Xperia 10 iii can't enable mobile data on talkmobile use the same settings used on my XA2 Plus
@flypig did point me towards a help article showing how to create and submit logs, but can’t find it now…
Jolla Zendesk for submitting logs here:
https://jolla.zendesk.com/hc/en-us
Not really a step-by-step guide, but this will show you the right way to go:
Thank you. What is useful in such logs? Following is with devel-su journalctl -f -u ofono :
Nov 30 11:42:10 Xperia10III ofonod[3323]: Activating context: 1
Nov 30 11:42:10 Xperia10III ofonod[3323]: setting up data call
Nov 30 11:42:27 Xperia10III ofonod[3323]: Deactivating context: 1
Nov 30 11:42:27 Xperia10III ofonod[3323]: Clearing active context
Nov 30 11:42:27 Xperia10III ofonod[3323]: Deactivated data call
Nov 30 11:42:28 Xperia10III ofonod[3323]: Activating context: 1
Nov 30 11:42:28 Xperia10III ofonod[3323]: setting up data call
Nov 30 11:42:54 Xperia10III ofonod[3323]: Deactivating context: 1
Nov 30 11:42:54 Xperia10III ofonod[3323]: Clearing active context
Nov 30 11:42:54 Xperia10III ofonod[3323]: Deactivated data call
Nov 30 11:42:55 Xperia10III ofonod[3323]: Activating context: 1
Nov 30 11:42:55 Xperia10III ofonod[3323]: Unexpected data call status 50
Nov 30 11:43:19 Xperia10III ofonod[3323]: Activating context: 1
Nov 30 11:43:19 Xperia10III ofonod[3323]: Unexpected data call status 50
Nov 30 11:43:35 Xperia10III ofonod[3323]: Activating context: 1
Nov 30 11:43:35 Xperia10III ofonod[3323]: setting up data call
Nov 30 11:44:20 Xperia10III ofonod[3323]: Deactivating context: 1
Nov 30 11:44:20 Xperia10III ofonod[3323]: Clearing active context
Nov 30 11:44:20 Xperia10III ofonod[3323]: Deactivated data call
Nov 30 11:44:21 Xperia10III ofonod[3323]: Activating context: 1
Nov 30 11:44:21 Xperia10III ofonod[3323]: setting up data call
These are de- and activating Mobile data, changing the data access point (IP to IPv6 or Dual and back), or even changing the APN from mobile.vodafone.it to web.omnitel.it.
Which part of these would be useful?
For these kinds of issues, where we don’t necessarily have ready access to the network/operator, logs are a really important tool. So it’s a big help if you can share logs, and really appreciated as well.
Whenever submitting logs, please do be aware that they can contain private data, so you should look through them and remove anything private before submitting them to Jolla or here on the forum.
@NikosAlexandris: is it Vodafone Italy that you’re having difficulty with?
I would like to get this working, obviously. I can contribute logs if they are useful. Yes, it’s Vodafone Italy.
I don’t want to oversell the benefit: having logs isn’t a guarantee that things can be fixed, but without them it there’s very little to go on.
This isn’t my area, so I’m not sure, but I’ll see if I can get an answer for you. In general the more detailed your logs the better, and if you can lightly annotate them with actions (e.g. at which point you enabled/disabled the network) then that can also helpful.
Do you mean that this issue has not been fixed yet?
@NikosAlexandris, I consulted an expert and it seems there is a hint in your logs. The “Unexpected data call status 50” lines tie back to 3GPP TS 24.301 Annex B, where it says “Cause #50 – PDN type IPv4 only allowed”.
The suggestion was therefore to try changing protocol in Settings → Mobile network → Data access point → Protocol to IP (meaning IPv4).
If you could please try that, see if it helps and let us know, that would be appreciated. In case it doesn’t help, more similar logs would be useful.
If this is addressed to me, then no, not yet: :slight_smile:
Jolla Care November 16, 2022
Hi,
Sorry for the late reply and thanks for the additional information!
We should have now all the needed information for now, hopefully this can be solved, but unfortunately can’t give any estimate on that.
Sincerely,
Jolla Customer Care
So after 6 months of reporting a bug stopping me to use my phone no attempt has even been made to solve the issue?
I think I should have back my license fee, install Android and leave the ship. I can live with bugs as long as they are fixed after reporting.
