Finger print passthrough
As a returning user after the N900 and N9 I wonder the following. As SF supports finger print unlocking and it has AAS, would it be possible to use finger print in AAS? Let’s say I have a banking app for which I have to supply username and password, the username and password are stored in a password vault and upon opening the banking application the credentials are prefilled after finger print scanning.
Did search the topic but could not find a similar request.
Then a second topic which I throw also here due to space saving. I know there is some kind of power saving when SF is idle e.g. let’s say screen off. Is this done by off-lining cpu cores or any other different way?
Fingerprint scanner passthrough is not yet implemented. It is one of many reasons I don’t use SFOS as daily driver anymore.
Hopefully, it will be implemented some day!
I just tried the two applications for electronic identification that I use on Xperia 10 II with SFOS, and none of them can use fingerprinting.
well it would be a nice to have I guess
Yes, but for me it is not a dealbreaker. I manage happily with my PIN-code.
It is technically possible, now with their new phone + AIDL direction makes it more likely than before because it’s cleaner and fits Jolla’s current HAL modernization efforts. However, it still requires meaningful engineering effort (especially building a proper bridge between the native sailfish-fpd and the Android biometric service inside the LXC container).
Adding another vote to support this request. This is imo a real quality of life feature that is lacking and would surely help adoption rates if implemented.
Writing here to express support too!
In the blog post Jolla asked us to use Github issues, and this surely qualifies for an entry: Issues · sailfishos/issue-tracker · GitHub
I’ve added it as an issue. Please vote it up!
There seems to be some progress in this regard: Commits · sailfishos/sailfish-secrets · GitHub
Uuuu, very nice to see!!
