BUILD ID = OS VERSION : 4.4.058 (but the bug was present with older version of Sailfish OS. Adaptation of the phone : 0.0.2.97
HARDWARE (XA2, X10, X10 II, …): X10ii
UI LANGUAGE: French
When you receive a call or when you make a call, you can’t use the loudspeaker you have an echo that the other person can’t hear you correctly
- receive a call or do a call
- loudspeaker is “on”
- you have an echo
A call without echo
A call with echo
se also this thread about that : Echo on during call on loudspeaker (Xperia 10 II)
You have not this bug with Signal (i don’t test other app).
