Xperia 10 III: audio output detection stops after a while (headphones)
REPRODUCIBILITY: 75% (often)
OSVERSION: 4.5.0.19
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.1.20 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
REGRESSION: not specified
After a while the detection of my audio output stops randomly working after a while. A reboot always helped. Deplugging yhe headphones stops music, so there is at least somehow a recognition given. But it is not possible to route the output correctly. Using audio output chooser nothing happens.
Also killing pulseaudio seems to do the job.
1.audio output via headphones stops randomly, audio is routed via speaker
2. reboot or kill pulseaudio
3. everything fine again
EXPECTED RESULTS:
audio routing always works correctly
ACTUAL RESULTS:
sometimes audio is always routed to main speaker and not to headphones
  • Patchmanager: no
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
not update from a previous version but flashed
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.9+git4
For the specific reason that I lost my NuraPro BT buds (very angry) I tried to use my Shure wired earplugs on my 10iii v. 4.5.0.19
The connection is totally flakey and unusable. I initially assumed that the HW port on the phone was defective, however the Shures work on my Mac.
I haven’t tried the pulse audio suggestion
YMMV
