As reported (and confirmed by other) my X suffers from a heavy power drain.
I tested a lot and it is absolutely only happening when WLAN is connected.
It is a more or less plain vanilla device (storeman, sfos-upgrade, harbour-defender) for testing.
Upgraded from 3.3 up to 4.1.
One mail account, set to sync manual.
Tested with all radio on, only network, network and cell data, WLAN enabled (but not connected) and other combinations. But it boils down to WLAN connected.
In my case, the device was updated from 4.0.1 (no power drain) to 4.1.0 (heavy power drain), so it must be related to a change between 4.0.1 and 4.1.0. And indeed, the only factor that has any effect is whether or not WLAN is enabled. The power drain is the same, regardless of whether there are any accounts syncing or not, whether Android support is running or not, whether applications are running or not, whether background services are running or not, etc. Only enabling WLAN causes the power drain. I think it occurs on both 2.4GHz and 5GHz Wi-Fi networks.
WLAN enabled → heavy power drain
WLAN disabled → no power drain
The fact that the regression occurred in between 4.0.1.48 and 4.1.0.23, and that the WLAN connection is causing (or is a primary factor in) the power drain, should hopefully narrow down which of the changes between the versions led to the regression.
And this one is just another (bad) example why I asked for a better bug handling (tracking/tagging) that needs to be done by @Jolla as long as they keep hiding their internal bug tracking system (which is okay!) but do not open up a public one or start doing work on this forum’s bug reports.
Nope. No ssh.
Just plain and simple laying around connected to WiFi AP, no usage and no connection at all (maybe one standard set up mail IMAP account, sync all 39 min).
