REPRODUCIBILITY (% or how often): second time so far
HARDWARE (XA2, Xperia 10…): Xperia 10
UI LANGUAGE: Slovenian
REGRESSION: (compared to previous public release: Yes, No, ?): Yes (compared to v3)
Twice so far (first time was with 4.0.1.45) notification sounds stopped working - no alarm, no ringing, no SMS alert tone), in addition if I go to Settings → Sounds and try to change the volume there, the Settings app freezes for about a minute (this doesn’t happen if I use the buttons to change the volume, although volume changes have no effect – notification sounds aren’t played despite volume being at 100%)
Phonecalls work normally, and I can hear the other person without problems
Rebooting the phone seems to fix the problem
Unknown
Unknown
Sounds work
Sounds don’t work
