My goal was to speed up user interactions because I often felt SFOS as slow and delayed. So I had a look into the related .qml files and began to tweak the values of duration and interval commands.
Result is a long list of UI tweaks, described below, and device is much much faster now. It also affects page loading speed (browser), mail sync speed and GPS duration to position fix.
Tweaks must be done from computer in cli as devel-su. The list contains all commands with absolute paths ready for c+p into the terminal window, including command lines for generating a backup before modifying and another line for undo / copy back if something goes wrong. Iām sure some paths to lib directory has to be changed to lib64 on 64 bit devices. (I still have my good old Xperia 10 in use)
I checked several weeks on my daily driver, and right now I checked again that the list is correct. The ācodeā below is intended to c+p into a text file, from there one can read it in a comfortable way and c+p to terminal on computer to ssh into the phone as devel-su and do the tweaks.
edit: 26.8.2024, 14:44 UTC updated the list below.
edit: 27.8.2024, 01:42 UTC added 3 missing files
edit: 27.8.2024, 16:48 UTC fixed typo for some values in
/usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml, now thatās really all that I have ATM.
edit: How to use:
Copy the content of the code window below to a text file by copy + paste.
Open the text file on computer in a text editor.
Enable developer mode on the phone
On computer, open a terminal and login to your phone by ssh or usb and become devel-su.
Then do for each file to tweak:
c+p and execute the first cp command into the terminal to create a backup copy of the original file.
edit the original file using the vi command.
If you make a mistake, quit editing without saving by [ESC] :q! command and start new.
If something doesnāt work, you can use the cp command below āUndo:ā It copys back the backup file to the original file name.
Donāt use the first cp command a second time, as it would destroy the original backup.
edit: cleaned up, removed everything from the list that has nothing to do with GUI speedup, will later repost the other tweaks in extra posts but not in such a long list. edit: The tweaklist is for SFOS 4.5.0.24 and tested only on this version. On other versions, line numbers may vary or things may not work.
edit 2.9.24: one value in TopMenuLayer.qml
edit 4.9.24: added a few forgotten files
Here it is:
Changed files X10 Backup
List of all tweaked files on X10 Daily Phone.
Tweaked Browser about-config is stored in
/home/defaultuser/.cache/org.saiilfishos/Settings/.mozilla/prefs.js
and
/home/defaultuser/.local/share/org.sailfishos/browser/.mozilla/prefs.js
Description:
xxx.bak is the backup copy of the original file.
Path is equal to path on phone.
List:
Keyboard Geometry
/usr/lib/maliit/plugins/jolla-keyboard.qml
ls /usr/lib/maliit/plugins/
cp /usr/lib/maliit/plugins/jolla-keyboard.qml /usr/lib/maliit/plugins/jolla-keyboard.qml.bak
vi /usr/lib/maliit/plugins/jolla-keyboard.qml
Undo:
cp /usr/lib/maliit/plugins/jolla-keyboard.qml.bak /usr/lib/maliit/plugins/jolla-keyboard.qml
632 duration: 75 // 300
654 PauseAnimation { duration: 50 } // 200
660 duration: 50 // 200
Reduce unnecessary delays - Make it faster:
Jolla-Notes:
ls /usr/share/jolla-notes/pages/
cp /usr/share/jolla-notes/pages/NotePage.qml /usr/share/jolla-notes/pages/NotePage.qml.bak
vi /usr/share/jolla-notes/pages/NotePage.qml
Undo:
cp /usr/share/jolla-notes/pages/NotePage.qml.bak /usr/share/jolla-notes/pages/NotePage.qml
190 duration: 120 // orig 200
278 duration: 120 // orig 200
cp /usr/share/jolla-notes/pages/OverviewPage.qml /usr/share/jolla-notes/pages/OverviewPage.qml.bak
vi /usr/share/jolla-notes/pages/OverviewPage.qml
Undo:
cp /usr/share/jolla-notes/pages/OverviewPage.qml.bak /usr/share/jolla-notes/pages/OverviewPage.qml
4 x duration 600 -> 100
135 PropertyAnimation { target: flashRect; property: "opacity"; to: Theme.opacityLow; duration: 100; easing.type: Easing.InOutQuad }
136 PropertyAnimation { target: flashRect; property: "opacity"; to: 0.01; duration: 100; easing.type: Easing.InOutQuad }
137 PropertyAnimation { target: flashRect; property: "opacity"; to: Theme.opacityLow; duration: 100; easing.type: Easing.InOutQuad }
138 PropertyAnimation { target: flashRect; property: "opacity"; to: 0.00; duration: 100; easing.type: Easing.InOutQuad }
/usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml
ls /usr/share/lipstick-jolla-home-qt5/backgrounds/
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml /usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml.bak /usr/share/lipstick-jolla-home-qt5/backgrounds/AmbienceBackgroundLoader.qml
55 duration: 100 // orig 800
Black background hack:
/usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml /usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml.bak /usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml
quick and easy test - open
/usr/share/lipstick-jolla-home-qt5/backgrounds/BlurredBackground.qml,
and in line 10, where it says ā0.65ā, change it to ā1āā¦
Thanks very much @Levone1
/usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml /usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml.bak /usr/share/lipstick-jolla-home-qt5/backgrounds/HomeWallpaperLoader.qml
39 duration: 100 // orig 800
Reduce unnecessary delays:
/usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml
ls /usr/share/lipstick-jolla-home-qt5/compositor/
