REPRODUCIBILITY (% or how often): 100
BUILD ID = OS VERSION (Settings > About product): 4.1.0.23
HARDWARE (XA2, Xperia 10…): Xperia 10 ii dual
UI LANGUAGE: English
REGRESSION: (compared to previous public release: Yes, No, ?): yes
Index for media files & documents not updating.
After mount a encrypted sd-card, the tracker daemon reindex stuck.
tracker daemon
Miners:
16 May 2021, 12:20:12: 25% File System - Processing… 02m 57s remaining
there is no process that shows an activity („ps -ef“ and „top“)
10 minutes after the mount of the SD-Card the tracker directory ~/.cache/tracker shows no activity
2228228 drwxr-xr-x 2 defaultu defaultu 4096 May 16 12:11 .
2228227 drwxrwx— 19 defaultu defaultu 4096 May 16 11:04 …
2228484 -rw-r–r-- 1 defaultu defaultu 10 May 16 12:11 db-locale.txt
2228373 -rw-r–r-- 1 defaultu defaultu 2 May 16 12:11 db-version.txt
2230780 -rw-r–r-- 1 defaultu defaultu 5 May 16 12:11 first-index.txt
2230779 -rw-r–r-- 1 defaultu defaultu 10 May 16 12:11 last-crawl.txt
2228381 -rw-r–r-- 1 defaultu defaultu 6410240 May 16 12:16 meta.db
2228767 -rw-r–r-- 1 defaultu defaultu 98304 May 16 12:16 meta.db-shm
2228758 -rw-r–r-- 1 defaultu defaultu 10240000 May 16 12:16 meta.db-wal
2230776 -rw-r–r-- 1 defaultu defaultu 363086 May 16 12:11 ontologies.gvdb
2233828 -rw-r–r-- 1 defaultu defaultu 1 May 15 22:09 parser-version.txt
- Reset Tracker with „tracker reset -e“
- Wait till tracker reindex is finish (without SD-Card)
([defaultuser@X10II-p1rat tracker]$ tracker daemon
Store:
16 May 2021, 12:12:08: 0% Store - Idle
Miners:
16 May 2021, 12:12:08: ✓ File System - Idle
16 May 2021, 12:12:08: ✓ Extractor - Idle) - mount encrypted SD-Card
EXPECTED RESULT: Index for media files & documents finish
ACTUAL RESULT: stuck in the middle of nowwhere
Store:
16 May 2021, 12:16:11: 0% Store - Idle
Miners:
16 May 2021, 12:16:11: 19% File System - Processing… 04m 05s remaining
16 May 2021, 12:16:11: ✗ Extractor - Not running or is a disabled plugin
Store:
16 May 2021, 12:16:12: 0% Store - Idle
Miners:
16 May 2021, 12:16:12: 25% File System - Processing… 02m 57s remaining
16 May 2021, 12:16:12: ✗ Extractor - Not running or is a disabled plugin
[defaultuser@X10II-p1rat tracker]$ tracker status
Currently indexed: 1857 files, 357 folders
Remaining space on database partition: 99.7 GB (97.64%)
Data is still being indexed: Estimated 02m 57s left
Store:
16 May 2021, 12:18:03: 0% Store - Idle
Miners:
16 May 2021, 12:18:03: 25% File System - Processing… 02m 57s remaining
16 May 2021, 12:18:03: ✗ Extractor - Not running or is a disabled plugin
