Download patches from the internet links, extract the ‘unified_diff.patch’ file, open the file with file browser’s pull down menu. It should install the patch. Good luck!
The patches are made for SFOS 3.4.0.24 and from year 2020/2021
On my Volla, it first seems to work (says ‘installed successfully’), but it has no effect. Both patches don’t work. I will check this file later ‘by hand’ and report.
Right now i installed Patchmanager and tried to install. Patchmanager said it’s incompatible to my SFOS version (…72) on trying to install ‘No Center Clock’, and the description says it’s only compatible up to …58.
The patch ‘No Center Clock (notch)’ works fine on the Volla & SFOS 4.4.0.72 if version check is disabled in Patchmanager! Now time is no more hidden behind the notch but visible in the upper right corner, and I’m happy!
I have a question. Once my husband bought a GS290 with /e/ installed on it.He has had problems with echo cancellation (and mobile internet didn’t work). My Sony 10 III with Sailfish also has echoing during a call. What about the Vollaphone 22/GS5 and Sailfish? Do you have the same problems?
Now, multiboot is working and both SIM are working well in Volla.
I work with SFOS, but SD-Card is not able to crypt.
Ubuntu is not for dayly working for me. Volla is a nice have to and works very good.
I wait for Xperia 10 iV with SFOS, but my XA2 plus is now dead, so i use this time GS5.
Thank you for your answer. I conclude that the trouble with echo must be due to the specific GS290 we have.
With the 10 III it is a well known problem.
I dont know. You are free to experiment, flashing the boot and super images, but you must be confident in your ability to recover. I have never tested this device.