cp /usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml /usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml.bak /usr/share/lipstick-jolla-home-qt5/compositor/ApplicationCloseGestureHint.qml
45 duration: 100 // orig 600
58 Behavior on opacity { FadeAnimator { duration: 100 } } // orig 600
71 Behavior on opacity { FadeAnimator { duration: 100 } } // orig 600
132 Behavior on opacity { FadeAnimator { duration: 100 } } // orig 600
/usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml
cp /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml.bak /usr/share/lipstick-jolla-home-qt5/compositor/Wallpaper.qml
52 transitionDelay: wallpaperItem.visible ? 100 : 0 // orig 200
85 duration: 100 // orig 200
95 Behavior on opacity { FadeAnimator { id: infoAnimation; duration: 100 } } // orig 300
/usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml
ls /usr/share/lipstick-jolla-home-qt5/launcher/
cp /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml.bak /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml
Line 48 highlightMoveDuration: 70 // orig 300 // Match velocity with EdgeLayer transition's 300ms (0.3s below) duration
Line 116: duration: 100 // orig 200 Test Mary 50
/usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml
cp /usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml /usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml.bak /usr/share/lipstick-jolla-home-qt5/launcher/LauncherFolder.qml
Line 39 Behavior on opacity { SmoothedAnimation { duration: 100; velocity: 1000 / duration } } // orig duration was 400, vel. no change
Line 256 Behavior on opacity { FadeAnimation { duration: 100 } } // orig 300
Line 279 Behavior on y { NumberAnimation { duration: 100; easing.type: Easing.InOutQuad } } // orig 300
Line 316 Behavior on opacity { FadeAnimation { duration: 100 } } // orig 300
/usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml
cp /usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml /usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml.bak /usr/share/lipstick-jolla-home-qt5/launcher/PinnedLauncherHint.qml
Line 35: Behavior on opacity { FadeAnimation { duration: 100 } } // orig 400
/usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml
ls /usr/share/lipstick-jolla-home-qt5/layers/
cp /usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml /usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/EdgeLayer.qml
in the middle, line 191 - 257, near transitions change all durations to abt. the half or 1/3 or 1/4.
199: 60 // orig 250
205: 60 // orig 250
220: 70 // orig 300
226: 70 // orig 300
245: 70 // orig 300
249: 70 // orig 2000
253: 70 // orig 300
------>> Match 70 from /usr/share/lipstick-jolla-home-qt5/launcher/Launcher.qml
systemctl --user restart lipstick
Remark: works good until now, looks good
/usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml
cp /usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml /usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/HomeLayer.qml
43 duration: 200
235 NumberAnimation { duration: 250; easing.type: Easing.OutQuad } // no change!
Remove annoying hints on unlock: (the same für Sony und Volla)
/usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml
cp /usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml /usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/LauncherLayer.qml
Change it at the end (Line 109) to say this:
edge: PeekFilter.Bottom
hintHeight: 0
hintDuration: 0
/usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml
cp /usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml /usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/NotificationOverviewLayer.qml
Line 26: NumberAnimation { duration: 400; easing.type: Easing.OutQuad } // obscure! no change
Line 42: duration: 70 // orig 200
Line 148: duration: 100 // orig 400
Line 149: velocity: 1000 / duration // orig 1000 no change, velocity will increase automatically if duration is shorter
cp /usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml /usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/PartnerLayer.qml
125 interval: 100 // orig 500
233 duration: 60 // orig 300
248 duration: 60 // orig 300
256 duration: 60 // orig 300
406 duration: 80 // orig 400
/usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml
cp /usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml /usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/StackLayer.qml
369 PauseAnimation { id: delayAnimation; duration: 150 } // orig 150, no change
383 delayAnimation.duration = 150 // orig 150, no change
393 duration: 100 // orig 300
/usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml
cp /usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml /usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml.bak /usr/share/lipstick-jolla-home-qt5/layers/TopMenuLayer.qml
30 hintDuration: 100 // orig 600 Test Mary 100 scheint zu gehen wart ma mal war 200 kann so bleiben
Remove 2 arrows:
/usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml
ls /usr/share/lipstick-jolla-home-qt5/lockscreen/
cp /usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml /usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml.bak /usr/share/lipstick-jolla-home-qt5/lockscreen/EdgeIndicator.qml
line: 27
source: "image://theme/graphics-edge-swipe-arrow"
change to
//source: "image://theme/graphics-edge-swipe-arrow"
Changing all 'duration:' parameters (e.g. 700 -> 35 ). changed to orig.value/20, eg. 700 -> 35
makes UI much faster. Valid only for this file + not for line 118 !
