You can find the answer here in the forum. First there is the solution discussed often. Second you can read about a new solution: Jolla C2 first time use instructions - #136 by nthn
And third: have you a source for “almost 2/3 of the devices”.
There are many emotions on the way here about a pure technical topic…
There is a counter some way up. And i said almost 2/3
Wont be explaining myself as I fell I have the right to be angry.
And over the air update for a brick? How can I update over the air when Im stuck with endless spinning circle after entering a 6-digit code that I set?
I follow the forum on hourly basis, I did all the steps recommended to not brick the device but it wasn’t helpful. Couldnt even do the update on first boot as wifi nor mobile data wasnt working. The device I get was deemd to fail.
On arrival battery was flat, I connected it to wall charger. It charged for 2-3 minutes, boot itself up without any of my doing. Than told battery is flat and turned off.
I needed to wait for device to run fully flat again. This allowed me to do first boot. But It all went as I explaing at the start of this post.
The current number of reported bricked C2 phones on the forum is currently 53, although this is probably understated as some users suffering this problem will probably go directly to Jolla via Zendesk or whatever.
I have no idea what proportion of those C2’s that have been shipped, delivered and setup (or attempted to set up) this number represents as I do not have access to that information. What we do know is that a fair number of C2’s have been setup without this problem occurring at all.
At the current time Jolla have provided no update on why this issue occurs or what causes it. The current advice seems to be to return your bricked phone to Jolla for a replacement or a refund by logging a ticket on Zendesk (though this has not been widely publicised).
Of course the update won’t fix the phones that are broken right now, but after sending your device in to get it fixed right now, which apparently doesn’t take very long, and after said update is out and you’ve installed it onto your device, you’ll be able to fix a non-booting device yourself without sending it in, as has previously always been the case.
Jolla messed up, we know. They’re also (actually) working overtime to fix it. Most people with a broken device will probably have it fixed before the last customers receive their C2. In fact, NikosAlexandris above got his device fixed and back in his hands in a shorter timespan than my post office has needed to decide which day they’d deliver mine (supposedly tomorrow).
I understand I should swnd the device in. The device that was late by few months. Shipping took almost two weeks so counting over, yet another month to get the device back and at this point no guarantees that it would even help. Sorry but Im loosing confidence for this device to turn out anything better than all the xperia’s. Sony devices are at least not a brick and far away better than community device and Sailfish “as its meant to be”
I agree with you, for such a niche product coming from such a small company and so reliant in the good work of the users, a root cause analysis should be well underway by now. And people who spent their hard earned money deserve at least a small explanation of what’s happened.
My advice to Jolla if it’s really aiming to conquer the automotive market (I’m a quality assurance engineer with iso 9001 and iatf auditing certificate) please work on your Quality Management System and communication, if a supplier did this where I work I honestly don’t think you’ll stand a chance to get any more work nominated.
Starting of programs and working with thems is very slow. If you are patient, most works finaly. It seems that accessing files could be a root cause. Hadn’t time for debugging. It is independent of the app or whether it is a native or an Android app.
e.g. sending pictures in Whatsapp needs sometimes several retries. In the first minute after Whatsapp starts, it says that it hasn’t enough disc space. When clicking on the message, the available space jumps from 0 to 108Gb.
Camera works, but sometimes it needs a minute or two after pressing the button. (it just hangs for some time).
No, you shouldn’t just send it in. You should, as noted in many places, open a ticket at zendesk and wait for instructions. Which will tell you how to do.
Somebody else, in another thread, posted a C2 photo. No apps were running other than Crest and this showed that almost no RAM was being used, but lots of swap memory. The poster was speculating that the C2 was so laggy because it was using swap memory all the time rather then RAM.
Hello, I will return my C2 for repair.
For my part, when I pre-ordered, I suspected that there would be problems.
But I reiterate my confidence in Jolla. Sailfish OS is a great OS and congratulations to Jolla. My first Jolla Aqua is still functional. I have an Xperia 10 under SailfishOS and an Xperia 10 III and I will continue the experience with a 10 V. I am waiting for my new 10 V purchased second-hand to be sent.
Personally, I don’t need a phone, I use my Xperia 10 III which works very well. My colleagues smile when I take out my X10 III to take a photo because once out of 10 times it has to be reset because the camera gets stuck on the front. But I don’t care. For nothing in the world would I change my SailfishOS for the latest Samsung or Apple
Therefore you should contact Zendesk before. You’ll get a service case number under which everything is organized. Don’t do anything or send the device before you have confirmation or number from Zendesk.