How, or better what, do I “clean” (in) the logs before publishing here? Else, I can (can I?) share to a trusted connection person a secure link with a file.
Tried this months ago. It does not work. ifconfig only shows an IPv6 address for Vodafone IT.
This is a question of what you consider to be private. Logs can, for example, contain phone numbers, usernames, contents of emails, etc. depending on what you capture. So it’s usually a manual process of reading through the logs to check, I’m afraid.
i believe the recommendation is when using ofonologs to generate log material for submission is to not ring any numbers.
simply set it running - while ofonologs captures the ofono connection data - and then stop it.
i ran it for about a minute, and that is apparently sufficient.
It is a new phone and there are no contacts yet. I didn’t make any phonecalls and no e-mails checking either. Manually checking what is human readable, is fine. Machine language however? It’s much of a time currently to scrutinize this. If anyone cares, I can share a link with stuff copy-pasted from the terminal. Else, I am pasting below lines I understand are safe to share.
Nothing of what I tried works.
After booting the phone
❯ ssh defaultuser@192.168.2.16
defaultuser@192.168.2.16's password:
Last login: Wed Nov 30 11:32:36 2022 from 192.168.2.12
| Sailfish OS 4.4.0.72 (Vanha Rauma)
[defaultuser@Xperia10III ~]$ devel-su journalctl -f -u ofono
Password:
-- Logs begin at Wed 2022-11-30 13:38:53 CET. --
Nov 30 13:38:57 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:38:57 Xperia10III ofonod[3320]: setting up data call
Nov 30 13:38:57 Xperia10III ofonod[3320]: [gbinder] Service manager /dev/hwpuddlejumper has appeared
Nov 30 13:39:06 Xperia10III ofonod[3320]: export_entries_one_storage_cb with ME failed
  • Mobile Internet is: Limited connectivity
  • 4G Calling (beta): Registered
Going to Settings → Cellular network → Data access point:
  • Changing from IP to IPv6 (though Vodafone does not support this in Italy?)
Nov 30 13:47:15 Xperia10III ofonod[3320]: Deactivating context: 1
Nov 30 13:47:15 Xperia10III ofonod[3320]: Clearing active context
Nov 30 13:47:15 Xperia10III ofonod[3320]: Deactivated data call
Nov 30 13:47:15 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:47:15 Xperia10III systemd-journald[667]: Suppressed 95 messages from ofono.service
Nov 30 13:47:15 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 13:47:15 Xperia10III ofonod[3320]: Unexpected data call status 4100
Nov 30 13:47:15 Xperia10III ofonod[3320]: imsradio0 > 27 vopsChanged
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    2::IImsR adioIndi
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  01 00 00 00                cation.. ....
Nov 30 13:47:15 Xperia10III ofonod[3320]: imsradio0 > 4 registrationChanged
Nov 30 13:47:15 Xperia10III ofonod[3320]: imsradio0 < 7 requestRegistrationChange
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    0::IImsR adio....
Nov 30 13:47:15 Xperia10III ofonod[3320]: imsradio0 > 4 requestRegistrationChangeResponse
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    0::IImsR adioResp
Nov 30 13:47:15 Xperia10III ofonod[3320]:   0030: 6f 6e 73 65 00 00 00 00  05 00 00 00 00 00 00 00    onse.... ........