106 20 // orig 400
114 35 // orig 700
118 100 // orig 1500
132 20 // orig 400
137 20 // orig 400
148 20 // orig 400
160 20 // orig 400
Restart lipstick:
Many thanks to @Edz !
/usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml
ls /usr/share/lipstick-jolla-home-qt5/main/
cp /usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml /usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml.bak /usr/share/lipstick-jolla-home-qt5/main/OrientationTransition.qml
25 duration: 150 // orig 250
33 duration: 150 // orig 250
/usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml
cp /usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml /usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml.bak /usr/share/lipstick-jolla-home-qt5/main/PeekArea.qml
57 clipEndAnimation.duration = 200 // orig 600
92 SmoothedAnimation { id: opacityAnimation; duration: 100; velocity: 1000 / duration } // orig d=300, v=1000
152 clipEndAnimation.duration = 200 // orig 400
154 clipEndAnimation.duration = 100 // orig 200
164 clipEndAnimation.duration = 100 * (clipEndAnimation.to - peekFilter.absoluteProgress) / clipEndAnimation.to // orig 300
/usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml
ls /usr/share/lipstick-jolla-home-qt5/switcher/
cp /usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml /usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml.bak /usr/share/lipstick-jolla-home-qt5/switcher/CloseAllAppsHint.qml
14 interval: 100 // orig 500
27 Behavior on opacity { FadeAnimation { duration: 300 } } // orig 1000
/usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml
cp /usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml /usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml.bak /usr/share/lipstick-jolla-home-qt5/switcher/StartupWatcher.qml
14 interval: 30 // orig 2000, works fast 'n' good but screen flickers on app startup
/usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml
cp /usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml /usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml.bak /usr/share/lipstick-jolla-home-qt5/switcher/Switcher.qml
174 interval: 100 // no change
337 scrollAnimation.duration = 70 // orig 150
343 scrollAnimation.duration = 70 // was 150
359 scrollAnimation.duration = Math.abs(contentY - scrollAnimation.to) * 1.5 // try 1.1 or comment out (= * 1), check pull down menu!!
437 NumberAnimation { target: switcherItems; property: "opacity"; to: 0.0; duration: 200 } // no change
448 NumberAnimation { target: switcherItems; property: "opacity"; to: 1.0; duration: 200 } // no change
/usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml
cp /usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml /usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml.bak /usr/share/lipstick-jolla-home-qt5/switcher/SwitcherItem.qml
137 PauseAnimation { duration: 100 } // orig 200
140 duration: 200 // was 400
186 PauseAnimation { duration: 100 } // orig 250
192 FadeAnimation { id: coverOpacityAnimation; duration: 200 } // orig 500
203 Behavior on opacity { FadeAnimation { duration: 200 } } // orig 500
221 interval: coverHint && !coverId ? 2000 : 200 // orig 5000 : 500
238 ColorAnimation { duration: 100 }
243 NumberAnimation { duration: 50 }
424 duration: 100 // orig 200
430 duration: 100 // orig 200
435 PauseAnimation { duration: 100 } // orig 170 Test 90
506 duration: 100 // orig 200
/usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml
ls /usr/share/lipstick-jolla-home-qt5/system/
cp /usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml /usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml.bak /usr/share/lipstick-jolla-home-qt5/system/StartupScreenBlanker.qml
32 PauseAnimation { duration: 100 } // orig 400
/usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml
ls /usr/share/lipstick-jolla-home-qt5/systemwindow/
cp /usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml /usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml.bak /usr/share/lipstick-jolla-home-qt5/systemwindow/SystemWindow.qml
60 NumberAnimation { duration: 100; easing.type: Easing.InOutQuad } // orig 200
/usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml
ls /usr/share/lipstick-jolla-home-qt5/topmenu/
cp /usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml /usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml.bak /usr/share/lipstick-jolla-home-qt5/topmenu/AmbienceSelector.qml
