Has someone else had problems with using sailfish settings backup tool to transfer data from a Xperia 10 III?
On my C2 it hangs in the “Gallery” step. Does this happen only in my special constellation or is there a “known issue”?
For me, I also thought that it hangs on Gallery, but it was unexpectedly slow (almost a day) due to a few long videos (I monitored the files created).
It finally finished successfully.
I never experienced that on previous Xperias.
Ok, good to know! Thanks. So I will hang tight!
How can I install zypper on my newly flashed C2?
pkcon install says:
This tool could not find any available package
The same goes for mce-tools.
Works fine for me. Just make sure that your repo indexes are refreshed first.
hmm… something is wrong with my ssh. Works fine on phone fingerterm.
Ok, in my case there is also one big webm Video I download once with yt-dlp, that is saved in the Videos folder that is included in the backup. Indeed, the speed to restore the recovery is soooooo unbelievable slow. I don’t know if that is a bug or my SD Card.
Now I’m not sure if I can just remove that file from the tar or if the backup is invalid then.
Maybe I’ll try.
On the good side I have to note, that I restarted the restore of the backup now more than once and there are no file duplicates etc. occurring (so far). I like that!
It seems to be a C2 bug: during restore, only 1 low power CPU core is used at 100%.
When I used other apps at the same time (browser,…), more powerful cores are activated and the restore of this big video file is faster.
The prerequisite for the installation was the appgallery, which required hms core. Then I downloaded the application directly from the app gallery and after installation, revolut worked without any problems with almost all functions. This method was the one that has worked without any problems since then. After the installation, I did not try to delete HMS Core for now, but I am happy because despite having to install this, I can use the application.
You can find this app with Fdroid
I could not get it work yet on the X 10 III (complains about root as well) and others there seem to struggle in this thread.
Do you have MicroG installed?
Or is it do to some other C2 specific feature, that it works for you?
My feedback after using it for a few days:
Pros:
- Larger size makes for a better UX compared to Xperias with my big hands
- making calls works great, no echo bug
- basic telephone functions work
- I didn’t have any problems setting it up
- Entering the PIN is responsive and fast compared to 10 III
- I can do without face unlock, fingerprints and all that stuff so that’s a plus as well for me
- The Android Apps I need work well (known bugs notwithstanding)
- SFOS runs reasonably fast (I’ve had worse)
- battery life is great compared to 10 III
Neutral:
- Photos are bad in low light and look like watercolor paintings when zoomed in, but that is expected from cheap hardware and might improve with proper camera 2 api some day.
Cons
- There is bad connectivity. Either the SoC is really slowwwwwwww or something is buggy. With my Poco F6 with Snapdragon 8s I get from my window 30mbit LTE+ speeds, with the T606 only 1mbit.
- Upgrading the platform from a 2021 bargain bin chip to something more reasonable for a few € more certainly wouldn’t have hurt anyone. Like a Helio G99, Snapdragon 4 series etc. I don’t see the T606 holding up well over the years since it’s at a snail’s pace when running Android Apps already.
Conclusion:
I always see using SFOS as a lifestyle choice, like being vegan, building a hut in the woods to live off the land or deciding you’re only gonna run free and libre software on your librebooted thinkpad from yesteryear. For having a peace of mind you accept dealing with hardships and hinderances that normal people don’t.
I expect any Sailfish device to be a bumpy ride at this point, but that’s a trade I’m willing to make for increased freedom from big tech surveillance.
At least until the 10 V is working properly, I’ll keep the C2 as my daily driver while my Android phone will be kept as backup, since I don’t really need much more than a feature phone that can do email and whatsapp and sometimes browse things and make snapshots.
Hello
I am a long time user of SailfishOS, since the first Jolla phone (Sailfish OS 1). I use it as my main smartphone. Before the Jolla C2, I was using Sailfish OS 4.6.0.15 on Xperia XA2, that I compare with my current experience with Jolla C2 version 5.0.0.43.
Things that I generally like are display size/resolution, camera zoom/wide angle, web browser update, great battery duration.
But there are too many software limitations to be used happily.
This are the main issues I come across that are really annoying.
No DNS resolution with Android apps (know issue https://forum.sailfishos.org/t/no-mobile-internet-with-android-apps/20586/30)
In the Email client, the search function is not working properly. Searching is working only in the seen/downloaded email. Older emails are not searched into. In the search options, chosing to search in server, the search is not done. (I am using an IMAP4 server, previously this was working)
Bluetooth is not working properly. I can pair Bluetooth audio devices, and auto-reconnect is working.
However when using a headset, the phone disconnect it after some seconds of usage, and has to be manually reconnect or reconnects automatically after some time.
This issue is found in both making a telephone call or watching a video using a browser. -
WLAN is not reconnecting automatically when I go away from my WiFi and then come back (don’t know if it’s relevant, but WiFi network has hidden SSID).
Text prediction xt9 is a missing feature (know issue https://forum.sailfishos.org/t/c2-predictive-text-input-on-sailfishos-5-0-0-missing/21010)
Camera does not support video (know issue https://forum.sailfishos.org/t/jolla-c2-camera-freezes-when-taking-video/20561)
Mobile related (I am using only SIM1 alone):
- 5G is missing (but it’s an hardware limitation?)
- 4G data speed is really slow
Other things not annoying:
VoLTE is not working (Iliad SIM in Italy)
Whatsapp migration guide has to be updated →
https://docs.sailfishos.org/Support/Help_Articles/Whatsapp_Setup/#moving-your-whatsapp-data-to-a-new-phone
To read the UID of user, the path is not
ls -l /home/.android/data/data
but now
ls -l /home/.appsupport/instance/defaultuser/data/data -
During booting, after entering the first PIN for disk encryption, and before entering the system, there is a while with a blank screen. I would just put some loading screen there, as it can be confusing.
I miss fingerprint unlocking (hardware limitation)
Great report!
I don’t see your report in a C2 VoLTE table.
Wifi does sometimes reconnect automatically for me.
Hello, just updated now.
I haven’t tried using the C2 as a so called “daily driver” yet, mainly due to the appsupport mobile data bug. But every time I take it out of the drawer I get the same feeling after playing around with it for a bit; it is way too slow to replace my xperia 10 II. I don’t use many apps, the browser is the most important. On the xperia 10 II the native browser works fine, the only problem is that the OOM killer kills it every now and then (like two-three times when reading a long thread on this forum), but then I just restart it. If it gets too annoying I can switch to firefox on appsupport which works even better. On the C2 scrolling in any somewhat heavier site (like every news site there is) is just painfully laggy in the native browser, and much worse in firefox on appsupport. If this doesn’t get any better (or really much better) I can’t see myself using the C2 as a daily driver.
It sadly is much worse than my old xperia 10 II in every way except the amount of RAM. I originally thought that I could live without a fingerprint sensor, but then it occurred to me that it also doesn’t have a notification led. I would have to enter the (at least) 5 digit code manually every now and then just to poll for incoming messages! I have never had a phone that required me to do that, and I really think that will become a deal breaker for me. I’ll just have to find out if I can live with it when it otherwise becomes usable.
Check your notification settings (Events view, I think). You do not need to unlock phone to see notifications.
You’re right, I don’t need to unlock it. But I still need to pick it up and turn on the display, I can’t just glance at its general direction when I walk past as I’m used to. Maybe I can learn to live with that.
It’s all a matter of muscle memory
I can enter my 26 digit code in under 10 seconds now.
