Jolla Phone does not support 5G for several providers in several countries
REPRODUCIBILITY: 100%
OS VERSION: 5.2
HARDWARE: Jolla 2026
UI LANGUAGE: English (UK)
REGRESSION: Been like this from the start
My existing Vodafone SIM card works with 5G on my previous phone (Sony Xperia IV running Android). In my Jolla 2026 phone however, I only get 4G; not 5G, even though I’ve set 5G preferred.
The same goes with my Odido SIM card: 5G on another (Android) phone, no 5G on my Jolla 2026 phone.
In short: Jolla 2026 phone does not appear to support 5G at all in the Netherlands, contrary to what its technical hardware specifications suggest.
Vodafone SIM with 5G subscription in the Netherlands. Validated to be working fine with previous phone (Sony Xperia IV running Android).
Odido SIM with 5G subscription in the Netherlands. Validated to be working fine with previous phone.
  1. Put Vodafone SIM or Odido SIM in Jolla 2026 phone
  2. Automatically select network, or ..
  3. .. manually select Vodafone NL or Odido
I expect the Jolla 2026 phone, which supports 5G according to specs, connects to the Vodafone or Odido 5G NL network.
The Jolla 2026 phone only shows Vodafone 4G NL or Odido with 4G. Speed tests show 4G speeds (less than 60Bmps).
Same for me on o2 in Germany. I really hope there will be a fix.
In Portugal: received mine today, placed a DIGI SIM, it showed 5G for a few minutes then went to 4G and I haven’t managed to change it.
Edit: Changed the SIM to a NOS SIM, it keeps changing between 5G and 4G. The good news is that at 5G it gets 650Mb/s down, 160Mb/s up.
Edit 2: Going back the DIGI SIM, it keeps also switching between 4G and 5G. Most of the times it shows 4G.
I switched from Xperia-XA2 (2G-4G only) Vodafone Netherlands to Jolla 2026 and was expecting it to activate 5G, but it sticks to 4G here also.
Is the 4G signal strength good?
Same here in Croatia, on Hrvatski Telekom network. On Sony Xperia 10 IV (stock android, not on Sailfish) I’m getting about 3/4 strength 5G signal, Jolla connects only with 4G.
I’m using Vodafone in the Netherlands. The 5G connection DOES actually work for me, but it seems to switch over to 5G much less often than it otherwise should. It’s usually on 4G, but it will sometimes flip to 5G. So it’s probably some config value thing.
Is it actual standalone 5G or LTE with added 5G capacity (non-standalone)? If you are on 4G with the possibility of adding a bit of 5G, but not currently using it, is that still 5G? Your operator probably thinks so, but does SFOS? Probably, but not guaranteed to work the same as e.g. Android…
My provider is Simyo (KPN) and I have the same: no difference between chosing 5G or 4G, it shows ‘4G-bellen (VoLTE)’ in both cases.
VoLTE has nothing to do with 5G working or not afaik.
I’ve not ever seen it show 5G.
It seems to be the same with operator Free in France : main of time in 4G, and a few part of time in 5G even 5G is available anywhere…
I don’t know. All I know is it says “5G” in the top right bar.
After using it for a while, it seems it stays in 4G during low rate data transfer (or even standby) and jumps to 5G when actively transfering large data, like opening a site or downloading a large file.
That is very likely the NSA (Non Stand Alone) 5G that @attah wrote about. I guess that is also exactly how android does it too, android misleadingly naming always ‘‘5G’’ its connection for both stages (4G+5G move during high activity)
Note that for Stand Alone 5G (and opposed to NSA 5G) to work, it needs both to be supported by the operator (often as an optional paid option), and the device to be compatible.
When I test my speed, it remains below 60Mbps, meaning it’s actual 4G; not 5G masquerading as 4G. 5G gives speeds in the hundreds of Mbps. I get that if I put my SIM in another phone.
In other words: the Jolla 2026 atm does not support 5G contrary to what its hardware specs suggest.
Here is my 5G registration with vodafone NL while out and about today. It should be noted it was on 4G basically all the way to and from Schiphol, and only went on 5G after an hour and a half or something.
Haven’t seen that happen yet on mine. And it should have, had 5G implementation on the Jolla - or its reception, who knows - been up to standard.
I have to add that 5G not working, despite selling it as such, is a dealbreaker. If no solution is imminent, I think I need to return the phone.
