Many thanks to you our active contributors for your feedback and proposals.
Version history of the OS release
- 2024-10-24: OS version 5.0.0.21 “Tampella” was released for the Jolla C2 community phones as an over-the-air update.
PLEASE NOTE
The security code of Sailfish OS is a minimum of 5 digits or characters. It is used for the device lock and home area encryption and is set at the beginning of the first startup. If you decide to use an external keyboard at this point (it is not recommended), bear in mind that you do not set a code shorter than 5 characters.
New community phone Jolla C2
- Deliveries of the new Jolla C2 Community Phone started to the first batch of customers in October 2024
- Sailfish OS (5.0.0.5) was pre-installed on the Jolla C2 phones at the factory
- This OS update, 5.0.0.21, is intended for the C2 phones only. Other phones will get the Sailfish 5 later.
Release highlights
The list below contains the major improvements of 5.0.0.21, compared to the release installed on the phones.
- Browser engine upgraded to ESR91. Thank you ‘flypig’ and the Community contributors
- Home view, Events view, Alarm view (clock and calendar alarms), and Lock screen rotate to landscape (if enabled in “Settings > Display > Rotating homescreen”)
- All Jolla default apps rotate to landscape
- Blocking of incoming calls from preset numbers. Set them in call history, contact cards and Settings > Apps > Phone.
- UI translations updated
- Internet sharing (hotspot) fixed
- “2.0” Camera label replaced with “M” (for macro)
- New ambiences
- Handing touches at the right edge of landscape Fingerterm fixed.
Sailfish OS Forum: issues reported by the community fixed in this update
Technical changes
The detailed changelog is here.
Updating your device
By installing this update you accept the updated The Sailfish OS End User License Agreement.
The usual update process
Your device must be connected to the Internet and signed into your Jolla account.
Start the update from “Settings > Sailfish OS updates”. Avoid running updates on the command line, please.
We warmly recommend making some 3-4 GB of free space for your device’s internal storage ( /home ) before starting the update. Processing an OS update of almost 1 GB requires a good amount of work area. Move your pictures and videos to the SD card (or your PC or cloud service).
This is the usual drill before attempting to update your devices:
Back up your data before an attempt to update your device and save the backup to an SD card or some other off-device location (PC, your cloud service). Note that videos and images are not included in cloud-based backups. Do not reboot the device while the update is being processed. Do keep the phone connected to a battery charger during the whole process. The device screen may get blank during the update process; you may wake the display with a short power key press to monitor the progress.
For detailed instructions on updating software, read our help article in Sailfish OS Documentation.
NOTE 1:
Sailfish OS does not support downgrading. Never try to downgrade the OS as this would break your device.
NOTE 2:
After downloading an update and selecting “Install” in the pulley menu, the device runs a restart first. You will need to type the security code before the actual installation can start. A horizontal progress bar appears on a black background, under the Sailfish OS logo. When the other end of the bar has been reached the phone will restart automatically. If it doesn’t, please wait for 15 minutes. If it is still stuck at the 100% point of the progress bar it is time to perform forced power off . Next, turn the phone on with the power key and check the OS version at “Settings > About product”.
NOTE 3:
The Jolla Shop has the images of the latest OS release only. Keep the previously downloaded ones stored on your computer if you should want to reflash one of them later on.
Notification concerning apps from Open Repos
- Compatibility with the release 5.0.0 has not been verified yet. Early Access users, please report
Some apps from Open Repos have been reported to cause problems when installing OS updates. Read the recent comments on those apps.
- Call recorder has caused serious problems. We recommend uninstalling that app before the OS update. Read this comment, please.
Known issues
- VoLTE not yet included. Please disable 4g in mobile network settings to make calls work correctly.
How did the upgrade go?
- I had no issues during the upgrade process
- I had small issues but was able to handle them
- I got into serious trouble when upgrading my device (please help!)
- I did not dare or want to update
Help articles
The Sailfish OS help articles are available at Sailfish OS Documents repository.
