USB-C to USB-C charging does not work reliably on my Jolla Phone 2026
REPRODUCIBILITY: Always
OS VERSION: Sailfish OS 5.2.0.17 (Finlayson)
HARDWARE: Jolla Phone 2026
UI LANGUAGE: Czech
REGRESSION: Unknown / noticed recently
USB-C to USB-C charging does not work reliably on my Jolla Phone 2026.
With several different USB-C chargers and USB-C to USB-C cables, the phone initially detects the charger, but charging disconnects again almost immediately and repeatedly reconnects/disconnects.
USB-A to USB-C charging works normally and is stable, including when using the same charger if it provides both USB-A and USB-C outputs.
The problem occurs with both orientations of the USB-C connector at the phone.
  1. Connect a USB-C charger to the phone using a USB-C to USB-C cable.
  2. The phone detects the charger.
  3. Charging starts or the charging icon appears.
  4. After a very short time charging disconnects.
  5. The Type-C/PD connection then repeatedly reconnects and disconnects.
The phone should charge continuously using a USB-C to USB-C cable.
Kernel log repeatedly shows a sequence similar to:
TCPC-TYPEC:** Attached.SNK
pd_tcp_notifier_call: sink vbus mv:5000, ma:3000
TCPC-PE:PD → SNK_START
TCPC-PE:PD → SNK_WAIT_CAP
TCPC-PE:PD → SNK_EVA_CAP
TCPC-PE:PD → SNK_SEL_CAP
TCPC-PE:PD → SNK_TRANS_SINK
mtk_ctd: pd_tcp_notifier_call Charger plug out
TCPC-TYPEC:Attached-> NULL
TCPC-TYPEC:** Unattached.SNK
The cable is not physically disconnected when Charger plug out is reported.
In contrast, USB-A to USB-C works normally. During a working A-to-C charge the charger reports approximately:
VBUS = 4479mV
IBUS = 2014mA
VBAT = 3914mV
IBAT = 2047mA
chg_en = 1
POWERED-OFF TEST
The issue also occurs when the phone is powered off.
With USB-C to USB-C:
  • Jolla logo appears
  • red LED lights
  • charger/cable graphic briefly appears
  • the display turns off
  • red LED then starts blinking
  • normal powered-off charging screen does not remain active
With USB-A to USB-C:
  • powered-off charging works normally
  • battery percentage and charging graphic are displayed
  • no blinking red LED
This suggests the problem is below the normal Sailfish OS userspace level.
ADDITIONAL TESTS
  • Tested multiple USB-C chargers
  • Tested multiple USB-C to USB-C cables
  • Tested both orientations of the USB-C connector
  • Both connector orientations show the same failure
  • USB-A to USB-C is stable
  • Battery and normal charging path appear to work correctly via USB-A
I can provide full kernel logs from both the failing USB-C-to-USB-C case and the working USB-A-to-USB-C case.
Could other Jolla Phone 2026 owners please confirm whether USB-C to USB-C charging works normally for them?
Mine works fine, both with charger or plugged in computer.
this is a known issue that was mostly resolved with recent updates …Jolla said there is still compatibility issues with some different chargers
duplicate of this Charging JP 2026 does not work
I have a batch 2 device, and mine also works - apple branded usb-c to usb-c cable, charging either from pd-cabable laptop or 2 usb-c pd chargers (anker and ikea). However, If i wobble the cable a bit, I can see in the logs that the connection sometimes is interrupted, and then promptly restored - sounds a bit like a hardware (port) issue in that regard. Firmware 5.2.0.17 here
I connect often Jolla 2026 to computer with USB A. Usually it is on developer or NPT mode. It charges also on those modes. Also charger which output is 5 V 2 A works fine.
For all reporters!
It’s useful if you also add the information about Power delivery (PD) and Quick charge (QC) about chargers you test.
Update after further testing:
I tested the phone with several charger/cable combinations. Both USB-C cables work correctly with another USB-C charger (about 3 A charging current). The problematic chargers also charge my Samsung phone normally, including fast charging.
So this appears to be a charger compatibility / USB-PD negotiation issue rather than faulty cables or a defective USB-C port. This also seems consistent with Jolla’s known issue that some chargers, particularly PD 3.0 chargers, may fail to charge the Jolla Phone.
It works as it should on mine.
I have 2 Apple chargers and cables (the fast charging cables and 18+20W brick) that I use for every type of device that doesn’t have MagSafe/QI2 charging.
Every single device that was reported to have issues with specific chargers, always works with these chargers for me.
My 10 III that is picky with cables, some handhelds that need older type A to C, some vapes, Jolla phones etc, every single thing worked every time without issues.
Might be worth getting one cable / charger set if you didn’t have one already and return it if it doesn’t work.
Additional test: Samsung EP-TA800 25W USB-C charger works correctly with Jolla Phone 2026 over USB-C to USB-C.
During the test:
BAT 73% | Charging | current=3355300 uA | charger=2
The EP-TA800 also supports USB Power Delivery 3.0 / PPS, so the issue does not appear to be caused by PD 3.0 in general. It seems to be a compatibility/interoperability problem with some specific USB-C PD chargers or PD implementations.
Current results:
  • AlzaPower A100 Fast Charge 20W, PD 3.0: unreliable / repeated disconnects
  • Samsung EP-TA800 25W, PD 3.0 + PPS: works
  • TRONIC USB-C charger: works
  • Multiple USB-C cables tested successfully with the working chargers
Here’s what I experience with my Jolla Phone (2026) Batch 1:
  • My Anker 100W charger ( Amazon.de ) charges it perfectly fine and fast without any issues
  • Connecting the Jolla Phone to my Framework 13 AMD 7840U has constant connect/disconnect and can’t establish a reliable connection with the laptop. The phone’s battery charges at an unbearably slow rate, but still charges.
  • Connecting the Jolla Phone to my work MacBook Pro also charges super slowly and I suspect it’s constantly connecting/disconnecting, but this isn’t reflected in macOS
  • My Steam Deck LCD charger works perfectly fine, but isn’t a USB-C to USB-C charger
JP2026 is still picky for some chargers
i use 8port (4x usbC up to30W, 4x usbA 12W) by Sologic,
dual port GaN2 20W on PD also by Sologic,
dual port GaN3 65W on PD by Sitecom - very fast charging.
does not charge on GaN 30W PD by Sitecom
all above are cheap and purchased in local Action store
all old chargers like apple, jolla, nonames - works fine.
Hi @mipal75.
Would you consider marking this post as solution?
As the bug report is not anymore true. And for the real issue there is another one.
My Jolla Phone 2026 has an equal problem. The phone has worked like an angel from start-up late July 2026 (Batch#1). But during last night a battery drain. Usb-c / usb-c , usb-A-usb-c / usb-c charging won’t work. No charging at all. Connection to pc won’t help either. I have now closed my Jolla. Waiting for an update or something.
Tested chargers without any success:
1. My Jolla Phone 2026 charger: Belkin 30 W USB PD usb-c wall charger.
(Has worked excellent from late July 2026.)
2. My android phone has: Mobique 20 W PD wall charger usb-c-usb-c.
3. One of my watches has: Apple usb-A 1 A / 5 V.
4. Old Jolla Phone 1 charger.
5. Old Sony charger of Xperias.
6. And lately pc lap top.
PS. Jolla Phone has shown every now and then indications of some level battery drain during the time, but it has been allways able to be charged before today.
A few days ago I noticed an interesting phenomenom while trying to charge my Jolla Phone from a battery bank via USB -C cable: the phone didn’t charge, but instead the leds in the bank indicated that IT was charging.
I quickly changed to old fashioned USB cable and charging worked fine with that.
Same issue here, after a curious battery drain yesterday, all my chargers (USB-C) don’t charge anymore. I found an old USB-A charger and with an adaptor (USB-A > USB-C) it still charges but very slowly…
Can’t access to an usb key or a ssd anymore, all the USB-C interface seems to be dead.
Great, with the dust issue in my front cam, that’s perfect… \o/
Even after reboot?
123
Update – detailed charging diagnostics on Sailfish OS 5.2.0.18
I performed additional tests using the kernel charging/USB-PD logs.
Samsung EP-TA800 25 W, USB-C to USB-C:
Works correctly. The phone establishes USB Power Delivery with PPS. The charger exposes a PPS/APDO range up to 11 V / 2.75 A and the MediaTek charging stack selects it. During charging the phone requests up to approximately 9.8 V / 2.55 A, with measured input around 8.9 V / 2.46 A (~22 W). So USB-PD/PPS and the USB-C CC communication clearly work correctly with this charger.
AlzaPower Qualcomm Quick Charge 3.0 charger, USB-C to USB-C:
No PD/PPS negotiation takes place. The Type-C layer correctly detects the source as advertising 5 V / 3 A, but the charging framework subsequently limits the input to only 500 mA. Measured input is approximately 5.07 V / 0.49 A (~2.5 W).
Relevant log lines include:
TYPE-C Only Charger!
while the charger configuration is subsequently:
CC = 500mA, IBUS-AICR = 500mA
AlzaPower A100 Fast Charge 20 W, USB PD 3.0:
On my latest test, connecting this charger caused the phone to reboot immediately. I have not intentionally repeated this test yet.
These results make a general USB-C connector fault unlikely: the same phone and connector successfully negotiate full USB-PD PPS charging with the Samsung charger.
This looks more like a charger interoperability / Type-C / PD charging-policy issue. In particular, in the non-PD case the kernel detects a 5 V / 3 A Type-C source but the charging framework limits it to 500 mA.
I can provide the complete kernel logs for all three cases if useful.
Hi mipal75,
Thank you for the all info.
Is it safe for JP2026 battery to use that Smsng EP-TA-800 charger? I happen to have it for my Smsng tablet. It’s fabricated 22.8.2022.
Thank you for the confirmation.
