Feedback on Jolla C2
Agree, especially info how to reflash the device by computer including publishing a working flash image. At the moment, customers don’t even know how to reflash the device. OTA update helps nothing if one doesn’t come over the language selection and device stucks.
So question is:
  1. how to set C2 into flash mode
  2. Software and operation process on Linux, Mac and Windows
  3. working image for initial setup and network connection to load future updates.
Now, take this with a ** big grain of salt** because I may be very wrong here.
But AFAICS most SFOS devices come with their recovery image right on the device.
Try:
devel-su
ls /boot
and you should see hybris-recovery.img.
One should be able to copy this off the device and use it as recovery image. Of course that needs a booting device in the first place! :slight_smile:
And we will still need to know how to get into fastboot mode, but I’m sure that info is out there somewhere in Turkish for the Reeder S Pro Max.
Again, I might be wrong here, better wait for official info by Jolla. But someone adventurous might want to try.
I tried the C2 for one day, as a replacement for my Xperia X plus.
It is a good experience so far, with a few issues.
I like the UI, the addition of the App Support button on the menu bar is really convenient.
Using the command line, I was able to install storeman and my usual apps from here with no issue.
The issue I have are the following:
  • Issue with sending SMS, it worked at first when I switched to 3G preferred, but failed later on. In the end, my phone lost the SIM card and the network entry menu, I had to remove my sim card.
  • Issue with App support, MicroG is not recognized by other apps (Spoof permission is enabled on both SFOS and the android setting of this app)
  • Still no usable GPS location unfortunately.
  • I am not able to play / pause music with button on my jack headset
Nice device overall for the price, I think I will love it :slight_smile:
Thanks @nephros for this hint! So I’ll hurry to copy this recovery image from phone to computer, just for the case…
edit: went fine! Have the image on computer now.
Found something on YouTube - it involved holding one of the volume buttons while powering on. Tried both - neither did anything.
What about /home (Käyttäjän tiedostot)?
Can you try to do a df -h ; df -i from the terminal?
Does it also say no space or inodes left?
Mind you there are two takes on this method, while holding the correct volume button make sure you try both methods:
1 - use the powerbutton to power on
OR
2 - insert a usb cable to power on
I’m stating this so obvious because I’ve flashed at least 40 phones of different manufacturers over 20 years, and in many brands only method 1 or 2 works, but they are usually not mutually exclusive depending on brand.
Tried that too. No dice.
(I have a working device, just trying to investigate a bit).
Disk usage overall.
Here is link to df -i printout
df -i
Here is link to df -h printout
df -h
Expires in a week.
Looks like all the goodies came along :grinning:
C2_root
Yesterdays failed upgrade attempt broke something.
C2 cannot download the update any more and hangs in “Waiting for connection”, when trying to fetch update package. #pkcon refresh also hangs.
Otherwise I can open browser and go browsing network (as long as I don’t need to type anything :grinning:)
On-screen keyboard has stopped working or does not come visible. Cannot write in browser or Notes.
Luckily I can now concentrate on admiring the beautiful sharp foto’s that the camera takes. :slightly_smiling_face:
Update 29.10.2024.
  • On-screen keyboard magically returned next day. Now I can write in browser and apps.
  • Package manager(s) are sort of offline. Updating OS with settings is impossible, because update UI cannot download update package, instead update is hang in “Waiting connection” until timeout.
  • Package manager pkcon cannot install anything, propably because it also cannot find any server or update repositories or something.
  • Jolla store and Openrepos cannot install anything and do not recognise any installed apps.
  • Installed apps cannot be uninstalled from app grid.
So my phone is in kind of Kiosk mode. I can use it, but cannot make software changes :grinning:
Waiting (patiently) instructions from Jollyboys to learn how to reflash Sailfish OS. :pray:
Update 1.11.2024
I caved in and send service application to Jolla zendesk and eventually send phone to Jollyboys for repairing (=ReFlashing)…
I have the same issue. My C2 starts, i can enter my security code, but than… wait… wait… wait… watch the turning wheel. But nothing happens. A factory reset would prob. help, but it is not supported, which is very hard for me to beleive.
