Yesterday i got my GS5 Lite and now I’m trying to do this. Developer mode is active, i’ve found the USB debugging option and switched it on, but i can’t find the anything regarding OEM updates. I found a setting called “Verify apps over USB” which is on by default and can be switched off, is that what you mean?
I’m not sure what the option is called, but the bootloader must be unlocked. I’ll have a look when I have an android available. @Seven.of.nine do you remember the name of the option to permit flashing?
I have no idea at the moment. I got my Volla phone with Volla OS or UB Touch installed from private seller and hadn’t to unlock the device. So I did install SFOS using UBPorts Installer @ Ubuntu Linux without any problems following the hints given by the UBports app on the Linux computer.
The bootloader has only to be unlocked at the first flashing of a phone. Every further reflash of a device at later time does not require unlocking the device again.
There is one thing with power up the device while holding Volume UP and another thing with (on a powered down/switched off device!!!) holding Volume DOWN and connect USB cable…
First i had to actually unlock it with fastboot flashing unlock, after that i could run the flash.sh script provided in the 7z file.
The run itself was successful (although i found 141 seconds for super somewhat short because the script indicates up to 10 minutes), and i rebooted the phone.
It’s now in a boot-loop: The Gigaset logo is shown with some text written over it:
Orange mode
Your device has been unlocked and can't be trusted
Your device will boot in 5 seconds
A few seconds later that the screen goes black, the vibrator motor shortly runs and the process starts over again. I am able to get into fastboot again.
you did run the flash.sh within the directory? My unpacked 7z looks like:
-rw-r--r-- 1 mwa mwa 33554432 Nov 5 18:08 boot.img
-rwxr-xr-x 1 mwa mwa 1443 Nov 5 18:08 flash.sh
-rw-r--r-- 1 mwa mwa 382 Nov 5 18:08 hw-release
-rw-r--r-- 1 mwa mwa 5534 Nov 5 18:02 Jolla-4.4.0.72-halium-mimameid-testing-aarch64.ks
-rw-r--r-- 1 mwa mwa 41636 Nov 5 18:09 Jolla-4.4.0.72-halium-mimameid-testing-aarch64.packages
-rw-r--r-- 1 mwa mwa 105945 Nov 5 18:09 Jolla-4.4.0.72-halium-mimameid-testing-aarch64.urls
-rw-r--r-- 1 mwa mwa 162 Nov 5 18:09 Jolla-4.4.0.72-halium-mimameid-testing-aarch64.xml
-rw-r--r-- 1 mwa mwa 2263393668 Nov 5 18:16 super.img
I indeed used the flash.sh script, the directory listing is identical.
To be 100% sure, can you post the sha256sum of all the files?
I was not sure if i should use the testing or the development version and tried both.
The phone was connected to a USB2.0 port on a Das Keyboard, which means there is a hub in between. The port itself as well as its upstream port are both USB2.0.
I’d recommend the hard way, since I can’t remember exactly what I’ve done.
First download the ubports-installer. With it, install Volla22 image (you need to boot it to android once to get the developer settings set up). Then when the android install from that is set up, go back to flashing with the flash.sh script.
The reason I say this is that the port was developed in the context of the Volla22 project and might depend on that exact android install.
Sorry that didn’t occur to me earlier. Too many irons in too many fires.
Edit: I have a spare that I need to flash but don’t know when (probably thursday or friday) I can get to it. In any case, I’m going to use the procedure I outline above.
I’m pretty sure the phone can be brought back to life.
Thanks for the instructions. I’m not in a hurry, so i don’t mind if it takes some time. My main issue is the ubports-installer which is not packaged for my distro, so i either have to do that myself or install a supported distro on a spare system. Either way, it’s gonna take a while .
Do you know where i can find the Volla22 image? Or does the ubports-installer download that for me?
I had a spare system, installed debian there, and installed the ubports-installer there.
This allowed me to install the Volla OS on my GS5, the flashing itself looked good.
After a reboot my phone did absolutely nothing, no response to whatever button at all. The only thing i can see is that the notification led lights up in white when i connect it to a USB port.
Now i’m really afraid i can’t get out of this because i can’t reach fastboot mode anymore …
Hmmm. Tricky. I, in my bastard consumer mode, would simply send it back … There is no way for ‘them’ to know what happened and, it sounds like there may be a fault with the phone.
Did you try both types of reboot? At some point you should get to baked in firmware (android firmware is flaky, so it sometimes feels like black magic). The first thing to do there would be something like delete user data / cache and try again.
