EDIT: Alright, the comment stayed after I pushed the update, so it looks like the config wasn’t overwritten. Successfully updated to 4.6 with no further incidents. Which means, now I can continue in recovering from backups.
So far, I only noticed Manufacturer and Product name under ‘About product’ showing UNKNOWN, but that’s about it.
EDIT 2: Camera is not working either.
Think I am gonna revert back on 4.5.0 and stay there for now.
(003446) [22:34:20] % lxc-start -P /var/lib/waydroid/lxc -F -n waydroid -- /init
(003446) [22:34:20] New background process: pid=3647, output=background
lxc-start: waydroid: ../src/lxc/network.c: netdev_configure_server_veth: 711 No such file or directory - Failed to attach "veth7zZ5S2" to bridge "waydroid0", bridge interface doesn't exist
lxc-start: waydroid: ../src/lxc/network.c: lxc_create_network_priv: 3427 No such file or directory - Failed to create network device
lxc-start: waydroid: ../src/lxc/start.c: lxc_spawn: 1840 Failed to create the network
lxc-start: waydroid: ../src/lxc/start.c: __lxc_start: 2107 Failed to spawn container "waydroid"
lxc-start: waydroid: ../src/lxc/conf.c: run_buffer: 322 Script exited with status 126
lxc-start: waydroid: ../src/lxc/start.c: lxc_end: 985 Failed to run lxc.hook.post-stop for container "waydroid"
lxc-start: waydroid: ../src/lxc/tools/lxc_start.c: main: 306 The container failed to start
lxc-start: waydroid: ../src/lxc/tools/lxc_start.c: main: 311 Additional information can be obtained by setting the --logfile and --logpriority options
(003446) [22:34:20] waiting 10 seconds for container to start...
(003446) [22:34:21] waiting 9 seconds for container to start...
(003446) [22:34:22] waiting 8 seconds for container to start...
(003446) [22:34:24] waiting 7 seconds for container to start...
(003446) [22:34:25] waiting 6 seconds for container to start...
(003446) [22:34:26] waiting 5 seconds for container to start...
(003446) [22:34:27] waiting 4 seconds for container to start...
(003446) [22:34:28] waiting 3 seconds for container to start...
(003446) [22:34:29] waiting 2 seconds for container to start...
(003446) [22:34:30] waiting 1 seconds for container to start...
(003446) [22:34:31] ERROR: container failed to start
(003446) [22:34:31] See also: <https://github.com/waydroid>
(003446) [22:34:31] Traceback (most recent call last):
File "/opt/waydroid/tools/__init__.py", line 68, in main
actions.container_manager.start(args)
File "/opt/waydroid/tools/actions/container_manager.py", line 131, in start
raise OSError("container failed to start")
OSError: container failed to start
Are you using a GS5 or a rephone or a Volla22 ? I’ve had odd behaviour on the rephone, but, if I select the camera modes carefully (in advanced camera) and use advanced camera, I get consistantly good behviour on the rephone (recent angelfish is a fine browser, too). My GS5 is a bit trashed at the moment and the Volla22 I passed on.
Volla 22. Everything worked fine before the update (with the expected bugs) to 4.6.
AdvancedCamera gives me the same nothing like the normal Camera app.
Yeah, it’s an odd one. I thought it would be fixed if I reflash the same image I did the first time (4.4 I think?). Once I updated that with ssu, it went to shit
I just checked and I have 4.5.0.21 on my rephone (with everything but bluetooth le working). There the Manufacturer is Volla and Product name Phone 22 …
If you installed it, you must be running the devel build, not the testing one i guess? I submitted a PR to Halium last night to update droidmedia in the halium image to the version used in 4.6, so I hope that fixes and media/camera issues.
After I smahed my Screen in March, it is now more or less dead. Unfortunately I was stupid enough to reboot. Any chance to get my data which is on the phone without repairing the screen? My last backup is unfortunately from December 2023 .
I managed to get in fastboot mode but I have no clue if this helps.
