I’ve used Situations for a very simple sounds/silent switching so that I don’t get email blings in the middle of the night. However, after upgrading my Xperia 10 III to SFOS to 4.4.0.72 (Vanha Rauma) it seems Situations has issues restoring sounds in the morning.
When this happens, the only solution seems to be to restart the phone, running the Situations app thinks it has switched the sounds on but nothing changes. Has anyone else experienced issues like this?
What I was doing with Situations was just switching ring volume between 0% and 100%, the settings were showing 100% volume even though it was somehow on silent.
Certain things that used to work do not any more, or in a degraded way.
The developers (pastillilabs) are aware of these, but they are occupied with other changes of the app at the moment (it runs on onther OSes as well), and have told me it could be some time until they can revisit SFOS support.
Although actually, as an OpenRC user, I prefer /etc/local.d/*.start instead. And, to gain systemd-like service monitoring functionality, running monit from /etc/inittab. Which is an approach that predates systemd itself.
As a temporary workaround for this specific sounds/silent switching, you could create a new ambience with chosen sounds disabled, and then have Situations toggle ambience, instead of sounds, at given time.
I’m afraid that due to this bug (causing that sound settings from one ambience replace sound settings of the second one) it won’t work for too long, either.
Well, that bug never affected me. I have my day/night ambiences working perfect as allways. So, @ExTechOp might be one of the lucky ones that don’t get affected.
That’s very strange considering that it is present on both my 10 III and XA2. And it doesn’t take any effort to trigger it - as videos posted in the error report show, a simple change between two ambiences having different sounds is enough for sounds from one ambience to overwrite the other one. I had to stop using ambiences because of that.
It would be really interesting to know what may be causing that it so badly affects both phones of mine but not others… Do you have different sounds in those two ambiences set for calls, SMS or email and are you sure that after switching between them the sound settings of the second ambience don’t get replaced by sounds from the first one as shown in these videos? Stunning.
Call sound is the same in all my ambiences, the rest is different. Everything but call and alarm is set to “No sound” in my night ambience and I change between the night ambience and a couple of others every morning and night with no problem.
The only thing I can think of is that my ambiences is installed from a custom rpm every new system setup.
@eson, did you ever reboot the phone when the night ambience was active, and switched to the day ambience only after reboot? If not, please could you test it? I mean:
enable the ambience which has SMS and email sounds set to “No sound”
reboot the phone
after reboot switch to your day ambience which has SMS and email sounds enabled
now please check in Settings / Sounds and alerts if all sounds were correctly changed.
In my case, ringtone, SMS, email and alarm clock sounds remain unchanged (i.e. still “No sound” of the former ambience). And if I go to that second ambience settings, I can see only sounds for chat and calendar listed, all the remaining options (SMS, email, ringtone, alarm clock) are gone. It is 100% reproducible, 10/10. On both XA2 Ultra and 10 III. And it looks that I am not the only one as there is a bug report describing the same issue with alarm sound setting disappearing from ambience setting: Make alarm sound setting in Ambience persistent
