WiFi Login Dialog - Check box not clickable - cannot login to wifi
BUILD ID = OS VERSION (Settings > About product): 4.2.0.21 (Verla)
HARDWARE (XA2, X10, X10 II, …): XA2 Plus
UI LANGUAGE: English
Checkbox is not clickable in wifi login dialog - thus i cannot login to the wifi network. Well, i can click on the checkbox, but the checkbox does not stay checked (you see it getting the focus, but nothing happens).
However when i enter the domain into the normal SFOS browser i can click on the checkbox without problems and login to the network.
For some reason the wifi login dialog browser behaves different than the stock SFOS browser in regards to the checkboxes.
In Germany, go to e.g. McDonalds or real Supermarket and try to login to the wifi network provided.
  1. Connect to the wifi network.
  2. Wifi login dialog opens
  3. you cannot click on the checkbox to confirm the terms&conditions.
The checkbox for the T&C is clickable as it is in the normal SFOS browser.
The checkbox cannot be selected - you see it getting the focus, but no persistent check mark.
Thus you cannot login to the wifi network.
This has already been reported on the release of SFOS 4.1. and also confirmed for 4.2. e.g.:
one workaround is to open the browser and navigate to a non-ssl page such as: http://neverssl.com. This will redirect you to the captive portal of the wifi and you can probably click the checkbox and accept terms and conditions
This still exists on 5.x. :frowning:
