Feedback on Jolla C2
I tested Bouygues Telecom: The volte does not work. But the reception of mms and sms is ok. Sends sms only. Nothing to do for the mms. I took a new operator (sfr). The volte works as well as reception of sms and mms. But sending mms and sms does not work. I give up the Storage part of the C2. Replace with XA2. I tested the flow rate on several types of device under sailfishOs the worst flow rate is the C2. I didn’t really care about not being able to send an sms or mms. But in terms of flow rate it’s slow. So not yet usable. But on the other hand on the orange operator it works superbly well.
this is missing on the C2, there is no vendor gps.conf in the files as far as I can find, there is a dbus com.jollamobile.gps.conf but that is about it
would you mind posting the entire gps.conf content of your device?
I darkly remember that I read somewhere in the forum, this file has now changed it’s location on recent SFOS version, but unfortunately forgot where the new location is.
This is the file’s content on my old X10 SFOS 4.5.0.24:
# XTRA_SERVER_QUERY (1=on, 0=off)
# If XTRA_SERVER_QUERY is on, the XTRA_SERVERs listed
# below will be ignored, and instead the servers will
# be queried from the modem.
XTRA_SERVER_QUERY=0
# XTRA_SERVERs below are used only if XTRA_SERVER_QUERY
# is off. izatcloud is a qualcomm server
XTRA_SERVER_1=http://xtrapath1.izatcloud.net/xtra2.bin
XTRA_SERVER_2=http://xtrapath2.izatcloud.net/xtra2.bin
XTRA_SERVER_3=http://xtrapath3.izatcloud.net/xtra2.bin
# Error Estimate
# _SET = 1
# _CLEAR = 0
ERR_ESTIMATE=0
# NTP Server
# NTP_SERVER=time.gpsonextra.net
# Asia
# NTP_SERVER=asia.pool.ntp.org
# Europe
# NTP_SERVER=europe.pool.ntp.org	#use this if it must be
# North America
# NTP_SERVER=north-america.pool.ntp.org
NTP_SERVER = ptbtime1.ptb.de
# If NTP_SERVER is commented NTP_SERVER=time.izatcloud.net is used
# DEBUG LEVELS: 0 - none, 1 - Error, 2 - Warning, 3 - Info
#               4 - Debug, 5 - Verbose
# If DEBUG_LEVEL is commented, Android's logging levels will be used
DEBUG_LEVEL = 1
# Intermediate position report, 1=enable, 0=disable
INTERMEDIATE_POS=0
# GPS Capabilities bit mask
# SCHEDULING = 0x01
# MSB = 0x02
# MSA = 0x04
# ON_DEMAND_TIME = 0x10
# GEOFENCE = 0x20
# default = ON_DEMAND_TIME | MSA | MSB | SCHEDULING | GEOFENCE
CAPABILITIES=0x37
# Accuracy threshold for intermediate positions
# less accurate positions are ignored, 0 for passing all positions
# ACCURACY_THRES=5000
##### AGPS server settings #####
# Bitmask of slots that are available
# for write/install to, where 1s indicate writable,
# and the default value is 0 where no slots
# are writable. For example, AGPS_CERT_WRITABLE_MASK
# of b1000001010 makes 3 slots available
# and the remaining 7 slots unwritable.
# AGPS_CERT_WRITABLE_MASK=0
# FOR SUPL SUPPORT, set the following
SUPL_HOST=supl.sonyericsson.com
SUPL_PORT=7275
# EXTRA SETTINGS
# NMEA provider (1=Modem Processor, 0=Application Processor)
NMEA_PROVIDER=1
# Mark if it is a SGLTE target (1=SGLTE, 0=nonSGLTE)
SGLTE_TARGET=0
# Select technology for LPPe Control Plane
# 0x1: DBH for LPPe CP
# 0x2: WLAN AP Measurements for LPPe CP
LPPE_CP_TECHNOLOGY = 0
# Select technology for LPPe User Plane
# 0x1: DBH for LPPe UP
# 0x2: WLAN AP Measurements for LPPe UP
LPPE_UP_TECHNOLOGY = 0
# AGPS_CONFIG_INJECT
# enable/disable injection of AGPS configurations:
#     SUPL_VER
#     SUPL_HOST
#     SUPL_PORT
#     SUPL_MODE
#     SUPL_ES
#     C2K_HOST
#     C2K_PORT
#     LPP_PROFILE
#     A_GLONASS_POS_PROTOCOL_SELECT
#     USE_EMERGENCY_PDN_FOR_EMERGENCY_SUPL
#     GPS_LOCK
# 0: disable
# 1: enable
AGPS_CONFIG_INJECT = 1
# AP Coarse Timestamp Uncertainty
# default : 10
# or as per clock uncertainty of product
AP_TIMESTAMP_UNCERTAINTY = 10
#DR_SYNC Pulse Availability
# 0 : DR_SYNC pulse not available (default)
# 1 : DR_SYNC pulse available
DR_SYNC_ENABLED = 0
#PPS Device name
PPS_DEVICENAME = /dev/pps0
#AP Clock Accuracy
AP_CLOCK_PPM = 100
#MAX ms difference to detect missing pulse
MISSING_PULSE_TIME_DELTA = 900
#Propagation time uncertainty
PROPAGATION_TIME_UNCERTAINTY = 1
awesome thanks probably need to figure out first what device the /dev/… the gps is on for the C2, i installed and tried running gpsd manually on /dev/ttyS2 but while GPS shows active no location is found, and gpsd service cannot be started, maybe on SailfishOS it is using a different service?
devel-su gpsd /dev/ttyS2 -F /var/run/gpsd.sock
that means on the C2 mobile tower assisted GPS works (since it got the location for me running OSM Scout when I had a SIM inserted), now I am only using Wifi and wanted to run the GPS by itself
I looked for the /etc/geoclue/geoclue.conf as well and geoclue.conf is not available on the C2, what I found so far is /etc/location.conf
with includes lines…
enabled=true
gps/enabled=true
mls/enabled=true (probably the mozilla service)
allowed_data_sources\device_sensors=true
allowed_data_sources\gps=true
Ok it actually worked just leaving the phone sitting for 40min or so with location active in the same spot exposed to the sky!
I’ve tested in GPS-only mode. And things may be different on new C2 hardware.
14. On daily alarm activation when selecting the volume up/down switch, while phone is locked, the alarm is not muted, or volume reduced.
not for me for MMS and no GPS (C2 with os 5.0.0.43)
Please report calls, SMS and MMS tests results into testing topic.
Hello yes I know. It’s a small package. The exact operator is a Coriolis virtual operator on the SFR network. I confirm that it would have worked. But nothing to do
Hello, est-ce que vous pourriez me donner votre config mms car chez moi j’ai une erreur de récupération des mms (Problème de téléchargement du message). Merci par avance.
Here is my mms configuration
Voici ma configuration mms
I can’t use the camera’s flash because it’s either badly positioned or badly calibrated. When activated, it creates a white halo in the bottom left-hand corner of the photo.
This could be an effect of some (bad) covers.
This is the one purchased from Jolla with the C2.
It seems to distribute the flashlight to the lens.
A fix could be using an Edding pen to darken the inner surface of the flash cutout of the cover.
Another interesting read about this:
Just cut the cover in part between Flash and lens. It helps tremendously.
Even if I don’t find this very serious, I thank you for your reply.
The sound quality is mediocre and too high-pitched. Is there a software solution to make it better?
It’s very serious from me. It works for me. And some others as well.
What’s not serious is that it was not tested and fixed. Luckily there are also other covers available (3rd party).
Specifically to Revolut could you do it without HMS Core? Or what was your setup and what version are you on?
I am on Xperia 10 III so i may have issue with the rooting generally as well, but maybe your experience can help a bit.
