Do note that UID and GID can be different as they depend on instalation order.
Android AppSupport → press on “Android version” 5 times → Security → Screen lock.
This does not work with 5.2.0.17.
It does not take the pin over.
It still shows “! Device unlock“ with “none“.
Fresh received Jolla 2. Micro G installed.
Does somebody have an idea?
The issue makes apps failing that works for others…
The instructions work for the Jolla C2 running Pispala 5.1. In addition to download the patch, it is needed to authorise the installation of third party apps.
The pin currently doesn’t work hopefully they fix it with update soon
