UI and gestures in SFOS - Off topic
True. SFOS simply didn’t have a top menu back then, and the whole top edge was reserved for closing apps/locking device.
I only wish Jolla would bring that back ( or at least if possible, have it as an option in settings)
But SFOS never had a diagonal gesture!
? Source please, in SFOS 1.x, you could swipe from the whole top edge to close an app, what would have benn the point of doing a diagonal?..
You are right - you are kinda holding the phone with a thumb, so thumb is closest to edge of right/left depending on the hand you use.
Then maybe browser could get a specific back gesture as a substitute for the lack of ability to swipe left/right between subpages?
Well, I was having connection issues on my XA2+, so I was constantly checking if I’m connected to a Wifi network, or something else failed. Looking for notifications also happened, but not a lot, because for now I don’t even have apps, that send notifications as I flashed SFOS again on XA2+ day ago (I think I need a reflash or something - once Wifi disconnects, once finger print reader stops working).
Yeah, I try, but fail miserably ;_;
Yeah, that’s fair.
Can’t tell, as I was not using for the last 10 years, as a person who jumped to SFOS recently (I was only eyeing SFOS for last 10 years, as I had no device to run it) I think it just needs some improvements. Compared to Android in this 10 years - I 100% agree. Android is just catching up in this area, iOS too.
Sorry, you ate totally right, mixed up diagonal with vertical. My bad, closing an app with a diagonal swipe wasnt an option.
Sadly I don’t have a scientific answer to this - I’m not that qualified. I could try to explain what I know, and I might be wrong at this.
In SFOS case we have:
Firmware from SoC/component manufacturers →Android kernel + libraries → libhybris → SFOS→AAS which is in container. AAS is not Open Source, only source available and as far as I see - only for OEM, as AAS is licensed (https://jolla.com/content/uploads/2022/11/App-Support-for-Linux-Platforms-whitepaper-November-2022.pdf?x97614) unless I’m wrong, if I am - pls, correct me
GrapheneOS is just heavily modified AOSP made to run only on Google Pixels, here you can see what features it has, that AOSP doesn’t. Features overview
As I don’t have access to Android App Support on SFOS I cannot confirm/deny that AAS has/hasn’t any of this features, but for now I know, that SFOS doesn’t have - Storage Scopes, Contact Scopes, Wi-Fi privacy, Network permission toggle and these are one I kinda depend on daily basis and many other on the list that work in the background.
SFOS has AAS in LXC container, and GOS has apps in sandboxes including sandboxed Google Services if somebody want’s to use them - I don’t think that AAS has this option, more like a normal Gapps or Microg, but it’s not sandboxed…but the whole Android is so… :smiley:
You can also see this discussion here:
https://old.reddit.com/r/linux/comments/1bpqpxj/a_dive_into_jolla_appsupport_almost_seamless/
So I cannot answer precisely about AAS - It’s not FOSS, somebody might be able to explained this or everything better. Dalvik Turbo virtual machine - Wikipedia
Aah, the doom-scrolling approach. I much prefer the multitasking view SFOS provides.
My read on the guy is that he’s at peak Dunning-Kruger on privacy and seeing something that makes his stuff look like amateur stuff has made him massively insecure. Hence spending at least an hour every day craptalking SailfishOS on here, in this thread about the Jolla 2 phone, which he states he’s not interested in buying anyway.
Complaining that gestures, something the N9 got right 15 years ago and nobody except Jolla has gotten even close to, are crap because they don’t work exactly like Android. Insecurity and sour grapes all the way down.
Sometimes I wonder how the Jolla team keep going. If I had a customer base that behaved in the way that seems way too common on this forum, I’d just shut it all down.
There is one, actually. You need to use the command line for a second to enable it because it’s hidden, but it works just fine, I use it all the time and I’ve never had any issues with it. Just enter this in the terminal and it’ll work:
dconf write /desktop/sailfish/experimental/quickAppToggleGesture true
(Maybe you’ll need to restart the home screen afterwards, not sure.)
Edit: oops, didn’t notice someone else had already mentioned this trick.
Yes, you need to reload the home screen or reboot the phone. Just discovered this trick and it works like a charm!
Too many tips is good :slight_smile:
Been using it the last few days, it was really the missing piece for me, should definitely be enabled, it’s fantastic.
You can use the edge swipe from either side without lifting your finger from the screen. This allows you to peek at the home screen, and see the connection icons at the top of the screen to see if there are any issues, and then drag your finger back to the edge of the screen to return to your current app without minimizing it.
That’s also the solution to accidentally closing apps, if you swipe down and the app starts to disappear, you’re in the ‘kill app’ zone and can just slide your finger back up and swipe from the center.
If you do it with attention - yes, but here is no information other than slightly visual that you are in kill zone, and you only see it if you do a constant pull - not a quick one Try it - you can kill an app with a 0,5 cm pull down. Opening top menu works in the same way, but here it;s totally fine.
When I was holding XA2+ with 1 hand and wanted to deploy top quick setting menu, I just pulled quick enough (and because of weight of this phone kinda missed with the finger), that apps just vanished. If there would be for example haptic feedback when you enter kill gesture, and requirement to pull with the finger to 1/4 that would make it way harder to do by mistake.
I need do point out, that because Pixel 6A on android is quite fast, I’m used to it (and to android gestures, yes) and I just rush XA2+ in the same way, but XA2+ is way slower, so any slack It has - I jump a bit too forward. I know that now and after killing apps by mistake I just go slower when doing something from top, but still - gestures are great, because you can use them super fast, so when you go fast… You get the idea. If I could turn off killing apps this way I would do it, it’s too easy - minimising - totally fine, if you do it by mistake you just open app again, but killing the app, too easy.
Yeah, that would work.
No amount of feedback will save anyone from accidents, if they use the gestures fast enough, because one’s brain has already sent the instruction to their finger to lift up before it registers the haptic or other feedback.
You are right, but still something can be done to make it harder. It’s super easy to kill with a gun intentionally or by mistake, so that’s why there are safety switches - they don’t eliminate all mistakes, but some do.
But it also takes a huge skill issue to shoot the target that’s next to yours even if you shoot for the first time in your life.
Just aim for the teardrop, notch, camera, speaker, whatever is on the dead center. X marks the spot, how can you miss that to the point it becomes an issue that blows out of proportion?
I kinda say that right here - you say gestures are fine, I think they need improvement.
Although gestures are not that dated.
Clearly you also notice, that some stuff could be customisable or improved (GIVE ME AN OPTION TO REMOVE THE LOCK BUTTON FROM TOP MENU - I WANT THIS SPACE :expressionless_face:, patches are outdated ).
BTW XA2/XA2+ has no notch, and big chin/forehead, so top display corner is not top corner of the phone, but it’s not that important. This gesture is just too easy to do not intentionally. Where in case of pulling from left/right I think it’s just not consistent with browser and could be done in a different way - that is more of a preference. The app killing gesture just needs improvement, or an option to turn it off. I’m not blowing this out of proportion - this irritated me a lot. I would turn this gesture off currently, but SFOS navigation has only 1 way - the right way.
@L_A_G I don’t make the title, I joined the discussion, that as far as I see was heated to point, as people have different opinions. Also this topic is pretty much an update post in form of topic, nothing super restrictive. It’s about the new Jolla phone, that runs SFOS - I talk about SFOS, also a bit about new phone (yes, the bootloader stuff).
I also tend to go off topic - just a personality thing, or as my doctor says - ADHD with which being unsure of something (knowledge, skill etc.) is kinda connected. We are talking about phones. Going with "Dunning-Kruger” and calling me and idiot, is not cool. Don’t cosplay as forums psychiatrist.
My reasoning of Qualcomm and Google being more “privacy friendly” I already explained, but it was removed or lost in the “fog of war” - it was just keeping bootloader unlockable and supplying needed libraries to run OS. So it’s not privacy friendly intentionally, but rather by an accident, and also “privacy” as is freedom today. QCM did it, Google did it, MTK does it partially, and OSes are not available. End of this discussion.
What this forum could really need is an “infighting” flag and a way for users to automatically hide these types of posts. A poster could then flag their replies as a “flame war”, and the rest of us could focus on actually interesting discussions.
