@Seven.of.nine I think the user mean the german thread.
Ok, that sounds good.
Just one question to be sure: From what i’ve heard with android you’ll have to create an account at google before you can actually use it. Is this setting reachable without creating an account? It would really be a deal-breaker if i’d have to create one.
I can’t speak about every phone, only about those which I owned, but: there was always a possibility to skip the step where it wants to link your phone to a google account. It keeps nagging you during the setup-process but you can skip it.
But I have never owned nor touched a GS5, so I can’t tell for sure, only 99.99%.
Updated Volla 22 4.4.0.72 to 4.5.0.18 and everything seems to be working fine. Please note: still in many cases the phone requires several reboots before the sim card is recognized, Bluetooth BLE devices are not recognized (e.g. smart watches) and there is no battery aging protection setting.
Yes @pa4wdh as @pansen-jim says, you can usually skip that step. and I did with the GS5 (I bought the ‘light model’ with 64GB space/4GB ram. 219 Euro.).
Yep, that seems correct … quite confused about the SIM and BLE issue!
Thanks again @poetaster and @pansen-jim for the information.
Last week i found a shop where i could but the GS5, but a few days ago the status on their website changed and says it’s not available anymore
. They do have the Lite version and as far as i can see the only difference is the built-in storage so i’ll see if i can get my hands on a GS5 Lite.
Oh guys, this becomes temptating…
Does the GS5 have a good GPS?
And are the pictures nice?
The GS5 GPS get’s a fix in about a minute. The GS290 and GS5 both had better GPS (judged by driving through France last summer) than the xperia 10II. I found, subjectively, the 290 had a better sensor, but haven’t actually tested this. The picture quality of the GS5 is certainly sufficient for my needs. the 6000x8000 pixel pics are really sharp and color reproduction accurate. The GS5 has audio output that’s ‘hot’ so it tends to distort if the volume is full up and you play rock’n’roll on the speakers but that’s better than being too quiet
EDIT: Currently, I would NOT upgrade the GS5 to 4.5.0.18 (well, I did, sigh) since the browser is less stable than it was with 4.4.0.72.
The sim thing seems to be that the setting for PIN is lost. On reboot or cold start, you have to go to Settings and enable PIN, get the SIM prompt, enter the pin and reboot. Then it’s set. I ‘believe’ the PIN setting goes away when you power down.
Thanks!
Do you mean camera sensor?
Is it good in low light?
I have to compare the specs and sizes of both GS but it looks that with a good GPS and a nice camera, one of them could be a cool replacement of the XA2. (which is almost perfect, out of the medium GPS and not-very-sensible camera).
edit: and about the Volla, no big differences out of the brand, price and pre-installed multi-boot, is that correct?
I think the GPS sensor on the 290 was a bit better. But both are fast in comparison with the sony.
Volla is no different but for the branding. I’ve purchased (and re-sold) from Volla just to support them, I keep the Gigaset phones
It’s ‘ok+’ I’m not sure how best to test it. I have a couple of low light shots on it now and they’re ok. You mean, ones without flash, or?
Yeah, without flash.
My point of comparison is the XA2, which camera is worse than the N900 in low light!
If you like, you can redo that and sell it to me, in order to double support
Ah, got ya. It’s much better ![]()
And I don’t have any volla phones now … future.
I’ll probably get my GS5 Lite next saturday
is there anything i should to before installing SailfishOS? For example, with my FP2 i was advised to calibrate the proximity sensor before installing because that is not possible within SFOS.
This doesn’t work in my case. On a cold boot, I go to settings and enable PIN and get the SIM prompt, enter the pin and then nothing happens and the sim card is still unknown, even after several reboots.
We should try to get the exact steps to ‘recover’ down. That might be enough information for piggz to recognize a pattern. I just did:
- power down.
- power up. (sim is gone).
- go directly to settings, PIN,
- select require enter PIN
- nothing happens, leave it open
- close settings
- return to settings, change SIM (SIM 2 toggle of / on)
- reboot
- this time sim prompt comes up.
Sometimes I forget to change 2 SIM related settings and I have to reboot 2 times.
Hello
can i use with this port on my gs5
android apps?
Yes if you install Waydroid. I don’t know exactly on GS5, but I use it on my Volla Phone / GS290 and it works fine.
