Feb 20 22:32:33 Sailfish mce[2863]: modules/display.c: mdy_stm_step(): forced brightness sync to: 2
Feb 20 22:32:33 Sailfish mce[2863]: modules/display.c: mdy_stm_set_compositor_availability_changed(): compositor availability change: handled
Feb 20 22:32:33 Sailfish kernel: [synaptics][info] synaptics_rmi4_suspend: synaptics suspend +++
Feb 20 22:32:33 Sailfish kernel: [synaptics][info] synaptics_rmi4_suspend: synaptics suspend —
Feb 20 22:32:33 Sailfish kernel: [synaptics][info] synaptics_rmi4_resume: synaptics resume +++
Feb 20 22:32:33 Sailfish kernel: [synaptics][info] synaptics_rmi4_resume: synaptics resume —
Feb 20 22:32:33 Sailfish systemd[1]: Started OS update logging.
Feb 20 22:32:33 Sailfish kernel: somc_panel_pcc_setup: color_tbl not available: no pcc.
Feb 20 22:32:33 Sailfish su[2965]: (to root) root on none
Feb 20 22:32:33 Sailfish quotacheck[2941]: Cannot get exact used space… Results might be inaccurate.
Feb 20 22:32:33 Sailfish su[2965]: pam_systemd(su-l:session): Using 600s D-Bus method call timeout
Feb 20 22:32:33 Sailfish kernel: somc_panel_pa_v2_setup (572):sat=0 hue=0 val=0 cont=0
Feb 20 22:32:33 Sailfish kernel: EXT4-fs (dm-1): re-mounted. Opts: (null)
Feb 20 22:32:33 Sailfish kernel: [synaptics][info] synaptics_rmi4_irq_enable: Interrupt already enabled
Feb 20 22:32:33 Sailfish systemd[1]: Reached target System Update.
Feb 20 22:32:33 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=osupdate-logging comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Increasing the SSU version to 4.0.1.48
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: [system] Activating via systemd: service name=‘org.nemo.ssu’ unit=‘dbus-org.nemo.ssu.service’ requested by ‘:1.7’ (uid=0 pid=2951 comm="/usr/libexec/sailfish-upgrade-ui")
Feb 20 22:32:33 Sailfish mce[2863]: modules/display.c: mdy_display_state_enter(): current display state = ON
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: dbus-daemon[2870]: [system] Activating via systemd: service name=‘org.nemo.ssu’ unit=‘dbus-org.nemo.ssu.service’ requested by ‘:1.7’ (uid=0 pid=2951 comm="/usr/libexec/sailfish-upgrade-ui")
Feb 20 22:32:33 Sailfish systemd[1]: Started Enable quota and run quotacheck for home.
Feb 20 22:32:33 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=quota@home comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:33 Sailfish audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=quota@home comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:33 Sailfish systemd[1]: Created slice system-oneshot\x2duser\x2dlate\x2dprivileged.slice.
Feb 20 22:32:33 Sailfish systemd[1]: Starting Oneshot stuff for privileged user (late run)…
Feb 20 22:32:33 Sailfish systemd[1]: Created slice system-oneshot\x2duser\x2dprivileged.slice.
Feb 20 22:32:33 Sailfish systemd[1]: Starting Oneshot stuff for privileged users…
Feb 20 22:32:33 Sailfish systemd[1]: Starting SSU service…
Feb 20 22:32:33 Sailfish systemd[1]: Created slice user-0.slice.
Feb 20 22:32:33 Sailfish systemd[1]: user@0.service: Failed to load environment files: No such file or directory
Feb 20 22:32:33 Sailfish systemd[1]: user@0.service: Failed to run ‘start-pre’ task: No such file or directory
Feb 20 22:32:33 Sailfish systemd[1]: Failed to start User Manager for UID 0.
Feb 20 22:32:33 Sailfish oneshot[2996]: find: /etc/oneshot.d/0/late/privileged/: No such file or directory
Feb 20 22:32:33 Sailfish systemd[1]: user@0.service: Unit entered failed state.
Feb 20 22:32:33 Sailfish systemd[1]: user@0.service: Failed with result ‘resources’.
Feb 20 22:32:33 Sailfish oneshot[2999]: find: /etc/oneshot.d/0/privileged/: No such file or directory
Feb 20 22:32:33 Sailfish systemd[1]: Started Oneshot stuff for privileged user (late run).
Feb 20 22:32:33 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=oneshot-user-late-privileged@0 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:33 Sailfish systemd[1]: Started Oneshot stuff for privileged users.