73 NumberAnimation { property: "x"; duration: 100; easing.type: Easing.InOutQuad } // orig 500
205 NumberAnimation { properties: "y"; duration: 80 } // orig 200
/usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml
cp /usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml /usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml.bak /usr/share/lipstick-jolla-home-qt5/topmenu/TopMenu.qml
26 scrollAnimation.duration = Math.abs(contentY - scrollAnimation.to) // * 1.0 // orig 1.5, or simply comment out * 1.5 at the end Test 1.1 Mary
75 duration: 300 // no change
160 duration: 100 // orig 400
167 duration: 100 // orig 400
302 duration: Lipstick.compositor.powerKeyPressed ? scrollAnimation.duration : 80 // orig 200
429 duration: Lipstick.compositor.powerKeyPressed ? scrollAnimation.duration : 80 // orig 200
492 interval: 5000 // no change
/usr/share/lipstick-jolla-home-qt5/windowwrappers/InProcWindowWrapper.qml
ls /usr/share/lipstick-jolla-home-qt5/windowwrappers/
cp /usr/share/lipstick-jolla-home-qt5/windowwrappers/InProcWindowWrapper.qml /usr/share/lipstick-jolla-home-qt5/windowwrappers/InProcWindowWrapper.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/windowwrappers/InProcWindowWrapper.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/windowwrappers/InProcWindowWrapper.qml.bak /usr/share/lipstick-jolla-home-qt5/windowwrappers/InProcWindowWrapper.qml
nothing to do
/usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml
cp /usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml /usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml.bak /usr/share/lipstick-jolla-home-qt5/windowwrappers/WindowWrapper.qml
34 FadeAnimator { duration: 100 } // was 600
/usr/share/lipstick-jolla-home-qt5/compositor.qml
cp /usr/share/lipstick-jolla-home-qt5/compositor.qml /usr/share/lipstick-jolla-home-qt5/compositor.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/compositor.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/compositor.qml.bak /usr/share/lipstick-jolla-home-qt5/compositor.qml
677 Behavior on opacity { FadeAnimator { duration: 100; alwaysRunToEnd: false } } // was 300 & true
692 interval: 200 // was 500
814 extraGestureDuration: 500 // no change
1025 Behavior on foregroundItem.opacity { FadeAnimator { duration: 100; alwaysRunToEnd: false } } // was 300 & true das is irrt. noch auf 300 gestnden -> korr + check!
1032 interval: 1000 // was 2000
1228 duration: 100 // was 400
1688 interval: 2000 // no change
1892 interval: 1000 // no change
/usr/share/lipstick-jolla-home-qt5/main.qml
cp /usr/share/lipstick-jolla-home-qt5/main.qml /usr/share/lipstick-jolla-home-qt5/main.qml.bak
vi /usr/share/lipstick-jolla-home-qt5/main.qml
Undo:
cp /usr/share/lipstick-jolla-home-qt5/main.qml.bak /usr/share/lipstick-jolla-home-qt5/main.qml
106 interval: 1000 // no change
/usr/share/lipstick-obex-ui/main.qml
ls /usr/share/lipstick-obex-ui/
cp /usr/share/lipstick-obex-ui/main.qml /usr/share/lipstick-obex-ui/main.qml.bak
vi /usr/share/lipstick-obex-ui/main.qml
Undo:
cp /usr/share/lipstick-obex-ui/main.qml.bak /usr/share/lipstick-obex-ui/main.qml
50 interval: 200 // wait for window fade outs etc., was 400
/usr/share/lipstick-windowprompt/main.qml
ls /usr/share/lipstick-windowprompt/
cp /usr/share/lipstick-windowprompt/main.qml /usr/share/lipstick-windowprompt/main.qml.bak
vi /usr/share/lipstick-windowprompt/main.qml
Undo:
cp /usr/share/lipstick-windowprompt/main.qml.bak /usr/share/lipstick-windowprompt/main.qml
47 _showTimer = singleShot(400, function() { // no change
/usr/lib/qt5/qml/Sailfish/Silica/ :
Lazy Swipes:
/usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml
ls /usr/lib/qt5/qml/Sailfish/Silica/
cp /usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml /usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/SilicaFlickable.qml
Line 63: maximumFlickVelocity: 2000 // was Theme.maximumFlickVelocity
1500 also possible
--------------------------------------------- BEGIN of other List
now changed values are after the // and before is the original value.
research project:
/usr/lib/qt5/qml/Sailfish/Silica/*
/usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml /usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ApplicationWindow.qml
236-238 Timer... interval: 150 // was 600
256ff 2 x duration 100; // was 2 x 400 Take care of the ; after the number!