  • from IPv6 to Dual
Nov 30 13:48:19 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:48:19 Xperia10III ofonod[3320]: Unexpected data call status 50
Nov 30 13:48:49 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:48:49 Xperia10III ofonod[3320]: Unexpected data call status 50
Nov 30 13:49:25 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:49:25 Xperia10III ofonod[3320]: Unexpected data call status 50
Nov 30 13:50:05 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:50:05 Xperia10III ofonod[3320]: setting up data call
  • Data access point to : web.omnitel.it
Nov 30 13:51:51 Xperia10III ofonod[3320]: Deactivating context: 1
Nov 30 13:51:51 Xperia10III ofonod[3320]: Clearing active context
Nov 30 13:51:51 Xperia10III ofonod[3320]: Deactivated data call
Nov 30 13:51:52 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:51:52 Xperia10III ofonod[3320]: setting up data call
  • Data access point (back) to : mobile.vodafone.it
Nov 30 13:53:42 Xperia10III ofonod[3320]: Deactivating context: 1
Nov 30 13:53:42 Xperia10III ofonod[3320]: Clearing active context
Nov 30 13:53:42 Xperia10III ofonod[3320]: Deactivated data call
Nov 30 13:53:43 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:53:43 Xperia10III ofonod[3320]: setting up data call
  • From Prefer 4G to Prefer 3G
Nov 30 13:55:15 Xperia10III systemd-journald[667]: Suppressed 407 messages from ofono.service
Nov 30 13:55:15 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
Nov 30 13:55:15 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 13:55:15 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 13:55:15 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 13:55:15 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 13:55:15 Xperia10III ofonod[3320]: data reg changed 1 -> 2 (searching), attached 0
Nov 30 13:55:15 Xperia10III ofonod[3320]: Deactivating context: 1
Nov 30 13:55:15 Xperia10III ofonod[3320]: Clearing active context
Nov 30 13:55:28 Xperia10III ofonod[3320]: data reg changed 2 -> 1 (registered), attached 1
Nov 30 13:55:30 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:55:30 Xperia10III ofonod[3320]: Unexpected data call status 33
  • Mobile Internet : Enabled. Mobile internet does not work however.
  • 4G Calling (beta): Not registered
  • From Prefer 3G to 2G only
Nov 30 13:56:16 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:56:16 Xperia10III ofonod[3320]: Unexpected data call status 4100
Nov 30 13:57:07 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:57:07 Xperia10III ofonod[3320]: Unexpected data call status 4100
Nov 30 13:58:03 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:58:03 Xperia10III ofonod[3320]: Unexpected data call status 4100
Nov 30 13:59:04 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 13:59:04 Xperia10III ofonod[3320]: Unexpected data call status 4100
Nov 30 14:00:10 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 14:00:10 Xperia10III ofonod[3320]: Unexpected data call status 4100
Nov 30 14:01:21 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 14:01:21 Xperia10III ofonod[3320]: Unexpected data call status 4100
  • Back to Prefer 4G
Nov 30 14:02:13 Xperia10III ofonod[3320]: data reg changed 1 -> 2 (searching), attached 1
Nov 30 14:02:14 Xperia10III systemd-journald[667]: Suppressed 556 messages from ofono.service
Nov 30 14:02:14 Xperia10III ofonod[3320]: imsradio0 > 27 vopsChanged
Nov 30 14:02:14 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:02:14 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:02:14 Xperia10III ofonod[3320]:   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    2::IImsR adioIndi
Nov 30 14:02:14 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  01 00 00 00                cation.. ....
Nov 30 14:02:14 Xperia10III ofonod[3320]: imsradio0 < 7 requestRegistrationChange
Nov 30 14:02:14 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    0::IImsR adio....
Nov 30 14:02:14 Xperia10III ofonod[3320]:   0030: 08 00 00 00 00 00 00 00                             ........
Nov 30 14:02:14 Xperia10III ofonod[3320]: imsradio0 > 4 requestRegistrationChangeResponse
Nov 30 14:02:14 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    0::IImsR adioResp
Nov 30 14:02:14 Xperia10III ofonod[3320]:   0030: 6f 6e 73 65 00 00 00 00  08 00 00 00 00 00 00 00    onse.... ........
Nov 30 14:02:14 Xperia10III ofonod[3320]: data reg changed 2 -> 1 (registered), attached 1
Nov 30 14:02:15 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 14:02:15 Xperia10III ofonod[3320]: setting up data call
Nov 30 14:02:15 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
Nov 30 14:02:15 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:02:15 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:02:15 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:02:15 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 14:02:15 Xperia10III ofonod[3320]: imsradio0 > 4 registrationChanged
Nov 30 14:02:16 Xperia10III ofonod[3320]: imsradio0 > 4 registrationChanged
Nov 30 14:02:16 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:02:16 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:02:16 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:02:16 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 14:02:16 Xperia10III ofonod[3320]: imsradio0 < 31 setSuppServiceNotification
Nov 30 14:02:16 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    0::IImsR adio....
Nov 30 14:02:16 Xperia10III ofonod[3320]: imsradio0 > 28 setSuppServiceNotificationResponse
Nov 30 14:02:16 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    0::IImsR adioResp
Nov 30 14:02:16 Xperia10III ofonod[3320]:   0030: 6f 6e 73 65 00 00 00 00  09 00 00 00 00 00 00 00    onse.... ........