Feb 20 22:32:33 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=oneshot-user-privileged@0 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:33 Sailfish systemd[1]: Started Session c1 of user root.
Feb 20 22:32:33 Sailfish su[2965]: pam_systemd(su-l:session): Failed to create session: Start job for unit user@0.service failed with ‘failed’
Feb 20 22:32:33 Sailfish su[2965]: pam_unix(su-l:session): session opened for user root by (uid=0)
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: [system] Successfully activated service ‘org.nemo.ssu’
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: dbus-daemon[2870]: [system] Successfully activated service ‘org.nemo.ssu’
Feb 20 22:32:33 Sailfish systemd[1]: Started SSU service.
Feb 20 22:32:33 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=dbus-org.nemo.ssu comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: [system] Activating via systemd: service name=‘org.freedesktop.UDisks2’ unit=‘udisks2.service’ requested by ‘:1.10’ (uid=0 pid=3023 comm="/usr/bin/udisksctl mount -b /dev/mmcblk1p1")
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: dbus-daemon[2870]: [system] Activating via systemd: service name=‘org.freedesktop.UDisks2’ unit=‘udisks2.service’ requested by ‘:1.10’ (uid=0 pid=3023 comm="/usr/bin/udisksctl mount -b /dev/mmcblk1p1")
Feb 20 22:32:33 Sailfish systemd[1]: Starting Disk Manager…
Feb 20 22:32:33 Sailfish usb_moded[2851]: CONFIGFS not detected
Feb 20 22:32:33 Sailfish usb_moded[2851]: ANDROID0 not detected
Feb 20 22:32:33 Sailfish udisksd[3034]: udisks daemon version 2.8.1 starting
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: [system] Activating via systemd: service name=‘org.freedesktop.PolicyKit1’ unit=‘dbus-org.freedesktop.PolicyKit1.service’ requested by ‘:1.11’ (uid=0 pid=3034 comm="/usr/libexec/udisks2/udisksd")
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: dbus-daemon[2870]: [system] Activating via systemd: service name=‘org.freedesktop.PolicyKit1’ unit=‘dbus-org.freedesktop.PolicyKit1.service’ requested by ‘:1.11’ (uid=0 pid=3034 comm="/usr/libexec/udisks2/udisksd")
Feb 20 22:32:33 Sailfish systemd[1]: Starting Authorization Manager…
Feb 20 22:32:33 Sailfish polkitd[3040]: started daemon version 0.105 using authority implementation local' version 0.105’
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: [system] Successfully activated service ‘org.freedesktop.PolicyKit1’
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: dbus-daemon[2870]: [system] Successfully activated service ‘org.freedesktop.PolicyKit1’
Feb 20 22:32:33 Sailfish systemd[1]: Started Authorization Manager.
Feb 20 22:32:33 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=dbus-org.freedesktop.PolicyKit1 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: [system] Activating via systemd: service name=‘org.freedesktop.PackageKit’ unit=‘packagekit.service’ requested by ‘:1.7’ (uid=0 pid=2951 comm="/usr/libexec/sailfish-upgrade-ui")
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: dbus-daemon[2870]: [system] Activating via systemd: service name=‘org.freedesktop.PackageKit’ unit=‘packagekit.service’ requested by ‘:1.7’ (uid=0 pid=2951 comm="/usr/libexec/sailfish-upgrade-ui")
Feb 20 22:32:33 Sailfish systemd[1]: Starting PackageKit Daemon…
Feb 20 22:32:33 Sailfish PackageKit[3047]: daemon start
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: [system] Successfully activated service ‘org.freedesktop.PackageKit’
Feb 20 22:32:33 Sailfish systemd[1]: Started PackageKit Daemon.