301 PauseAnimation { duration: 50 } // was 200
/usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml /usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml
Undo:
vi /usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/BusyLabel.qml
52 Behavior on opacity { FadeAnimator { duration: 100 } } // was 400
/usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml /usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/DatePickerDialog.qml
113 duration: 125 // was 500
120 duration: 125 // was 500
280 duration: 75 // was 300
287 duration: 75 // was 300
/usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml /usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/Drawer.qml
72 duration: 75 // was 300
137 duration: 75 // was 300
/usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSection.qml
58 readonly property int _animationDuration: _group ? _group.animationDuration : 50 // was 200
/usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ExpandingSectionGroup.qml
56 property int animationDuration: 50 // was 200
/usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimation.qml
37 duration: 50 // orig 200
/usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/FadeAnimator.qml
/usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml /usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/HorizontalScrollDecorator.qml
54 Behavior on opacity { FadeAnimation { duration: 100 } } // was 400
69 interval: 75 // orig 300
/usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml /usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ListItem.qml
97 duration: 50 // was 200
/usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml /usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/PageStack.qml
109 property int _transitionDuration: 100 // was 400
592 FadeAnimation { duration: 100 } // was 400
1279 duration: 25 // was 100
1355 pageFadeIn.duration = multiplier * (differentOrientation ? 63 : 100) // was 250 : 400 values should match line 1374 + line 592
1367 duration: 25 // was 100
1374 duration: 63 // was 250
1396 duration: 1000 // was 1500
/usr/lib/qt5/qml/Sailfish/Silica/plugins.qmltypes
cp /usr/lib/qt5/qml/Sailfish/Silica/plugins.qmltypes /usr/lib/qt5/qml/Sailfish/Silica/plugins.qmltypes.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/plugins.qmltypes
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/plugins.qmltypes.bak /usr/lib/qt5/qml/Sailfish/Silica/plugins.qmltypes
1160 "Short": 3000, // no change, check if this is a system wide time setting
1161 "Long": 5000 // no change, check if this is a system wide time setting
/usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml /usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/PulleyAnimationHint.qml
94 duration: 100*Math.max(1.0, pullDownDistance/Theme.itemSizeLarge) // orig 400
106 duration: 100 // Matches bounceback animation duration // orig 400
Undo:
63 maximumFlickVelocity: 2000 // was: Theme.maximumFlickVelocity
/usr/lib/qt5/qml/Sailfish/Silica/Switch.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/Switch.qml /usr/lib/qt5/qml/Sailfish/Silica/Switch.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/Switch.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/Switch.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/Switch.qml
105 interval: 125 // was 500
/usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml /usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/TapInteractionHint.qml
83 duration: 1500 // was 2000
/usr/lib/qt5/qml/Sailfish/Silica/TouchInteractionHint.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/TouchInteractionHint.qml /usr/lib/qt5/qml/Sailfish/Silica/TouchInteractionHint.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/TouchInteractionHint.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/TouchInteractionHint.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/TouchInteractionHint.qml
too complex for me...
/usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml /usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ValueButton.qml
52 property int _duration: 50 // was 200
/usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml /usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/ViewPlaceholder.qml
68 Behavior on opacity { FadeAnimation { duration: 75 } } // was 300
/usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml
ls /usr/lib/qt5/qml/Sailfish/Silica/private/
cp /usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml /usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/private/FastScrollAnimation.qml
Line 42: property real defaultDuration: 200 // orig 300 Test Mary 100
Line 115: velocity: 4000
Line 116: maximumEasingTime: 80 // orig 100
Line 122: velocity: 4000
Line 124: maximumEasingTime: 80 // orig 100
Line 161: PauseAnimation { duration: 80 } // orig 100
/usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml /usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/private/Slideable.qml
50 duration: 70 // orig 200
296 duration: 100 // orig 300
305 duration: 100 // orig 300
327 duration: 100 // orig 300
336 duration: 100 // orig 300
/usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml /usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/private/SliderBase.qml
91 duration: 100 // orig 200
100 duration: 100 // orig 100
/usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml
cp /usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml /usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml.bak
vi /usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml
Undo:
cp /usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml.bak /usr/lib/qt5/qml/Sailfish/Silica/private/ZoomableFlickable.qml
195 duration: 100 // orig 200
206 duration: 100 // orig 200
--------------------------------------------- END of other list
--------------------------------------------- eof
Enjoy!
