57 [mms-task-http] /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.req (201977 bytes) → http://10.188.239.145/mms/wapenc → /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.conf
2022-10-16 10:22:57 [mms-transfer-list] Transfer /msg/390/Send started
2022-10-16 10:22:57 [mms-task] Send[390] NEED_CONNECTION → TRANSMITTING
2022-10-16 10:22:57 [mms-ofono] Settings.Netmask: 255.255.255.255
2022-10-16 10:22:57 [mms-ofono] IPv6.Settings.Address: 2607:fb90:82ab:8c30:7115:6f1b:4bf1:d2d9
2022-10-16 10:22:57 [mms-ofono] IPv6.Settings.Gateway: fe80:0000:0000:0000:5499:d3dd:e9b9:dbc9
2022-10-16 10:22:57 [mms-ofono] IPv6.Settings.PrefixLength: 64
2022-10-16 10:22:57 [mms-ofono] IPv6.Settings.DomainNameServers: fd00:976a:0000:0000:0000:0000:0000:0009 fd00:976a:0000:0000:0000:0000:0000:0010
2022-10-16 10:23:03 [dbusaccess] Name ‘:1.104’ timed out
2022-10-16 10:23:04 [mms-task-http] HTTP status 7 (Connection terminated unexpectedly)
2022-10-16 10:23:04 [mms-task] Send[390] TRANSMITTING → SLEEP
2022-10-16 10:23:04 [mms-transfer-list] Transfer /msg/390/Send finished
2022-10-16 10:23:14 [mms-connection-nemo] Deactivate /ril_0/context2
2022-10-16 10:23:14 [mms-ofono] Deactivating /ril_0/context2
2022-10-16 10:23:14 [mms-ofono] IPv6.Settings.PrefixLength: 0
2022-10-16 10:23:14 [mms-ofono] Interface:
2022-10-16 10:23:14 [mms-ofono] Context /ril_0/context2 is not active
2022-10-16 10:23:14 [mms-dispatcher] 310260544370145 CLOSED
2022-10-16 10:23:14 [mms-connection-nemo] Released /ril_0
2022-10-16 10:23:19 [mms-task] Send[390] SLEEP → READY
2022-10-16 10:23:19 [mms-dispatcher] Send[390] READY
2022-10-16 10:23:19 [mms-task] Send[390] READY → NEED_CONNECTION
2022-10-16 10:23:19 [mms-connection-nemo] MMS modem path /ril_0
2022-10-16 10:23:19 [mms-connection-nemo] MMS context /ril_0/context2
2022-10-16 10:23:19 [mms-connection-nemo] MessageProxy: 10.188.239.14:8080
2022-10-16 10:23:19 [mms-connection-nemo] MessageCenter: http://10.188.239.145/mms/wapenc
2022-10-16 10:23:19 [mms-connection-nemo] Activate /ril_0/context2
2022-10-16 10:23:19 [mms-ofono] Activating /ril_0/context2
2022-10-16 10:23:20 [mms-ofono] Settings.Interface: rmnet_data3
2022-10-16 10:23:20 [mms-ofono] Settings.Method: static
2022-10-16 10:23:20 [mms-ofono] Settings.Address: 21.171.203.145
2022-10-16 10:23:20 [mms-ofono] Settings.Netmask: 255.255.255.252
2022-10-16 10:23:20 [mms-ofono] Settings.Gateway: 21.171.203.146
2022-10-16 10:23:20 [mms-ofono] Settings.DomainNameServers: 10.177.0.34 10.177.0.210
2022-10-16 10:23:20 [mms-ofono] Interface: rmnet_data3
2022-10-16 10:23:20 [mms-connection-nemo] Interface: rmnet_data3
2022-10-16 10:23:20 [mms-ofono] IPv6.Settings.Interface: rmnet_data3
2022-10-16 10:23:20 [mms-ofono] Context /ril_0/context2 is active
2022-10-16 10:23:20 [mms-connection-nemo] Connection 310260544370145 opened
2022-10-16 10:23:20 [mms-dispatcher] 310260544370145 OPEN
2022-10-16 10:23:20 [mms-dispatcher] Send[390] NEED_CONNECTION
2022-10-16 10:23:20 [mms-task-http] MMS interface address 21.171.203.145
2022-10-16 10:23:20 [mms-task-http] MMS proxy 10.188.239.14:8080
2022-10-16 10:23:20 [mms-task-http] /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.req (201977 bytes) → http://10.188.239.145/mms/wapenc → /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.conf
2022-10-16 10:23:20 [mms-transfer-list] Transfer /msg/390/Send started
2022-10-16 10:23:20 [mms-task] Send[390] NEED_CONNECTION → TRANSMITTING
2022-10-16 10:23:20 [mms-ofono] Settings.Netmask: 255.255.255.255
2022-10-16 10:23:20 [mms-ofono] IPv6.Settings.Address: 2607:fb90:82bc:8c94:3ca0:cb90:f4f5:2187
2022-10-16 10:23:20 [mms-ofono] IPv6.Settings.Gateway: fe80:0000:0000:0000:8511:57e8:5315:6156
