This is to announce 4.6.0.13 SFOS update for Xperia Tama devices: XZ2, XZ2c, and XZ3. Please read release notes before update.
As mentioned in the release notes, Waydroid does not start in 4.6.0.13. At this moment, I don’t know how to resolve it.
Note that during OTA update, my screen went blank. As I am usually running those via ssh, it wasn’t a problem. However, local terminal users could be in a situation where it is not clear whether update has finished.
I have updated OTA instructions and recommend using SSH with it. Please read instructions if you plan to update via OTA.
At the moment of writing, this release has had a limited testing and only via OTA update. So, early adopters, please report how it went. If someone preferred to flash the image, please report as well. For those wishing to be on the safer side, wait till more users would have a chance to test the release.
Images are available for this release.
Edit 24 Jun: Waydroid issue should be fixed now. But see below for issues with icons, no solution so far
Edit 25 Jun: Issue with icons is resolved now as well. New images have been uploaded and attached to the release.
Sailfish-default icons are moved from /usr/share/themes/sailfish-default/meegotouch
to /usr/share/themes/sailfish-default/silica
There’s now an image provider component in Silica which can be registered with custom paths. Apps don’t need to put their things in the global directory.
Regarding Waydroid — seems that the issue is common across all ports. I had it on Xperia 10 (yes, I am using Waydroid on official paid version since it’s much better at isolating android apps).
As it is stated in rinigus post, removing or commenting
lxc.apparmor.profile = unconfined
in /var/lib/waydroid/lxc/waydroid/config works for now.
I updated and got icons disappearing too - not just app icons, the show button for passwords, the shift and back keys on kboard…and very weird, when I enter the letter t on any input field it takes a screenshot.
Would be good to check ssu lr from you (@defactofactotum) and @ApB. As it is the only anomaly that I experienced during OTA update and fortunately fixed it before I proceeded with OTA.
For some reason, you miss store (Enabled repos by user, see OTA instructions) and you have aliendalvik repo. Also, Chum repo is fixed on wrong version.
I disabled all patches first and wanted to disable openrepos too but I think the patchmanager froze the homescreen so I just left it. Yes, I updated from 4.5.0.24. I suppose I can reflash.
