BUILD ID:
HARDWARE (Jolla1, Tablet, XA2,…): XA2
UI LANGUAGE: german
REGRESSION: (compared to previous public release: Yes, No, ?): don’t tested
Accounts added from Backup don’t work. Sure, we need to re-enter the passwords, but nevertheless no connection ist possible. That affects:
Email
Nextcloud
OneDrive
Dropbox
(I don’t remember if Twitter was affected too. Other account types untested cause I don’t have such)
If the account is completely deleted and added new everything works like expected.
XA2 was on 3.4 with Android support problems. Factory reset
- Create Backup to SD from 3.4
- Reset phone to factory settings (gives System 3.1)
- Updating phone from system settings (in two steps: 3.2, then direct 3.4)
- enable encryption
- import backup from sd
- go into each account and fill in the specific password
Accounts importey from backup should work after adding password in settings.
Accounts don’t work
