In the last couple of days i lost all audio functions on my 10III. No ringtone when receiving a call, no notification sounds, no audio during calls. Even audio playback with the media player doesn’t work. Audio tests in CSD are also silent.
I think I have the same issue. I was waiting to write a report because I’m out and about for a few days.
My experience is that everything works fine for a while, then somehow you realise situation has changed. I’m trying to understand if it’s a matter of time, or an action.
When it happened the first time I turned it off and on again. After the second time, I started counting the number of calls, and it seems it’s three or four (done and received). After the third time I tried to play some audio files both with the Media app and from within the File Browser and neither worked.
I also realised that when using the Media app, the songs are slowed down (one second lasts three), I dunno if the two things are related.
I’m sorry I can’t help any better but this is what I have done so far.
Yes, this is the same issue I have
I was thinking to reinstall the phone, have not heard others with exactly the same error description - until now, so I will not do it anyway, it will be waste of time.
I will try to see if the error occurs when 2 different process are using the sound, it not easy to figure it out, anyway it makes the phone more or less unusable.
Maybe someone is willing to try this, tested this for nearly 24 hours and audio was working fine.
Edit the files default.pa and arm_droid_default.pa(maybe default.pa is not needed). Both files can be found in /etc/pulse.
Search for the line ‘load-module module-suspend-on-idle timeout=1’ in arm_droid_default.pa and ‘load-module module-suspend-on-idle’ in default.pa. Put an asterisk in front of both lines to disable suspend on unused audio sinks.
I’ll report back if this worked out. So far it is looking good.
Since today I have had the same. I have the 10 III a week now. Missed calls because I didn’t hear them. Started searching for the loudest ringtones. Have ringtone volume at maximum.
