exactly! but wifi connection works! I can use browser and Jolla store for example…there seems to be problems with some apps…but I don’t know why…I also tried to restart wi-fi and app-support too…
How did you install mce tools? For me when I run
pkcon-install mce-tools
it says package is not found
It should be already installed.
Well, apparently not, since when I enter any command, say
mcetool --help
terminal says mce is not found
It’s just mce if you want to run it from CLI. Another option is if you tap 5 times in version of SFOS in Settings.
You say it’s just mce, but earlier in this thread you shared this command:
mcetool --set-low-power-mode=enabled
I want to try double tap on my C2, but CLI says mcetool: not found for this command and unrecognized option for
mce --set-low-power-mode=enabled
I found in the terminal that there is a mc-tool and mce installed … so two different commands and programs … maybe you can go with mc-tool …
Solved this, thanks to old thread here.
Had a problem installing mce tool on my Sony 10 III SFOS 4.6, but executing this command first helped me:
pkcon install mce-tests
Terminal asked for my password to install some components, after that this command worked fine:
pkcon install mce-tools
On my C2, however, mce-tools installed without errors right away
Well i have also some devices with Micro USB, even MiniUSB, but the most of my Devices: Phones, Headphones, Arduino, Flipper Zero etc are USB C. Its an EU Standard since couple of years
Good morning, I have put the c2 to load and when it was fully loaded it has asked me for the security code, no assistant has jumped so I can not continue. What do I do now?
Did you type in the default code 12345?
Wasnt there a paper withtge package telling to use that password ?
In my case it was
Maybe the paper was missing from this one package by accident or this is a case of “I don’t read anything inside the package, even though I encountered a problem!”
Hi I finally entered the 12345 and the problem was resolved. Thank you all
The phone powers on automatically when I connect the charger and is now frozen on the C2 and SailfishOS logos.
Hey, my Jolla C2 arrived yesterday. Today, I plugged it into a charger to let it charge fully, but the moment I connected it, the device booted up automatically. Since then, the screen has been stuck displaying the ‘C2’ logo at the top and the ‘SailfishOS’ logo at the bottom. It’s been like this for 40 minutes now. What do you recommend? Should I unplug it and wait for it to turn off, or try connecting it via USB to my laptop?
Feel free to correct me if this post needs to be posted anywhere else or in another way, its my first day at the forum ^^’
Hi @r_now ,
Yes, device boots up when attaching USB-C cable. Unplug the charger and long press power key to power it on.
omg, you’re the best, thanks a lot, I feel so excited and a bit dum at the same time ^^’
Booted up my c2, fully charged. Downloaded the latest sailfish update and the phone rebooted. It is now asking for a security code, but the touch pad is unresponsive. I know the default code is supposed to be 12345, but nothing happens when I touch the numbers on screen.
What to do…
I was able to continue by attaching a mouse and keyboard. Let’s see what happens after the conf.wizard.