Thanks.
Yes, that sounds like a half-the-packages-installed kind of update situation.
I’d hop into the terminal (or rather, ssh) and first try to find out what’s breaking pkcon (very likely the broken part is packagekitd, or dbus itself).
There may be useful packages left at /home/.pk-zypp-dist-upgrade-cache.
If that can be made to work again, something like sfos-upgrade --verify, or very careful use of zypper dup might be able to recover the install/update.
You can also try to look through /var/log/zypp/history and try to find which installation failed, if any.
This story tells about how someone could recover this way from a broken update.
Hmm. there’s nothing in history relating to Sailfish upgrade…
2024-10-25 10:29:44|command|root@JollaC2|'/usr/libexec/packagekitd'|
2024-10-25 10:29:44|install|harbour-paketti|1.1.1-1|aarch64|root@JollaC2|store|80a8b1c3432766d746401592c4b195767dda660b47fe6afd510dedd33977560f|
2024-10-25 10:30:34|command|root@JollaC2|'/usr/libexec/packagekitd'|
2024-10-25 10:30:34|install|harbour-barcode|1.0.53-1|aarch64|root@JollaC2|store|6b6e769c3671840e856ba57bf17f17e6ede5b3f79f72b8bfae4cb2e6eb971f52|
2024-10-25 10:35:45|command|root@JollaC2|'/usr/libexec/packagekitd'|
2024-10-25 10:35:45|install|harbour-qrclip|1.0.11-1|aarch64|root@JollaC2|store|8a29b9814efdcd103c896805714ac5b1b4aef2a11c29da798ceb20fafbd96733|
[root@JollaC2 zypp]#
There are packages in …upgrade-cache directories…
bash: sfos-upgrade: not found
bash: zypper: not found
I’ll look into that Story…
Thank you for your help. :+1:
I noticed that camera app when opened from locked phone froze at one orientation a few times.
I realized that there is not much I can do, so I decided to file a ticket at Zendesk. Guessing I will have to send the phone back to Suomi. :cry:
Been driving C2 for a day now and besides some android app crashes and network oddities (that seem to correct thenselves like magic) nothing too awfully disturbing happening. WhatsApp didn’t find storage but then it did and Spotify had some trouble connecting to services - both working fine now though.
The device is rather large compared to the Xperia 10 II so that will take some getting used to. The sleeve volume buttons are way stiff and rather annoying to use - good that there are other options.
Camera works nicely, took some sporting event pics yesterday and even though blurry, I’m ok with this, not a pro photographer in any sense. Video is broken though. Since there’s no official channel for CHUM & OBS on this 5.x yet, I’ve just done “zypper ar” to the latest repos and everything installed from those seems to be working fine for now at least.
Needed to copy ‘wget’ and ‘clear’ from the old SFOS-device since they didn’t seem to exist in C2 by default. Now they work without issues too. So far no other extra needs have risen.
I have received my C2 Phone.
  1. unfortunately I had to realize that the fingerprint cannot be added during setup because these settings are missing!!!
  2. the SailfishOS Store also does not work or open smoothly!!!
  3. when trying to install alternative stores such as Storeman or Chum, they are not displayed on the screen after installation
  4. when trying to reset the phone to factory settings, unfortunately this setting is also missing!!!
How can I solve this problem or can it be solved in the terminal?
Thank you very much for your help and advice
What makes you think it has a sensor?
This is not comprehensible - you’ll have to be more specific.
For me it has a little bit of more loading time than on my 10 III - that’s it. No functional issues.
This is pretty normal for pre-release versions. Some workarounds have been mentioned, but for basic users the best advice is patience.
Also called a “lemon” :confused:
Sorry, it’s an attention error on my part :wink:
