You don’t understand what I mean.
To do the gesture ambidextrous you need to do “both” sides gesture, when in case of the bottom/top there is only 1 direction. Sides are more “aligned” with going between apps, apps pages or going forward/back in a web browser. Minimising an app from the side seems IMO a bit unintuitive.
Of course coming from android, that IMO mastered gestures, but like 2-3 years ago.
@Kanthal On android currently you have:
Pull down from top to open quick setting → 1 more pull to notifications
Short pull from sides to go back (“global back button”), but you need to pull and let go (SFOS does the same)
Short pull up from bottom to minimise
Pull & hold from bottom to enter multitasking|
Swipe right or left at the bottom bar to enter previous or next app in the multitasking list
Every gesture is giving haptic feedback unless you turn it off.
Because there are options like you pull & hold and it gives different outcome it’s hard to mix up.
So in my opinion Jolla could do the swipe from bottom with hold & let go to minimise and to for example pull & hold from the top to close, so then this gestures would work in the center and on sides, no need to put the finger on top left/right and swipe down.