Feb 20 22:32:33 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=packagekit comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:33 Sailfish dbus-daemon[2870]: dbus-daemon[2870]: [system] Successfully activated service ‘org.freedesktop.PackageKit’
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Querying repositories
Feb 20 22:32:33 Sailfish packagekitd[3047]: [packagekit-zypp] Setting target on init: /home/.zypp-cache
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: adaptation0, adaptation0
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: adaptation1, adaptation1
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: aliendalvik, aliendalvik
Feb 20 22:32:33 Sailfish PackageKit[3047]: get-repo-list transaction /7127_dbdbabee from uid 0 finished with success after 194ms
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: apps, apps
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: customer-jolla, customer-jolla
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: hotfixes, hotfixes
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: jolla, jolla
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-Allstar12345, openrepos-Allstar12345
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-KeeperoftheKeys, openrepos-KeeperoftheKeys
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-Mister_Magister, openrepos-Mister_Magister
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-Osanwe, openrepos-Osanwe
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-ade, openrepos-ade
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-ahappyhuman, openrepos-ahappyhuman
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-balta, openrepos-balta
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-beidl, openrepos-beidl
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-birdzhang, openrepos-birdzhang
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-coderus, openrepos-coderus
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-cy8aer, openrepos-cy8aer
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-direc85, openrepos-direc85
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-dysko, openrepos-dysko
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-equeim, openrepos-equeim
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-ichthyosaurus, openrepos-ichthyosaurus
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-karin_zhao, openrepos-karin_zhao
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-kif, openrepos-kif
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-neochapay, openrepos-neochapay
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-nodevel, openrepos-nodevel
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-onion, openrepos-onion
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-osetr, openrepos-osetr
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-planetos, openrepos-planetos
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-planetos_store, openrepos-planetos_store
Feb 20 22:32:33 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-pulsar541, openrepos-pulsar541
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-slava, openrepos-slava
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-steffen_f, openrepos-steffen_f
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-syrja, openrepos-syrja
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: openrepos-vasvlad, openrepos-vasvlad
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: sailfish-eas, sailfish-eas
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: store, store
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Enabled repository: xt9, xt9
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of store to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: uid 0 is trying to obtain org.freedesktop.packagekit.system-sources-configure auth (only_trusted:0)
Feb 20 22:32:34 Sailfish PackageKit[3047]: uid 0 obtained auth for org.freedesktop.packagekit.system-sources-configure
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7128_cadccccc from uid 0 finished with success after 30ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-vasvlad to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7129_aeebbdee from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-syrja to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7130_abcaaeed from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-steffen_f to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7131_cdadddac from uid 0 finished with success after 28ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-slava to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7132_becabeea from uid 0 finished with success after 28ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-pulsar541 to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7133_eaaebdbc from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-planetos_store to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7134_ecdbadee from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-planetos to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7135_aebedeed from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-osetr to false
Feb 20 22:32:34 Sailfish usb_moded[2851]: CONFIGFS not detected
Feb 20 22:32:34 Sailfish usb_moded[2851]: ANDROID0 not detected
Feb 20 22:32:34 Sailfish systemd[1]: user@0.service: Service hold-off time over, scheduling restart.
Feb 20 22:32:34 Sailfish systemd[1]: Stopped User Manager for UID 0.
Feb 20 22:32:34 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user@0 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:34 Sailfish audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=user@0 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:34 Sailfish systemd[1]: user@0.service: Failed to load environment files: No such file or directory
Feb 20 22:32:34 Sailfish systemd[1]: user@0.service: Failed to run ‘start-pre’ task: No such file or directory
Feb 20 22:32:34 Sailfish systemd[1]: Failed to start User Manager for UID 0.
Feb 20 22:32:34 Sailfish systemd[1]: user@0.service: Unit entered failed state.
Feb 20 22:32:34 Sailfish systemd[1]: user@0.service: Failed with result ‘resources’.
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7136_adaeaacb from uid 0 finished with success after 28ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-onion to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7137_dbebebed from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-nodevel to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7138_dbebcbdb from uid 0 finished with success after 28ms
Feb 20 22:32:34 Sailfish dbus-daemon[2870]: [system] Successfully activated service ‘org.freedesktop.UDisks2’
Feb 20 22:32:34 Sailfish dbus-daemon[2870]: dbus-daemon[2870]: [system] Successfully activated service ‘org.freedesktop.UDisks2’
Feb 20 22:32:34 Sailfish systemd[1]: Started Disk Manager.
Feb 20 22:32:34 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=udisks2 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-neochapay to false
Feb 20 22:32:34 Sailfish udisksd[3034]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7139_eeaaeead from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-kif to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7140_dcacabed from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-karin_zhao to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7141_bdbccced from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-ichthyosaurus to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7142_bddcbbdb from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-equeim to false
Feb 20 22:32:34 Sailfish kernel: FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Feb 20 22:32:34 Sailfish udisksd[3034]: Mounted /dev/mmcblk1p1 at /run/media/root/SOESD on behalf of uid 0
Feb 20 22:32:34 Sailfish udisksctl-user[2928]: Mounted /dev/mmcblk1p1 at /run/media/root/SOESD.