Nov 30 14:02:16 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
  • Deactivating 4G calling (beta)
Nov 30 14:04:04 Xperia10III systemd-journald[667]: Suppressed 115 messages from ofono.service
Nov 30 14:04:04 Xperia10III ofonod[3320]: imsradio0 < 7 requestRegistrationChange
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    0::IImsR adio....
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0030: 0a 00 00 00 01 00 00 00                             ........
Nov 30 14:04:04 Xperia10III ofonod[3320]: imsradio0 > 4 requestRegistrationChangeResponse
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    0::IImsR adioResp
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0030: 6f 6e 73 65 00 00 00 00  0a 00 00 00 00 00 00 00    onse.... ........
Nov 30 14:04:04 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 14:04:04 Xperia10III ofonod[3320]:   0040: 78 71 67 0b 7b 00 00 00  10 00 00 00 00 00 00 00    xqg.{... ........
  • Roaming from Always allow to Do not allow
Nov 30 14:08:31 Xperia10III systemd-journald[667]: Suppressed 262 messages from ofono.service
Nov 30 14:08:31 Xperia10III ofonod[3320]: imsradio0 < 7 requestRegistrationChange
Nov 30 14:08:31 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:08:31 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:08:31 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    0::IImsR adio....
Nov 30 14:08:31 Xperia10III ofonod[3320]:   0030: 0b 00 00 00 00 00 00 00                             ........
Nov 30 14:08:31 Xperia10III ofonod[3320]: imsradio0 > 4 requestRegistrationChangeResponse
Nov 30 14:08:31 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    0::IImsR adioResp
Nov 30 14:08:31 Xperia10III ofonod[3320]:   0030: 6f 6e 73 65 00 00 00 00  0b 00 00 00 00 00 00 00    onse.... ........
Nov 30 14:08:31 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
Nov 30 14:08:31 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:08:31 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 14:08:31 Xperia10III ofonod[3320]: imsradio0 > 4 registrationChanged
Nov 30 14:08:32 Xperia10III ofonod[3320]: imsradio0 > 4 registrationChanged
Nov 30 14:08:32 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:08:32 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:08:32 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:08:32 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 14:08:32 Xperia10III ofonod[3320]: imsradio0 < 31 setSuppServiceNotification
Nov 30 14:08:32 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    0::IImsR adio....
Nov 30 14:08:32 Xperia10III ofonod[3320]: imsradio0 > 28 setSuppServiceNotificationResponse
Nov 30 14:08:32 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    0::IImsR adioResp
Nov 30 14:08:32 Xperia10III ofonod[3320]:   0030: 6f 6e 73 65 00 00 00 00  0c 00 00 00 00 00 00 00    onse.... ........
Nov 30 14:08:32 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
  • Deactivate Mobile Internet again
Nov 30 14:11:37 Xperia10III ofonod[3320]: Deactivating context: 1
Nov 30 14:11:37 Xperia10III ofonod[3320]: Clearing active context
Nov 30 14:11:37 Xperia10III ofonod[3320]: Deactivated data call
Nov 30 14:11:37 Xperia10III systemd-journald[667]: Suppressed 105 messages from ofono.service
Nov 30 14:11:37 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
Nov 30 14:11:37 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:11:37 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:11:37 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:11:37 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 14:11:37 Xperia10III ofonod[3320]: imsradio0 > 4 registrationChanged
Nov 30 14:11:37 Xperia10III ofonod[3320]: imsradio0 < 7 requestRegistrationChange
Nov 30 14:11:37 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    0::IImsR adio....
Nov 30 14:11:37 Xperia10III ofonod[3320]:   0030: 0d 00 00 00 00 00 00 00                             ........
Nov 30 14:11:37 Xperia10III ofonod[3320]: imsradio0 > 4 requestRegistrationChangeResponse
Nov 30 14:11:37 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    0::IImsR adioResp
Nov 30 14:11:37 Xperia10III ofonod[3320]:   0030: 6f 6e 73 65 00 00 00 00  0d 00 00 00 00 00 00 00    onse.... ........
