The Volla 22 (Gigaset GS5) Thread
hi piggz! please give me the sailfish build so I can weld it to my Volla22. thanks in advance! regards!
I installed SFOS on the GS5 yesterday. First of all, thanks for the port @piggz.
After some playing around, I noticed that the notifications always come in very high volume, no matter what you have set in the system.
The WIFI is detected with different frequency bands, so not just one WIFI, but 2 with the same name. In addition, the system forgets the WIFI every time it is restarted.
The regular notch hacks do not work via the patch manager. It would be nice to integrate them into the system right away.
It is also noticeable that the system sometimes hangs, i.e. has a delay in reacting.
Flashed back my Gigaset GS5 from SFOS to Android 13 GSI Image without Google:-)
https://sourceforge.net/projects/andyyan-gsi/files/
Hello Mr. Piggz any update to sailfish 4.5…
for gigaset gs5?
I’m helping test is you want, instructions:
https://paste.mozilla.org/4D7cv3Dj
Looking really good. that’s amazing fast, @piggz !
hello sir
how can i update my gigaset…to this version?
You can either go the route experimental route I linked above, but better is to wait until @piggz takes this live and then it’s simple.
hello mr. piggz any news about release date
sailfish os 4.5…
When it is ready, as always!
Its actually on OBS now … ive not tested it yet though!
OBS???
download link please
On a terminal or ssh connection:
become root: ‘devel-su’
and execute:
ssu re 4.5.0.16
ssu ur
zypper ref
zypper dup
Almost, but .18 !! Setting to .16 will likely break your system
Available release are here
https://build.merproject.org/project/subprojects/nemo:testing:hw:volla:halium-mimameid
How is the situation for the Volla / GS290 at the moment please? What would you suggest at the moment?
https://repo.sailfishos.org/obs/nemo:/testing:/hw:/volla:/yggdrasil:/
i would say situation is: 4.4 is the most current one for a gs290
Thank you @pawel.spoon , want to say I’m very happy with the Volla, only want to stay up to date and not miss something. :slightly_smiling_face:
I have the gs290 on 4.4.0.72 and it has a couple of advantages over the Volla22 on 4.5 (browser) … but I need to update to 4.5.0.18 testing to see if the bugs are out. Still, don’t see much reason to update the gs290 at the moment.
The difference I see between the X10 @ 4.5.0.18 and the Volla @ 4.4.0.72 is only the browser behavior on tap (click) is better on 4.5.0.18, but Browser still crashes frequently. So on Volla I use mostly Firefox / Waydroid, that is slower and doesn’t look so good as the Sailish browser but doesn’t crash.