2022-10-16 10:23:20 [mms-ofono] IPv6.Settings.PrefixLength: 64
2022-10-16 10:23:20 [mms-ofono] IPv6.Settings.DomainNameServers: fd00:976a:0000:0000:0000:0000:0000:0009 fd00:976a:0000:0000:0000:0000:0000:0010
2022-10-16 10:23:27 [mms-task-http] HTTP status 7 (Connection terminated unexpectedly)
2022-10-16 10:23:27 [mms-task] Send[390] TRANSMITTING → SLEEP
2022-10-16 10:23:27 [mms-transfer-list] Transfer /msg/390/Send finished
2022-10-16 10:23:37 [mms-connection-nemo] Deactivate /ril_0/context2
2022-10-16 10:23:37 [mms-ofono] Deactivating /ril_0/context2
2022-10-16 10:23:37 [mms-ofono] IPv6.Settings.PrefixLength: 0
2022-10-16 10:23:37 [mms-ofono] Interface:
2022-10-16 10:23:37 [mms-ofono] Context /ril_0/context2 is not active
2022-10-16 10:23:37 [mms-dispatcher] 310260544370145 CLOSED
2022-10-16 10:23:37 [mms-connection-nemo] Released /ril_0
2022-10-16 10:23:42 [mms-task] Send[390] SLEEP → READY
2022-10-16 10:23:42 [mms-dispatcher] Send[390] READY
2022-10-16 10:23:42 [mms-task] Send[390] READY → NEED_CONNECTION
2022-10-16 10:23:42 [mms-connection-nemo] MMS modem path /ril_0
2022-10-16 10:23:42 [mms-connection-nemo] MMS context /ril_0/context2
2022-10-16 10:23:42 [mms-connection-nemo] MessageProxy: 10.188.239.14:8080
2022-10-16 10:23:42 [mms-connection-nemo] MessageCenter: http://10.188.239.145/mms/wapenc
2022-10-16 10:23:42 [mms-connection-nemo] Activate /ril_0/context2
2022-10-16 10:23:42 [mms-ofono] Activating /ril_0/context2
2022-10-16 10:23:43 [mms-ofono] Settings.Interface: rmnet_data1
2022-10-16 10:23:43 [mms-ofono] Settings.Method: static
2022-10-16 10:23:43 [mms-ofono] Settings.Address: 21.171.203.145
2022-10-16 10:23:43 [mms-ofono] Settings.Netmask: 255.255.255.252
2022-10-16 10:23:43 [mms-ofono] Settings.Gateway: 21.171.203.146
2022-10-16 10:23:43 [mms-ofono] Settings.DomainNameServers: 10.177.0.34 10.177.0.210
2022-10-16 10:23:43 [mms-ofono] Interface: rmnet_data1
2022-10-16 10:23:43 [mms-connection-nemo] Interface: rmnet_data1
2022-10-16 10:23:43 [mms-ofono] IPv6.Settings.Interface: rmnet_data1
2022-10-16 10:23:43 [mms-ofono] Context /ril_0/context2 is active
2022-10-16 10:23:43 [mms-connection-nemo] Connection 310260544370145 opened
2022-10-16 10:23:43 [mms-dispatcher] 310260544370145 OPEN
2022-10-16 10:23:43 [mms-dispatcher] Send[390] NEED_CONNECTION
2022-10-16 10:23:43 [mms-task-http] MMS interface address 21.171.203.145
2022-10-16 10:23:43 [mms-task-http] MMS proxy 10.188.239.14:8080
2022-10-16 10:23:43 [mms-task-http] /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.req (201977 bytes) → http://10.188.239.145/mms/wapenc → /tmp/mms_Cnx4Ym/mms2022-10-16T102156/msg/390/m-send.conf
2022-10-16 10:23:43 [mms-transfer-list] Transfer /msg/390/Send started
2022-10-16 10:23:43 [mms-task] Send[390] NEED_CONNECTION → TRANSMITTING
2022-10-16 10:23:43 [mms-ofono] Settings.Netmask: 255.255.255.255
2022-10-16 10:23:43 [mms-ofono] IPv6.Settings.Address: 2607:fb90:82bf:639c:7115:6f1b:4bf1:d2d9
2022-10-16 10:23:43 [mms-ofono] IPv6.Settings.Gateway: fe80:0000:0000:0000:f8dd:5675:8f86:6437
2022-10-16 10:23:43 [mms-ofono] IPv6.Settings.PrefixLength: 64
2022-10-16 10:23:43 [mms-ofono] IPv6.Settings.DomainNameServers: fd00:976a:0000:0000:0000:0000:0000:0009 fd00:976a:0000:0000:0000:0000:0000:0010
2022-10-16 10:23:50 [mms-task-http] HTTP status 7 (Connection terminated unexpectedly)
2022-10-16 10:23:50 [mms-task] Send[390] TRANSMITTING → SLEEP
2022-10-16 10:23:50 [mms-transfer-list] Transfer /msg/390/Send finished
2022-10-16 10:24:00 [mms-connection-nemo] Deactivate /ril_0/context2
2022-10-16 10:24:00 [mms-ofono] Deactivating /ril_0/context2
Blockquote
If more information is needed, or logs, I am more than happy to work with one of SailfishOS engineers.
Thank you