Feb 20 22:32:34 Sailfish su[2965]: pam_unix(su-l:session): session closed for user root
Feb 20 22:32:34 Sailfish systemd[1]: Started Handle udisks sd mount.
Feb 20 22:32:34 Sailfish audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=mount-sd@mmcblk1p1 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7143_dbadddee from uid 0 finished with success after 30ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-dysko to false
Feb 20 22:32:34 Sailfish systemd[1]: Removed slice user-0.slice.
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7144_aaebeeed from uid 0 finished with success after 28ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-direc85 to false
Feb 20 22:32:34 Sailfish PackageKit[3047]: repo-enable transaction /7145_cebcccde from uid 0 finished with success after 27ms
Feb 20 22:32:34 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-cy8aer to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7146_cdbcbccb from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-coderus to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: uid 0 is trying to obtain org.freedesktop.packagekit.system-sources-configure auth (only_trusted:0)
Feb 20 22:32:35 Sailfish PackageKit[3047]: uid 0 obtained auth for org.freedesktop.packagekit.system-sources-configure
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7147_eadbedca from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-birdzhang to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7148_aadacacd from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-beidl to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7149_eaccabdb from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-balta to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7150_bbabbeba from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-ahappyhuman to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7151_bbcaecad from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-ade to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7152_bdacbcea from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-Osanwe to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7153_aecedaae from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-Mister_Magister to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7154_ccbaadde from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-KeeperoftheKeys to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7155_deeccbaa from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Setting the enabled state of openrepos-Allstar12345 to false
Feb 20 22:32:35 Sailfish PackageKit[3047]: repo-enable transaction /7156_adeadacb from uid 0 finished with success after 27ms
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Upgrading distribution jolla-configuration-h3113
Feb 20 22:32:35 Sailfish PackageKit[3047]: uid 0 is trying to obtain org.freedesktop.packagekit.upgrade-system auth (only_trusted:0)
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Progress: 101
Feb 20 22:32:35 Sailfish PackageKit[3047]: uid 0 obtained auth for org.freedesktop.packagekit.upgrade-system
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Creating symlink: /var/cache/pk-zypp-cache -> /home/.pk-zypp-dist-upgrade-cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository adaptation0 from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository adaptation1 from disk cache
Feb 20 22:32:35 Sailfish usb_moded[2851]: CONFIGFS not detected
Feb 20 22:32:35 Sailfish usb_moded[2851]: ANDROID0 not detected
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository aliendalvik from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository apps from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository customer-jolla from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository hotfixes from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository jolla from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-Allstar12345 from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-KeeperoftheKeys from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-Mister_Magister from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-Osanwe from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-ade from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-ahappyhuman from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-balta from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-beidl from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-birdzhang from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-coderus from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-cy8aer from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-direc85 from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-dysko from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-equeim from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-ichthyosaurus from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-karin_zhao from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-kif from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-neochapay from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-nodevel from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-onion from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-osetr from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-planetos from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-planetos_store from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-pulsar541 from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-slava from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-steffen_f from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-syrja from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository openrepos-vasvlad from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository sailfish-eas from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository store from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Reloading repository xt9 from disk cache
Feb 20 22:32:35 Sailfish packagekitd[3047]: [packagekit-zypp] Switching target with hot pool: /home/.zypp-cache -> /home/.pk-zypp-dist-upgrade-cache
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Progress: 0
Feb 20 22:32:35 Sailfish sailfish-upgrade-ui[2951]: Progress: 100
Feb 20 22:32:36 Sailfish usb_moded[2851]: CONFIGFS not detected
Feb 20 22:32:36 Sailfish usb_moded[2851]: ANDROID0 not detected
Feb 20 22:32:37 Sailfish usb_moded[2851]: CONFIGFS not detected
Feb 20 22:32:37 Sailfish usb_moded[2851]: ANDROID0 not detected
Feb 20 22:32:38 Sailfish usb_moded[2851]: CONFIGFS not detected
Feb 20 22:32:38 Sailfish usb_moded[2851]: ANDROID0 not detected
Feb 20 22:32:39 Sailfish usb_moded[2851]: CONFIGFS not detected
Feb 20 22:32:39 Sailfish usb_moded[2851]: ANDROID0 not detected
Feb 20 22:32:40 Sailfish packagekitd[3047]: [packagekit-zypp] Before commit: 861 downloads, 861 installs, 24 removals
Feb 20 22:32:40 Sailfish packagekitd[3047]: [packagekit-zypp] Byte sizes: 0 download, 1575023572 install, 1508114005 remove, 739265268 cached
