Unfortunately, it’s still impossible to tell what’s wrong.
Some interesting stuff may (or may not) be hidden behind systemd-journald[667]: Suppressed xxx messages from ofono.service
Data call status 4100 (the value probably coming from inside the modem) is even less informative than 50, it’s defined in Android binder API as OEM_DCFAILCAUSE_4, i.e. “something went wrong but we won’t give you any clue”.
Thank you. Can we be pragmatic? Who can fix this? How much does it cost? Time and money?
I would not like to wait for months. Having an answer clear and upfront, is the best.
Dear Jolla, we have already paid more than EU 300.- for the device, we have bought the license for the operating system, so it is natural that we have expectations.
Would we know who can fix this, how much time and money it will cost, it would help ‘us’ : we can wait and contribute. Needless to say, please test more before advertising a new device supported by SailfishOS.
DRM keys cannot be backed up on devices other than tne Xperia X since there are no exploits.
You will be able to restore Android but the protected features will no more be available.
Dear @jameson@emva@flypig@PeegeeTips@slava@senders, I strongly suggest that we try to tackle this issue together. We, end-users, that have bought an Xperia 10 III device and decided to flash SailfishOS on it, did so by choice. I guess we all know the risks and we are conscious about the benefits, and this is why we are here. Any polemic rhetoric won’t help. There are other serious problems in the world than a mobile phone device.
Let us try to gather pieces and see how we can collectively resolve the issue. This is the intention behind asking who can fix this, how much time would it take and how much would it cost. Isn’t for example the work done here Sailfish OS for Sony Xperia 1 and 5 (4.4.0.72) | XDA Forums relevant? Eventually, there are similar issues to tackle.
The solution requires putting hand to device-level code and having good knowledge of the communications stack. I understand that someone on some other topic around here might hope to solve the issue magically by switching SIMs, but the solution lies in finding (and fixing) the reason of the misbehaviour of the device with some providers.
Out of curiosity @flypig did the logs I submitted reveal anything interesting?
i.e. some hint at at the cause of the problem.
I have had no feedback from Jolla support.
I have upgraded both my XA2 and the 10iii to SFOS 4.5:
Same settings used on my XA2 Plus work fine. Xperia 10 III handset was confirmed to have working telephony/mobile-data before device flashing. Xperia 10 III running 4.5 can make phone calls, shows “3.5G” and shows 40% signal on the sim icon on the desktop, and shows “TalkMobile” as enabled in the settings. It also shows as “Enabled” rather than “Connected”, and there is no double triangle icon next to the “3.5G” on the homescreen.
Using the settings that I successfully use on my XA2:
(ofono_2023-02-09_141328.tar.gz)
Data
APN: talktobile.co.uk
Protocol (IP or IPv6 or Dual): Dual
Authentication: PAP or Chap
Username: wap
password: wap
Using the settings provided to Flypig by TalkMobile:
(ofono_2023-02-09_142144.tar.gz)
Data
APN: TalkMobile.co.uk
Protocol (IP or IPv6 or Dual): IP (this is what you mean by “IPV4” right?)
Authentication: PAP
Username: wap
password: wap
Neither work. New ofono logs for both sets of settings supplied.
Only difference that I can see is that homescreen now shows “3.5G” rather than “3G”.
I think that the only way out of this is either to switch provider or to switch mobile phone.
Since there is no trace of work on the Xperia 10 IV, and for the Xperia 10 V port we need at least other 16 months, either I stick with the XA2 or I switch to Iliad.
