How many People are we, who has the Problem with the never ending spin on correct lock code?
Please like this post, who has this Problem, so we can count how many unusable Jolla C2 devices are in the wild…
I was aware that speeding things up may cause device to be still “under construction” but completly unusable device?
Don’t get me wrong, Im still looking forward for better future for Jolla C2, but I wonder how could all this obvious problems be missed and devices shipped like this. No one from Jolla tried to booting new device?
The big problem is the lack of recovery image. All these problems would most probably be solved if we could just do factory reset.
How about a short poll - like after every update?
0 voters
I do not want to specify the bug - I guess everyone who is affected knows what bug is meant in this poll
The Problem is IMHO not the security code. Something get wrong with encryption.
After i was ready with the wizard - the phone worked, but no WLAN. I restarted the phone second time and got an error: “Error with encryption” Wizard started second time (what never should happened) and after second reboot - i got this never ending spinning wheel.
There are multiple symptoms to the bug. Not all who have encryption problems, end up with a spinning wheel. Mine, for example, is worse. I cannot even insert a security code.
I received my phone before this thread was created and the experience was
)In that phase I run out of time and put the phone to the drawer and have not touched it since.
Reading reports above it seems be to be de-facto bricked. Let’s see whether we will get a recovery procedure without sending it in. Well, I did not expect a mature product, so I can’t say I would be really disappointed. Just less lucky than with my previous Jolla/Xperia phones
The device is in Tampere, if you need a piece for your debugging I will be happy to take a bike trip to Polttimonkatu.
Hi all, I just wanted to confirm that I received my phone today and I followed the instructions at the top of this thread and had no issues whatsoever. I immediately plugged it into power, although it still had 48% battery remaining. I then started the first installation wizard and picked a 6-digit code, followed by the connection to my Wifi and the login to my Jolla account which both worked fine.
I must say that I was a bit nervous before the first boot up of the phone as I have read other users experiencing major problems during the setup. So I am very glad that I can report no issues on my end. And I was also already able to download and install the first software update.
Greetings from a very happy Jolla phone user in Germany <3
it is not mandatory right. the first time i did skip it, the second time i thought: oh why not for the sake of good old times.
once you are in it, there is no canceling
however the problem in the end starts with the language selection on the second boot, after an from my point of view finished installation
@Jolla maybe the instructions should be extended with ‘have sim card’ inserted ?
just wondering if that would help
or enable dev mode and use usb tethering in case wifi fails
not sure if that would have helped, just asking
I am somewaht sure, that inserting the SIM card triggered the issue inthat my case. The device reboot multiple without one.
The USB lan cable adapter would have been a better try to get an internet connection, in hindsight ^^’
Do you have a plan to boot it up in some hours or days? Or do you want to wait with it until Jolla gives new instructions?
I received my C2 today. It was off, battery level at 57%. I charged it to 92% and then started it.
I assigned a 5-digit PIN code.
I connected the C2 to the hotspot of my XA2, but according to the WiFi details, the C2 only had a limited connection and could not connect to the store or the internet.
I then switched the mobile network on the XA2 to prefer 2G and changed the primary DNS server in the WiFi connection on the C2 to 8.8.8.8.
After that, I had an unrestricted connection to the internet and was able to set up my account for the Jolla store.
After that I switched the mobile connection on the XA2 back to prefer 4G.
I then downloaded and installed the update to 5.0.0.21.
The restart and installation of the update went without any problems.
I then installed the Jolla apps and Android app support.
As I have only once booted up the phone and as it is working without the SIM and by the Wlan my plan is not to try to restart it until Jolla gives some additional insttuction.
You misread my post. I had no sim in, so when wlan failed, you are in shit
Got my phone!
Worked so far…but since the upgrade, the orientation is stuck to landscape…any idea why?
Thanks everybody to share experience!
Orientation for me is stuck right after reboot until first lock of device then starts working normally (but in portrait though)
Same here, plugged my device into charger. This turned the device on to the language selection, where ic could accept. However a few seconds later, it turned off again due to low battery
I kept it charging for a while, but when i turn it on now, i only get the unresponsive touch language screen.
i did not yet try a usb c mouse input to bypass this, has anybody tried this and succeeded in a bootable state afterwards?
Non-working touchscreen on first boot is not 100% guaranteed brick afaict, you could try rebooting, if wlan fails it’s pretty much over it seems
Some comments on unresponsive touchscreen.