Nov 30 14:11:43 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
Nov 30 14:11:43 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:11:43 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:11:43 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:11:43 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
  • Activate Mobile Internet again
Nov 30 14:13:01 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 14:13:01 Xperia10III ofonod[3320]: setting up data call
  • Deactivate Select Network automatially
Nov 30 14:14:03 Xperia10III ofonod[3320]: [gbinder-radio] WARNING! 2e676e69 unexpected ack
  • Select vodafone IT
Nov 30 14:14:39 Xperia10III ofonod[3320]: slot1 nw select manual: 22210
Nov 30 14:14:42 Xperia10III systemd-journald[667]: Suppressed 387 messages from ofono.service
Nov 30 14:14:42 Xperia10III ofonod[3320]: imsradio0 > 6 serviceStatusChanged
Nov 30 14:14:42 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:14:42 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:14:42 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:14:42 Xperia10III ofonod[3320]: imsradio0 > 4 registrationChanged
Nov 30 14:14:42 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 14:14:42 Xperia10III ofonod[3320]: imsradio0 < 7 requestRegistrationChange
Nov 30 14:14:42 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    0::IImsR adio....
Nov 30 14:14:42 Xperia10III ofonod[3320]:   0030: 0f 00 00 00 00 00 00 00                             ........
Nov 30 14:14:42 Xperia10III ofonod[3320]: imsradio0 > 4 requestRegistrationChangeResponse
Nov 30 14:14:42 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    0::IImsR adioResp
Nov 30 14:14:42 Xperia10III ofonod[3320]:   0030: 6f 6e 73 65 00 00 00 00  0f 00 00 00 00 00 00 00    onse.... ........
Nov 30 14:14:45 Xperia10III ofonod[3320]: imsradio0 > 4 registrationChanged
Nov 30 14:14:45 Xperia10III ofonod[3320]:   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
Nov 30 14:14:45 Xperia10III ofonod[3320]:   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
Nov 30 14:14:45 Xperia10III ofonod[3320]:   0020: 30 3a 3a 49 49 6d 73 52  61 64 69 6f 49 6e 64 69    0::IImsR adioIndi
Nov 30 14:14:45 Xperia10III ofonod[3320]:   0030: 63 61 74 69 6f 6e 00 00  85 2a 74 70 00 00 00 00    cation.. .*tp....
Nov 30 14:14:45 Xperia10III ofonod[3320]: Clearing active context
Nov 30 14:14:46 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 14:14:46 Xperia10III ofonod[3320]: Unexpected data call status 33
  • Mobile Internet say now Enabled but it does not work.
Nov 30 14:16:07 Xperia10III ofonod[3320]: Activating context: 1
Nov 30 14:16:07 Xperia10III ofonod[3320]: setting up data call
@flypig @PeegeeTips @jameson Is it a question of the OS handling a specific case or is it Vodafone Italy’s the responsibility to make this work? Why does it work in Germany?
The phone works with Vodafone Italy under Android, and Vodafone Italy works with other phones under SailfishOS. Therefore, it must be a borderline case that is badly managed by Xperia 10 III AOSP and is triggered only by specific providers.
I really don’t know:
I’m working under the assumption that the ofono component in SFOS that handles mobile data connections with telecom providers has a difficult job, i.e. there isn’t a single absolute methodology to hand-shake a 3G/4G/5G data service.
Jolla have probably spent their limited resources in getting the ofono component to successfully hand-shake a data connection with:
a) the most ‘standard’ connection types
b) the most popular telecom providers (where that is not the same as #1)
And what we have here is that TalkMobile is neither very standard, or very popular, and the ofono component simply does not yet support the quirks of this telecom provider. The billions android and ios have invested in them mean that they have long since covered these quirks - and to a degree their scale forces telecom providers to adapt to them (the chrome effect).
My hope is that the logs will reveal these quirks, such that ofono can be adapted to cover these edge-cases. But to a degree, this will always be a reactive effort based on user reported problems - given the resources Jolla have to develop the ofono component.
Warning - this is nothing but my speculation.
Note - that I have supported Jolla/SFOS despite the above being my understanding of the state of play. I believe that having alternative platforms is valuable.
I feel I do my bit in buying a SFOS licence for every Sailfish-X device that is released - despite me never using my XperiaX, never owning a Xperia 10, and perhaps never flashing my Xperia 10ii.
But this support cannot be sustained indefinately, i do need mobile data, and I am being told by Talkmobile that 3G services that my XA2 depends upon will be switched off in the New Year.
Fingers crossed…
