Since I can record with sailfish-recorder when a headset in plugged in the jack, I have tried to record with the jack plugged and without the jack plugged and compared the entries in the journal log.
In the case the jack is not plugged in, the kernel sends an error at some moment. It seems that it is a very low level problem: hardware adaptation problem due to a different SoC? If it is the case, I fear there is no solution to my problem.
Yeah Known issue but nothing happends. After newest update still the same on Xperia 10 III. Had it on XA2 too and it is the audio not the microphone. Try to play music and it is silent. Booting helps for awhile till next boot etc. Has to be software issue.
Went silent again and for sure everything is off even the microphone, got worse with he new uppdate. Earlier I had a working phone for days now it is everyday boot.
Obviously there is a hardware problem with my microphones.
With csd, when testing microphone, top microphone works but is recognised as below microphone while microphone recognised as top microphone doesn’t work.
I have found in pulseaudio config how to force top microphone as input for voice recorder but it does not work for voicecall since it uses port input_voicecall and I have not found how to force it to use top microphone.
I had a similar problem on my X10 III. Other couldn’t hear me, but I tested Sailfish Recorder and the microphone worked. I tested after with another contact and I couldn’t reproduce the issue.
EDIT: We found out that the internal loudspeaker of my interlocutor is defective.
since yesterday i have the same problem. nothing helps, no restarting of pulseaudio, no reboot. i installed alsa-utils to see if the microphone is muted or the volume is too low, but amixer and alsamixer say no such device, also on my peria 10 ii. but i don’t think this is the issue, because recording a video and saving it freezes the camera app
The same problem, the mic don’t work in calls, and don’t work in audio recorder app, but if i try to make a video whit the camera app the mic work, after that the mic work in audio recorder app, but if i try to make a call the mic dont work, and crash in audio recorder app too
