REPRODUCIBILITY (% or how often): 90%
BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, Xperia 10…): Xperia 10 II, Xperia 10
UI LANGUAGE: Swedish
REGRESSION: (compared to previous public release: Yes, No, ?): Yes, compared to 3.X
The quick-toggle Bluetooth button on the top menu shows that Bluetooth is off, and there is no indicator in the status bar, but in the settings it shows as on, and my headphones automatically connect just fine.
Bluetooth on (maybe?)
Turn off phone
Turn on phone
Toggle shows that Bluetooth is active, the indicator is shown in the status bar.
Bluetooth is stealthily enabled, Bluetooth headphones connect automatically just fine.
This seems to be fixed in 4.4 (tested with XA2 Ultra) but it’s not mentioned in changelog. I’ll confirm this with X10II, too, which also suffers from the same issue.
Same issue on my new X10 III (4.4.0.68), with 100% reproducibility. This happens after each reboot. I need to turn Bluetooth off/on or switch the Flight mode on/off for the status bar indicator to appear and the quick-toggle button to show correct state.
P.S. If I want to do it using the quick-toggle button itself (which after reboot incorrectly shows inactive state), I have to press it TWICE, because the first time actually turns Bluetooth OFF (so the state of the quick-toggle button doesn’t change as it was already off), and only the second press turns Bluetooth back on and makes the quick-toggle button show active state.
What’s strange, I have never, not a single time, seen this issue on my XA2 Ultra, whereas on the 10 III it happens after each single reboot.
