Why would a 10 V be an advantage over a 10 iii? Both should support eSIM when the functionality is delivered (ie. never)
I didnāt knew that 10 III has eSIM. Mine for sure hasnāt.
Mine neither and according to Sony documentation Xperia 10 III (XQ-BT52) doesnāt support e-sim
My bad, sorry (20 characters)
Community member @b100dian posted this article in IRC which could be helpful for eSIM support under sfos. Letās hope that eSIM support will get some traction in the near future ![]()
The physical esim sounds like the best of both worlds. I could easily see myself transferring my carrier sim into a physical esim that I could also load other travel sims into.
Great if someone with a physical esim could try this software.
And I saw this on the Osmocom esim page: GitHub - osmocom/pysim: A python tool to explore and program SIMs / USIMs / ISIMs. Mirror of https://gitea.osmocom.org/sim-card/pysim
I have a dual sim xperia 10ii (physical + esim) and it looks like support is already there, Sailfish at least recognises the phone is dual sim capable (Sailfish 4.5). Settings shows two sim slots, see screenshot.
I havenāt tried it yet thoughā¦
I donāt believe the 10 II has eSIM. Are you confusing it with something like an actual physical SIM providing same/similar functionality?
I think the mentioned software is more of a front end to lpac, which would have to be ported to SFOS first: GitHub - estkme-group/lpac: C-based eUICC LPA
If I understand lpac correctly, it can be used from the command line, so a front end would not be strictly necessary.
any updates here? Iād like to try SFOS on Sony Xperia 10 IV but need eSIM support
Given the fact the new C2 reference device apparently does not support eSIM I doubt Jolla will be much motivated to implement this. I think it will have to come from the community.
Not really planned but some preparation things have been done. eSIM is somethimg that we need eventually support.
As we speak, there are more urgent items to finalize. Support for eSIM is something that we roadmap for Sailfish 5 series but not for the first release.
So, no dual sim use in X10V (XQ-DC54) then
⦠and XQ-DC72 is not on the list of supported devices, why XQ-DC54 was the device to go forā¦
Then my 10III has to last a bit longer.
We have decided to support the variant XQ-DC72, too. It has two physical SIM slots, one of which can be used for a SIM card or an SD card. Our documents need an update. XQ-DC72 shares the code base with XQ-DC54 but requires a different configuration. We will create dedicated flashable images for these two variants.
XQ-DC54 has the eSIM, one physical SIM slot and an SD card slot. Unfortunately, Sailfish does not support the eSIM. Therefore, XQ-DC54 works as a single SIM phone.
Hooray, this is great to have this confirmation. Thanks so much.
Not 100% Sailfish related but may still be interesting to get some background information on eSIM:
If anybody is interested in technical specifications, please see the eSIM specifications for Consumer devices on the GSMA website:
https://www.gsma.com/solutions-and-impact/technologies/esim/esim-specification/
Hi,
Is Sailfish OS for Sony Xperia 10 V going to be available in the Downloads any time soon. I keep checking and nothing. After the Sauna release, I thought maybe, but its still not there!?
Cheers
Dave
Why are you posting in the thread about eSIM, and not the one about Xperia 10 V?
The proper thread actually does have an answer.
Oh yes, somehow the forum page changed on my computer. I will try to find it again.
