Bugs and issues of Android apps
REPRODUCIBILITY:
OS VERSION: 5.2
HARDWARE:Jolla Phone 2026
UI LANGUAGE: Finnish
REGRESSION:
Multible bugs and issues on Android.
Multible apps wont work because of cant set “Set screen lock on an Android device”. Example Danske Bank ID wont work since you cant set password to Android, Authenticator for Microsoft wont work if company has this setting on. These are important apps for workers.
  • Most of the new Google apps wont work or launch at all. Google maps, Google Photos, but older apps work like Google Tv.
  • Fingerprint reader not implemented on Android?
  • F-secure app works, but VPN doesnt work on Android?
  • Teams work, but cant make calls? Audio doesnt work when i make a call?-
  • Whatsapp has issue getting backup file
Imagine if everyone named their threads “Bugs and issues”. Also imagine if people just filled in what they felt like in the bug report template, and put a gazillion topics in one topic(thread).
Now also imagine if they didn’t search first to find what was already reported, known limitations and so on.
I wonder how they think such a thread will do any good at all.
Re Android PIN Android app requiring lock pin
wow - you were really really restrained this time ! :slight_smile:
about your Danske Bank issue ID issue, you can set an Android PIN by going to: Settings → Android AppSupport → press on “Android version” 5 times → Security → Screen lock. The PIN will only be seen by Android apps, it won’t affect the Sailfish lockscreen. (only available on 5.2/JP26, for older versions you need to install this 3rd-party pkg to get this workaround to work)
Google maps is a known issue and is being worked one, dont know about other Google apps (not sure why use them)
currently Fingerprint reader isnt working for Android apps. there is hope that will change someday in the future
about Teams issues, no idea…F-secure why do you use it on SailfishOS? for VPN sailfishOS has its own native connection settings
WhatsApp has always kinda sucked when it comes to backups, even on Android and even more so when you change platforms (mainly Android < → iOS).
For me, it only worked if I logged into my Gmail account for the first time during the setup to pull the backup. For some reason, it didn’t like it when I tried picking a pre-logged-in account in microG.
Regarding Google apps: first of all you need to have microG installed. How to do that is described beautifully in this thread by flypig. With the latest microG 0.3.15.40226 at the time of writing,
  • Maps I had to re-install from Aurora Store, then it would display a map.
  • Photos took a minute to load a gallery. I did not test the backup feature because I use Immich for that.
  • TV installed but I could not play purchased movies. This is because AppSupport does not ship with Widevine DRM. There were attempts to get DRM working inside a Arch Linux Container, with no success so far.
In SFOS 5.2 MicroG can be installed through Jolla Store.
Regarding F-Secure VPN: Android apps cannot route the traffic of the whole device, as they run in a container. To use a VPN, you need its OpenVPN or WireGuard config files and set it up through Settings. F-Secure VPN does not provide such config files, as such it cannot be used on Sailfish OS.
that’s great! makes it a lot easier
Regarding WhatsApp: if you switch from a regular Android phone, you best bet is to use the method described by ahjolinna, that is restoring a Google Drive backup from a Google account that you added to microG through WhatsApp.
In the future, should you want to switch to another Sailfish OS device or to / from a rooted Android device, a reliable method is to copy the media and private data folders. These are stored in the following locations:
Android Sailfish OS
media /storage/emulated/0/Android/media/com.whatsapp/ /home/defaultuser/android_storage/Android/media/com.whatsapp/
private data /data/data/com.whatsapp/ /home/.appsupport/instance/defaultuser/data/data/com.whatsapp/
You can tar -cf them when WhatsApp / AppSupport is fully stopped. Once you copied the tar files over to the new phone, where WhatsApp has been installed and opened once, note the ownership of the com.whatsapp folders (stat com.whatsapp/). This has been 510059:501023 for my media and 510059:510059 for my private data, it will be different for you. Delete the folders already there, tar -xf in the respective locations and change the ownerships (chown -R 510059:510059 com.whatsapp). WhatsApp should then open, magically set up just like on the old device.
swap-indiana-jones
Imagine if there simply was a popup when starting a thread: please search before you post. Imagine if Jolla honestly and clearly would state limitations of appsupport and under each supported model known issues. Let’s face it, their websites are a mess.
Imagine how bored you would be when there would be no one filling the forum with unnecessary threads, simultaneously filling the universe and making holes to space-time-continium.
It isn’t that serios and if its, we need to find more constructive way to adress it.
The other “Regulars” and i have actually put together a FAQ that we are hoping to get made public and pinned.
Until then i guess the community will have to keep asking people to turn their brain on and consider what they are actually achieving. How hard is it to consider that SFOS AAS will be sort of like a de-googled Android distribution with a bit of less deep integration?
While information always can be better; no limitation list can ever be complete. Someone will always come up with a new app that is “the most important in the world”.
I’m pretty sure that exists. People just don’t give a crap.
On the New Jolla that 3rd party app doesnt install and doesnt give any error code. F-secure i use for password manager.
when i do this i am in the same endless loop maybe i miss the packages as well (running new jolla with sfos 5.2 and latest and greatest app support)
Cant set password even if i set Android to developer mode
it seems the feature isnt fully implemented yet. Then again 5.2 is a early preview build for JP26 so issues where expected, just have to wait for next update and see if it has been resolved by then.
FuseDaemon: Rejected access to app-private dir on FUSE: /storage/emulated/0/Android/data/cn.com.broadlink.econtrol.international from uid: 10071
Any clue anybody? It used to be working in C2 and now it is not in Jphone2026
What versions of google maps and photos did you get to work? When I try Photos/Maps/Drive they all start to launch but fail.
The app data dir likely has rwxrwx— permissions so the normal defaultuser cannot read it.
What you need in that case is the devel-su root access (Settings > Developer tools) and if you want to explore the files graphically, Root mode for File Browser
Thanks for the suggestion but it didn’t work. I guess that the error from the log is more likely to be a symptom of some other issue … It is a remote control app from Broadlink and it used to work ok on the C2 with 5.1 latest branch
