[C2] Orientation fixed to Landscape after reboot
REPRODUCIBILITY: 0% (not specified)
OSVERSION: 5.0.0.21
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.15 - aarch64
REGRESSION: no
After rebooting (I think the first time after updating to 5.0.0.21) the device comes up in Landscape orientation and does not rotate.
Also reported here: Jolla C2 first time use instructions - #77 by wosrediinanatour
  1. settings->display
  2. Orientation auto
  3. Rotate home screen → on
  4. device behaves as expected
  5. reboot
  6. Sec. code entry is portrait
  7. Lipstick starts in Landscape
EXPECTED RESULTS:
Lipstick orientation follows device orientation.
ACTUAL RESULTS:
Orientstion can be switched in Settings to L or P, but Auto always puts it to L, no rotation.
Apps also seem to get no informartion about orientation.
Tapping the Top Menu Orientation button (while Settings is set to P) from on to off to on again makes device configure itself to L.
  • Patchmanager: no
  • OpenRepos: yes
  • Chum: yes
  • Other: yes: nemoed the username
CSD test of Gyroscope fails, values of +/- 6.x instead of 1.3.
Device Owner User: nemo
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.10+git7
Weird: after a while, this issue fixes itself, and everything starts working as expected.
Yes, you have to wait a bit…
Lock/unlock once after reboot is enough for me (though it starts locked in portrait)
Just now it seemed to fix itself by starting CSD tool and doing the gyro test.
To fix temporarily, run
systemctl restart sensorfwd.service
But it will need admin confirmation.
I found another workaround by accessing the orientation sensor raw values with the Messwerk app.
The app probably launch/restart the daemon which is not launched at boot…
For me, oddly, none of the proposed solutions (above command, waiting after boot, locking and unlocking, etc.) allow my screen to rotate.
It’s just stuck!
My setup is also “nemo’fied” and has quite some mods, but it didn’t want to rotate after a fresh flash either.
AIDA64 is not seeing any accelerometer, compass, rotation sensor or gyroscope either.
I do have a flashed Reeder phone rather than a real C2, bought it off a forum member :slight_smile:
Lock/unlock doesn’t seem to work anymore, but enabling gps and then running any app that uses gps for even a second is a terminal-free option to unlock rotation on C2 after reboot it seems
